Question about The Watches
How to turn off the 5 minute beep on a coleman wr30m watch.
My Watch is showing military time but i want it to show in the 12 hr clock
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
http://www.fixya.com/support/t6812987-change_timex_wr30m_from_24_hour_12
How do change my timex wr30m from 24 hour to 12 hour display
Mar 21, 2018 | The Watches
How to set the time on timex WR30M watch?
hi Janet.
You may also need to change the time when traveling or to adjust for daylight saving time.
  1. What to Look For. Locate the MODE button, the SET/INDIGLO button and the START/STOP button on the side of your Timex Indiglo WR 30M.
  2. Setting the Hours. Press down the MODE button until "TIME" appears. ...
  3. Setting Minutes and Date
https://oureverydaylife.com/how-do-i-change-the-time-on-a-timex-indiglo-wr-30m-12421830.html
How to set the time on timex WR30M watch Google Search
Dec 13, 2017 | Timex Watches
Pasnew watch Model wr30m set time
Try Googling (Pasnew)(wr30m)(manual) without parens to get instructions.
Nov 09, 2017 | Watches
How to set the time on a wr30m watch
google how to set time on a wr30m watch
Sep 10, 2016 | The Watches
Turning off alarm on Model: WR30M?
Google (fossil)(WR30M)(manual) without parens for instructions.
Apr 05, 2014 | Fossil Watches
How to change the date on a Mingrui WR30m watch and also the day setting unless these are corordinated?
Keep on clicking on mode until it comes up with the seconds flashing. Then click on reset 5 times until the day is flashing. Then click on start until the day changes to the day you want! :D It worked for me
Sep 25, 2011 | Watches
How do i change my timex wr30m from 24 hour to 12 hour display
Hi cbrichw,
Hope it helps.
Thank you for using FixYa.
Nov 13, 2010 | Timex 1440 Nylon watch
HOW TO CHANGE THE TIME ON MY DIGITAL WATCH IT HAS 4 BUTTONS ON THE TOP LEFT IS "LIGHT" ON THE LEFT "MODE" ON THE TOP RIGHT "START" AND ON THE RIGHT IS "RESET" THE...
Press "mode" until the hour is flashing,
Now press "start" to change the hour. When hour is correct, press "reset" and minutes should start flashing.
Press "start" to change minutes" then press "mode" again.
Oct 29, 2010 | Watches
Setting Time and Date on a Timex WR30M
1) Press and hold mode for about 2 seconds and then release. You will now be in the alarm edit mode.
2) Press mode once more and now you are in time edit mode.
3) Use the stop button to select what to edit, i.e. hour minute, etc.
4) Use the reset button to make the changes once you have selected the hour/minute, etc. that you want to change.
5) Press
Mar 07, 2008 | Watches
Watches Logo
63 people viewed this question
Top The Watches Experts
D. E. Hev
vince
gbob59
Are you a The Watch Expert? Answer questions, earn points and help others
