Question about GE Health & Beauty
Need battery charger for a (pace saver plus 3 premiere). 3 wheeled scooter about 1999 model Serial#. GE 40213 R. 4 pin , not XLR type.
gewiz
  • 1263 Answers
SOURCE: when turning on the charger for a bec sterling 3
what the charger is showing that ?, it has a digital display ? please supply more information
Posted on Jun 13, 2009
  • 177 Answers
SOURCE: Pride Celebrity Deluxe Mobility Scooter - Serial Number
Hi. The serial number will be on a sticker on the upright support that holds up the seat. You will have to lift of the seat, and take the cover off the batteries to see it. It should be on the front of the deat support. Neil.
Posted on May 27, 2010
  • 177 Answers
SOURCE: just bought my dad a second hand go go 3 wheel elite scooter
Hi Linda. Sometimes if there is a blown fuse or faulty connector on the battery leads, the charger thinks the batteries are charged as the voltage coming out of the charger rises to the high level. Some chargers will cut out if this happens. It is probably not the charger.
Make sure the batteries are plugged in correctly, sometimes during transport they will get knocked and become disconnected.
Also make sure that the battery terminals are not loose where the wires connect to the batteries.
Good luck. Neil.
Posted on Jun 05, 2010
  • 177 Answers
SOURCE: I needto replace the battery charger on my Rascal 600F scooter
Hi. Most chargers with only two wires, have a small bridge wire from the
black ( negative ) wire to the middle terminal of the connector. This disables the controller while the machine is charging. The charger will still work without this bridge wire, but the scooter will still operate normally.
There are a few different chargers around that have an internal relay that disables the scooter, but these chargers are normally "on-board" chargers.
Good luck. Neil.
Posted on Jul 07, 2010
  • 46 Answers
SOURCE: NEED A REPAIRMAN FOR A 3 WHEEL BATTERY OPERATED SCOOTER IN FLORID
well it most likely the the 5k ohm potenteitometer is bad this is a common ptoblem with pride scooters if you have a screwdriver and can take it apart you can order the part online and it comes with the wire tail on it so it just plugs into the controller board the part costs about 68 dollars from pride depending on what model you have, email me and i could probably walk you through it
Posted on Jul 11, 2010
I need the XLR pinout for my Air Hawk portable wheelchair. The charger fell out of the wheelchair pocket on a flight, I need to charge the 24 V battery Li-Ion so I can make it back home with power.
is this ref any use ?
XLR Style Charging Cable for wheel chairs scooters and electric bicycles
be careful over what charger you use as Li-ion batteries must not be overcharged. most have a sensor that detects the voltage and stops charging when the battery is fully charged. This circuitry is inside the charger, not the pin.
May 22, 2016 | Health & Beauty
2 Prong Battery Charger
800-255-0285 Leisure lift / Pace saver ask for tech support.
Mar 28, 2016 | Health & Beauty
What retail store can I find a battery charger for a terminated scooter
hi the new charger plugs & sockets will not fit that if u cant get the old type charger have a look on E/BAY they have chargers as low as $20-00.but u will have to change youre plug and socket u can buy tem on e/bay c photo .good luck hi again I just thought of another way if u buy a XLR CHASSIS SOCKET FEMALE 3 PIN COST ON E/BAY aprox $6-00 U CAN USE THE NEW CHARGERS ...cheers
Aug 29, 2015 | Health & Beauty
Pace saver iii repairs
Make sure the battery is properly charged. A discharged battery will light up the lights but do nothing for the motor.
Jul 16, 2015 | PaceSaver Plus III Titan 3 Wheel Travel...
Hooked up charger sparked melted the plug
Change the XLR PLUG ( three pin male or chassais female are easily found on the internet. Always plug the carger to the mains supply last and remove the mains end plug first when unplugging.
check for shorted wiring inside the XLR plug
Apr 05, 2014 | Pride Victory 4 Wheel Mid-Size Electric...
Charging schematic for pride scooter
red + goes to pin 1, black - goes to pin 2 and jumps to pin 3
Dec 29, 2013 | Pride Rally 3 Wheel Scooter
Powerchair charging socket.
Most externaly charged wheel chairs use a three pin connector thee pins are arrainged ina triangle. This is an XLR flange connector. You can get one from here http://www.capitolsupply.com/catalog/40663-cables-go-panel-mount-cs9745018.html?cid=cse_ggl4 This should look like what your charging port.
On qusttion, hve you ever used solddering iron? You will need at a minimum a 35w iron, eutectics solder, solder past, acid brush and a good wire stripper. Before i get into a long discertation on soldering, I take things i need to be soldered to Batteries Plus, battery shop. My Rascal 600t has an internal charger but i wanted to charge my batteries externally. I designed a charging harness to be used with my external charger. I gave the design to the guys at battery plus and they fabricated the harness for me. I would bet you that if you took your chair to them they would replace the connector for you. Any good battey store should have the soldering gear and folks that can use it to replace that connector with the equipment its not hafrd to do.
Jul 10, 2012 | Electric Mobility Shoprider Electric Power...
Pride pace saver manule
This is a Leisure Lift Pacesaver Plus II scooter.
Here is the link to order a new manual and more information on the company.
http://www.pacesaver.com/ps2manualrequest.html
Hope this helps
Jul 03, 2012 | Pride Health & Beauty
Hello. I need a battery charger for a Rascal 325. This is the second one. It is not an OEM but a Prism GHC-244000IL-EMI 24V Model AE244000. They tell me at my scooter repair store that the OEM costs...
Any 4 amp charger you can find will work to charge your batteries. Preferably find one that has an on/off switch on the charger. You should be able to find one on ebay a lot less than what the scooter repair store quoted you Check around your neighborhood someone might have a second charger that they are not using. Since Medicare will pay for a new chair every 5 years someone might have a extra charger laying around. Hope this helps you
Oct 18, 2010 | Electric Mobility Power Electric Scooter...
Health & Beauty Logo
Top GE Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a GE Health and Beauty Expert? Answer questions, earn points and help others
