Question about Sebo Vacuums
I cleaned my sebo upright vacuum cleaner but get a grinding noise and rubber burning smell. Could be the belt? How do I change that ?
    New Friend:
  • 108 Answers
Is the brushbar free to turn? Belts dont burn up if everything is moving freely
Posted on Apr 18, 2017
  • 397 Answers
SOURCE: Eureka Maxima Bagless brush not spinning in vacuum position
belt doesnt have to be broken, check the metal arm on the vacuum, see if there is build up of old rubber from previous belts, clean the arm that spins the belt and double check to make sure u have the correct belt
Posted on Jan 20, 2008
  • 30 Answers
SOURCE: Burning smell and smoke
I ran into a scenario similar to this at work. With the burning smell and smoke combined, it leaves only one problem remaining; the motor. The motor and the pulley that enables the belt to spin could be malfunctioning (causing friction between the 2 parts) and thus causes the burning smell and the smoke. I'd highly advise not to touch either part after having the unit on (YOU WILL BURN YOURSELF).
The only other likely possibility is to make sure there aren't any hairs caught in or around the motor and the bearings of the agitator.
Posted on Mar 08, 2008
  • 1673 Answers
SOURCE: sebo x5 vacuum cleaner
The full bag light comes on when it is getting full or a blockage in the hose or the dirt inlet by the brush roll. Other then that, there is a circuit board called the computer controller, part #5740ER and is giving you a false reading and causing a shut down.
Posted on Jun 22, 2008
SOURCE: Oreck Vacuum Cleaner problem (upright)
the belt has stetched and needs changing.
Posted on Apr 21, 2009
Vac Belts
  • 701 Answers
SOURCE: Makes a loud noise like a grinding noise.
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Posted on Nov 30, 2009
Sebo x4 grinding noise and smell. have changed both belts but problem persists
Suspect the motor bearings.
Many machines now have too much plastic, causing melt down within a short time after the warranty has expired.
Might be time for replacement.
God bless your efforts.
May 22, 2017 | Sebo Vacuums
My Sebo vacuum cleaner makes a whistling noise when standing upright
similar to the air relief on my dyson think it is so they don't burn motor up
Feb 17, 2015 | Sebo Automatic X4 Extra Upright Vacuum...
Sebo vac grinding noise and burnt smell
Take it to your local vac shop for assessment. Sounds like a bad motor. If they are not a Sebo dealer, make sure they know that a X1 motor is not the same as an X4 motor. It should cost around $200 for the total repair . A new X4 is $799 so the repair is usually a good idea.
Jun 16, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
Smells like burning rubber when running
Vacuum belts lose elasticity and will slip. It may spin the brush roll ok when you look at it but be so loose that when. Vacuuming carpets the belt will stop turning. The motor shaft is still spinning and will melt the rubber belt causing a burned rubber smell. Belts on almost All vacuums need. To be changed at least twice per year.
Nov 13, 2011 | Riccar 8955 Upright Vacuum
I have a windtunnel vacum cleaner. When I
It might be a slipping rubber belt, is the brush roller moving when you look underneath? If it's a self propelled machine there might be another slipping belt. Friction from fast rubbing rubber can smell like it is burning.
Jan 16, 2010 | Hoover Company Wind Tunnel U53019 Upright...
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me...
Nov 30, 2009 | Vacuums
DC07 Low Reach Vacuum smells like a belt is burning and is making
The roller is likely jammed, or there is debris around the belt area
Jul 05, 2009 | Dyson DC07 Low Reach Bagless Upright...
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Vacuums Logo
61 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
