Where do I plug in sound bar - Televison & Video
    Habit-Forming:
  • 100 Answers
Soundbars are often optical and require a specific cable. If your tv does not have an optical output, other options are hdmi or phono... phono can also be taken from the tv with a scart to phono adaptor.
Posted on Apr 17, 2017
How do you install a sound bar
DO ALL THIS with the power OFF - All you need is power, and an optical cable... there are specific places to plug each end and they insert in a certain orientation..
Once you have power to the sound bar and the optical cable plugged into the sound bar and TV... power up both..some TV's will automatically recognize the connection, some will need to be programmed..(via the menu).. its not hard!! I can control the on/off of the sound bar with my TV remote. This is a simple connection..good luck.
Oct 18, 2017 | Audio Players & Recorders
My sound bar didn't come with the red/white aux cables. I had some at home. I plugged the red into the red, and white into the white, but, it's not working. And yes, the soundbar is on. My input lis
Think you can set sound bar to play via Bluetooth .go into the settings of the tv and look for Bluetooth.when the sound bar is on make it discoverable and the tv will pick it up.if you don't have Bluetooth then check to see if there is an option switch in settings to use external speakers.check cable and also check volume on sound bar is not muted.also see if you can link the tv to sound bar via optical link cable as this is much better than RCA red/ white audios which tend to fail as people pull on the cable rather than the plugs when removing them from equipment.
Dec 12, 2014 | RCA RTS735E Home Theater Sound Bar
How do i connect a sound bar to a laptop?
Probably the easiest way is through a jack to jack cable (3.5mm).
One end plugs into either the speaker output or headphone output on your laptop and the other plugs into a socket that is most likely on the side of the bar and will be associated with iPhones/iPads - on my sound bar I would use the iMusic setting.
Depending on your laptop/sound bar their maybe a number of other ways to connect that may be preferable.
May 11, 2014 | LG 47LG50 47 in. LCD HDTV
Just bought a G-Sonic 32 inch sound bar came home hooks it up to my Vizio 42 inch tv no sound with bar??? RCA on TV and bar a PC and plug in no sound ?
I had the same problem, no sound from tv to the sound bar. I hooked up the output for sound from the sound source, your cable tv box or satellite receiver and ran it to the sound bar, and then received sound.
Nov 29, 2013 | Televison & Video
Klipsch soundbar (SB1) won't power on ... green light on power adaptor seems to trip and go off when I power on the SB
I have read that this may be due to the order in how the AC adapter is attached to the sound bar. After some research I found that you need to unplug the AC adapter from the wall and the sound bar and let it sit for about 15min. Then flip the power switch "ON" on the sound bar and connect the AC adapter to the rear of the sound bar. Lastly, plug the adapter into the power outlet.
Feb 21, 2013 | Klipsch Audio Players & Recorders
No sound from as500 speakers
Hi there. If the sound bar is plugged into the monitor you also have to make sure that you have the cable from the bar plugged into the audio jack on the pc which is the pale green port. Hope this helps Mark
Aug 22, 2009 | Dell AS500 Sound Bar Computer Speakers
I had memory added to my pc so everything was unplugged. Now I can't figure out which one is the power source for my speaker bar and where it should be plugged. The speaker bar has the green light on and...
Make sure the green plug from the speaker bar is plugged into the green plug on the back of your computer. If it is plugged into the wrong jack you will not get sound. Hope this helps.
Mar 16, 2009 | Dell AS500 Sound Bar Computer Speakers
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
