Question about Watches
Adjusting a steel band to fit my wrist. - Watches
    New Friend:
  • 12 Answers
Hi , Steel Bands are made of pieces which connects with pins.
just pull out the pins of the exact piece that you want to remove and then join them by inserting the pin.
Also for small adjustments it can fix by repositioning of end to lock attachment.
Posted on Apr 21, 2017
Where do I get links bought the watch used off a buddy and he has the smallest wrists known to man and also is there anyway to get the illumination back in the hands again
to fix the band problem just buy another band and fit it
as to the hands , I'm afraid that it will not be worth the cost to have the hands re painted with luminous paint
Dec 16, 2015 | Nixon The 51-30 Tide - One Size - Sanded...
How do I remove a link in the steel wrist band on my watch
no details or photos so the best advice is to take it to a watch shop or jeweler and have it done
Dec 15, 2015 | Watches
Remove links
  • Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
  • 2 Place the watch face-down on a flat surface.
  • 3 Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
  • Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
  • Finish removing the pins with your pliers.
  • Keep the extra links in case you ever need extra room on your watch band.
  • For further assistance, check out the link:
    Aug 17, 2010 | Pulsar Men's Stainless Steel Bracelet...
    I am trying to figure out how to shorten the wrist band on my Casio Edifice EFA-119.
    mcdevito75 here, If your Casio has a metal band, you can remove 1--2 links, this takes a special tool called a link remover, best bet is to look for a small watch repair shop in your area. If your Casio has a strap, the buckle may be able to move up the strap to fit your wrist, if so, move the buckle up the strap to fit your wrist and cut offf the exccess strap. If not, you"ll have to replace the entire strap. Hope this helps.
    Aug 03, 2010 | Casio Edifice EFA109-7AV Wrist Watch
    How to open Baume & Mercier Hampton Milleis ladies stainless band
    Looking at your watch it looks like the clasp on the SS model is just a double deployant preasure fit. If it is brand new sometimes these style of deployants are vary tight.
    It is Stainless Steel it is vary difficult to break it looking at the construction of the bracelet.
    Basically you just Pull, there is no button it is just pressure fit.
    mike --
    Jan 01, 2009 | Baume Et Mercier Hampton Milleis MOAO8242...
    Adjusting the strap
    Most clasps have a series of small holes drilled in them, and the end of the strap is held in by a small, spring-loaded bar whose ends are seated in one set of holes. Take the end of a small paperclip, or a large needle, and use it to depress the spring-loaded pin. You can then carefully slide it to another set of holes to make the band smaller. Don't let the ends of the pin slide all the way out of the clasp, or it might shoot off into space.
    Jan 22, 2008 | Versace 27473-008-00 Wrist Watch
    Tessot steel wrist watch band
    i own a tissot too. instead of removing a link, just change which hole the link sits in on the clasp
    Jan 13, 2008 | Watches
    Watch band
    How can I remove a link from my watch band to fiit my wrist?
    Dec 22, 2007 | Fossil AM 3688 Wrist Watch
    Watches Logo
    13 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
