Question about Dryers
I ordered3italialiquidglittereyelinner and when they arrived they were dried out how do I fix this what do I add to make them moist again I really like the product b
    Top Expert:
  • Dryers Master
  • 47,797 Answers
Complain to the supplier as they are old stock and should be returned
as to how to make them moist , may be a beautician could have the answer there
Posted on Apr 17, 2017
How can I oven dry spices?
Turn your oven to add low as it will go, put the spices in and keep a close eye on them, they will go from moist to dry very fast.
Jul 28, 2014 | Cooking
Humidifier not getting enough water
I suggest you buying the FOG RING: http://www.neotizen.com/main/main.php
This is really helpful for HUMIDIFYING any area, it is very cheap and it produces a lot of cold vapor.
Dec 28, 2013 | Trion ComfortBreeze CB707 - Atomizing...
Freezer too dry
Why is this question in camcorders?
Water can evaporate from ice. This is called "sublimation".
As a result, ice cubes shrink, especially in frost-free refrigerators, which are often very dry. Frost free models have a fan that circulates air internally so the moist air gets blown out, rather than
Freezers get condensation from moist air that gets inside when you open the door. Frost free models cycle off every few hours, and warm up a bit (a heating coil) to melt the condensation and then they blow that out so it won't form frost. They also blow out any vapour from the sublimating ice cubes. Then they cool down again.
Oct 26, 2012 | Video Cameras
Moving/Shipping bolt re-installation for Frigidaire Front loading washer Mod # GLTF2070DS0 Serial XC40623490 instructions and tips as well as suggestions. Is this really needed, unit will be in storage...
yes it sure is a good idea to have the shipping bolts in place to move it they tend to bounce around and could damage something if not secured...also a tip would be if it will be stored where very warm sure as storage places generally are it would be a real good idea to pour about a gallon of water in tub since their is always water their to keep seals wet to prevent dry rot and if stored where hot that water may eveperate so add some to keep it moist and the seals wont dry rot
Gene
Aug 24, 2011 | Washing Machines
My daughter spilt a bit of cranberry juice on my touch pad. I have a hp. The mouse is working but the left button is a no go and the right one only registers sometimes. What can i do to fix this and make...
Hi, dry it using hair blower to make sure the moist go. To fix your mouse left button, try to unscrew the mouse casing and see to it that by clicking it really contacting with the switch button. Wear and tear also damage the solder of the switch button. it will be fixed by re-soldering the mouse switch if loosen.
Jun 21, 2011 | HP Computers & Internet
What are the settings (humidity)from 40 upwards on my micromark ? . Is the lower setting to take out most moisture ? Thank You
40 is 40% humidity in room - that's really dry.
For moist area you usually want 50 or 60%.
Dehumidifiers are for damp areas. If temp ouside is below freezing, inside house is probably already too low.
Dec 01, 2009 | Dehumidifiers
My Sharper Image ionizer after I cleaned the grid now makes popping noises and then the red light that says drying grid comes on most of the time. Sometimes the light that says attention required comes...
You are probably aware that the ionizer uses a very high voltage (at very low current) to function. If you have used a cleaner of some kind on it, you could have made the grid sensitive to moisture.
I would remove the grid again and wash it thoroughly in distilled water to remove any residue that stayed behind, then dry it in warm air before reinstalling it.
Oct 10, 2008 | Sharper Image Hybrid GP (SI724) Air...
Good evening I am an owner of a General Electric Gas Dryer Model PWSR483gb1WW it has never really dried my clothes properly (the temperature of the dryer when in function is 116 fahrenheit) the GE tech...
How long is the dryer vent hose .It should be metal and as short as possible, best under 12 feet long. Is there any thing that can get in front of the vent outside that may block or hinder the exit of the hot moist air. Too long a vent pipe or a out side flaper that is not free moving will cause back pressure that will not dry your clothes without more that one drying cycle. Also lint can get stuck in the hose especially at any bends,can be a fire hazard.
Jun 23, 2008 | Dryers
Dryers Logo
24 people viewed this question
Top Dryers Experts
