Question about Karcher Vacuums
Karcher vacuum window cleaner When fully charged, switch on machine it works, then switch it off turn it back on green light blink all the time also the motor does not work and does not switch off.
Buffalo12980
  • 625 Answers
SOURCE: Embeded Dirt Finder
check out the switch that activates it. go to thehooverstore for a complete listing of hoover machines. I'm sure you'll find your machine listed along with an exploded diagram of the machine
Posted on Sep 22, 2007
SOURCE: Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Posted on Jun 20, 2008
  • 13 Answers
SOURCE: Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Posted on Oct 03, 2008
  • 14 Answers
SOURCE: Karcher Press & Ex 800
The water pump is not working or the pump line is blocked. Check the pupm hose, if ok replace water pump
Posted on Mar 06, 2009
  • 10865 Answers
SOURCE: Brushes don't turn, light works when switched on,
Hello. Generally, when the brushes don't turn you will find that the belt is broken. In some cases, also the brushes will stop if they are clogged up with animal hair, etc. Regards, Joe
Posted on Dec 14, 2009
Why does the green light stay on when my window vac is turned off
It never did this before. I would assume that light indicates the battery is fully charged.
Jul 17, 2016 | Karcher WV50 Window Vacuum
Karcher wv50 spare on off switch
If you contact one of the Karcher Centers ( details are on Karcher.co.uk website) they may be able to help.
regards Gary
Aug 02, 2014 | Karcher WV50 Window Vacuum
My karcher window vac does not seem to charge?
Have you tried to take it all apart just a small bit of rubbish will stop it from working.
Jul 24, 2014 | Karcher WV50 Window Vacuum
Why wont my karcher window vac switch on even after a full charge any ideas ?
Take it apart and see what is stopping it (the motor) from turning .
Jun 23, 2014 | Karcher WV50 Window Vacuum
Can't switch Karcher window vac off
I had the same problem and I let the battery run down to stop it cycling on and off. My husband investigated it and found that there is a fault with the on board battery charge sensing circuit. (when the charge is about 10 to 15 % remaining the onboard ic controller cycles the unit on and off, irrespective of the switch. He checked it by cutting wires to the switch and it still cycled off and on so the switch was not faulty.
He put it all back together and said to charge it before it gets too low. If it cycles on and off it probably needs a re charge at that point.
Unfortunately there is no battery level indicator on the tool and nothing to suggest in the manual of what may happen when battery is flattening.
I am taking this up with Karcher as I only used it three times so far and it it was not a cheap gadget. Hope this helps
Mar 08, 2013 | Karcher WV50 Window Vacuum
Status light is red, why? I have a Roomba Discovery.
Hi.
If the red light is solid, that means that the Roomba is near to full discharge. If the light is flashing red, then the Roomba is completely out of charge.
If the Roomba is fully charged, then there may be a fault.
Here full list of light codes:
Pulsing Amber - Charging
Green - Fully Charged
Amber - Partially Discharged
Red - Almost Fully Discharged
Flashing Red - Fully Discharged"
Here manual
See also
Roomba DISCOVERY MODELS' DIAGNOSTIC TESTS
May 24, 2010 | Vacuums
Vacuums Logo
49 people viewed this question
Top Karcher Vacuums Experts
kbright1
Level 1 Expert
richie46
Are you a Karcher Vacuum Expert? Answer questions, earn points and help others
