Question about Coffee Makers & Espresso Machines
How to get Italia glitter eyelinner liquid again I bought 3ofthem and they are all dried u how to saddmoisture to them ?
How do I used glitter glue on my scrapbook?
Glitter colors are small bottles of color that have glitter inside. You can use them for decorating pages, putting borders around photographs or even for writing details on the page. Just make sure that the glitter is fully dry before you turn the page.
Feb 12, 2013 | Crafts & Hobbies
How do I decalicy the Starbucks Italia Digitial?
Use a coffee machine descaling liquid or powder. Follow directions on product. Add it to water container on machine and push the descaler button "bottom right" on machine. Follow directions on screen.
Jul 17, 2011 | Starbucks Saeco Italia Digital Barista...
I spilled liquid through the top grate of the microwave by accident and it has dripped through to the inside. Is the microwave ruined now or is it still safe to use?
Its not ruined and it's still safe to use.
But before use, make sure you dry up the visible liquid, and wait for some hours before using the microwave again so that the liquid would dried up by then.
In summary, it is advice-able that the liquid dry first before using the unit again to avoid electric shock or damage to the unit.
I hope you understand the above.
Good luck.
Mar 02, 2011 | Microwave Ovens
How could i put a glitters with my wall at my facebook
  • SPRAY CLEAR GLITTER ON DRY WALLS -- Go to your local craft store and pick up a couple cans of spray glitter. You want a clear base so you can keep your current wall color. Look for a spray that says something like clear glitter finish or clear glitter sealer. Then just spray your walls with the clear glitter spray.
  • PAINT YOUR WALLS WITH GLITTER SPRAY PAINT -- If you want to change the color of your walls you can spray paint them with colored glitter spray paint so you get the painting and glitter done in one easy step. However, spray paint can be expensive and you may find it is difficult to get a nice even coat of paint. So this method would be good for a small room or an accent wall.
  • PAINT YOUR WALLS THEN ADD GLITTER -- This is the cheapest way to get the glittery look you want. Buy your wall paint in the color of your choice. Then buy tubes of glitter in the craft section. As you paint your walls, do one small section at a time. Then pour out a bit of glitter on a paper plate and gently blow on the glitter so it blows onto the freshly painted wall. The glitter will stick to the wet paint. Then move on to the next section and do the same thing! If you are applying two coats of paint to your walls add the glitter to the second coat.
  • Feb 27, 2011 | Graphics RSA SID700-6-60-48-5...
    My son Dumped some kind of liquid on my LG Rumor and now it is white screened.
    Please take note; once a phone drops into water or any liquid, first thing you need do is to remove the battery, get a phone screw driver, loose the phone and dry the phone board with bulb or any heat.
    The essence is to dry the water totally from the board, because if it dries itself, the phone board will get rust and phone might not work properly again.
    Back to your phone, I think the liquid as entered your screen and its not dry yet, that's why its white.
    Put off the phone, remove the battery and leave the liquid to dry on the screen or put is near a very light heat and the liquid will gradually dry off.
    Try it, it will work.
    Take care.
    Dec 30, 2009 | LG RUMOR Cellular Phone
    Coffee Makers & Espresso Machines Logo
    24 people viewed this question
    Top Coffee Makers & Espresso Machines Experts
    Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
