Question about Toastess Kitchen Appliances - Others
My toastess fry pan leg broke how do I replace it all 4 joined with 1 screw
    Top Expert:
  • Toastess Master
  • 42,122 Answers
You will need to get a complete new stand unit
or there is a product on the market that has a liquid that is set by ultra violet light
you could get that and give it a try
Posted on Apr 17, 2017
Need plastic leg for Fabre ware frypan model 310A
Until you find the correct leg (via fabre wares website) you could get by with finding a screw that fits inside where the leg attaches, drill out a chunk of wood that you measured to make sure its the right height, insert the screw thru the drilled hole and attach the new temp leg to the frying pan.
Oct 02, 2016 | Kitchen Appliances - Others
Recumbant bike makes aclunking sound whe pedaled
follow this steps and fix it. God bless you
Prepare to oil by filling a grease gun with lithium grease. Check your owner's manual for the exact type of grease for your unit.
Locate where it is you need to lubricate. Focus on the bearings, free-moving joints and attachments with moving parts such as handle bars, wheels, pedals arms and guide rails. Go to each location one by one when greasing.
Unfasten the bolts or screws that hold the joint or attachment that you wish to lubricate.
Grease each bolt and screw liberally. Tighten each bolt and screw back into its place when finished.
5
Wipe away any excess grease
Loose Pedals
Kneel next to the left side of the elliptical's base. Use the Phillips screwdriver to tighten the two screws located in the center of the left pedal.
Use the Allen wrench to remove the bolt securing the left pedal arm to the pedal leg and body arm. Use the Phillips screwdriver to remove the screw securing the rear end of the pedal leg to the crank arm.
Pull the end of the pedal leg free of the crank arm. Wipe the crank arm clean, then apply a fresh coating of machine grease or silicone lubricant. Replace the end of the pedal leg back onto the crank arm and use the previously removed screw to secure it back into place.
Join the front end of the left pedal arm to the ends of the pedal leg and body arm. Use the previously removed bolt to connect the pieces together.
5
Move to the right side of the elliptical and repeat the above steps on the right pedal arm
Dec 09, 2013 | Exercise & Fitness
I need a new "leg" for my society electric fry pan
You don't need anything unless the frying pan doesn't work because of the leg.
what you can do is just put an object in place of the leg it works out cheaper too
Oct 21, 2013 | Society / Regal Ware Society Regal Ware...
How to replace joint on buzz lightyear leg
get a wooden dowel pin that will fit inside leg. Push it in leg then push some newspaper around it to secure it in place. Then put wood glue
on the whole thing with dowel removed Insert dowel and let dry for about 4 hours.
While waiting get the leg socket and drill a hole in the middle so it lines up with the dowel. Countersink so the screw doesn't stick out and get in the way.
drill small hole in dowel for screw and attach leg socket.
Wouldn't hurt to put epoxy under leg socket for better adhesion.
Let set for 24 hours then enjoy.
May 04, 2013 | Thinkway Disney Pixar Toy Story 3...
NordicTrack SL710 pedals slip and make a clicking noise?
Kneelnext to the left side of the elliptical's base. Use the Phillips screwdriver totighten the two screws located in the center of the left pedal.2
Use theAllen wrench to remove the bolt securing the left pedal arm to the pedal legand body arm. Use the Phillips screwdriver to remove the screw securing therear end of the pedal leg to the crank arm.3
Pull theend of the pedal leg free of the crank arm. Wipe the crank arm clean, thenapply a fresh coating of machine grease or silicone lubricant. Replace the endof the pedal leg back onto the crank arm and use the previously removed screwto secure it back into place.4
Join thefront end of the left pedal arm to the ends of the pedal leg and body arm. Usethe previously removed bolt to connect the pieces together.5
Move to the right side of the elliptical and repeatthe above steps on the right pedal arm
Oct 31, 2011 | Nordic Track NordicTrack Treadmill, A2550
10-1/2" Bow window (PVC) Was manufactured
If the unit is not too long or protrude to far out you can line the bottom with 3/4" plywood and slide into opening. If larger unit Dog legs (angle supports) will have to be added to the bottom of the unit exterior screws will hold longer than nails. Put dog legs as close to where every window joins together (if larger multi window unit) and back down into the framing of the home (use pressure treated lumber) cover with matching home exterior coverings.
May 27, 2011 | Garden
IN THE OLD DOUBLE SWITCH I REPLACED WITH THE 5224, SWITCH 1 WOULD TURN ON LIGHT 1 AND SWITCH 2 WOULD TURN ON LIGHT 2. I WIRED THE 5224 THE SAME WAY AS THE OLD SWITCH. NOW ONE SWITCH ON THE 5224 TURNS BOTH...
The switch is wired backwards. Swap sides with the wires.
If you look closely at the switch you will see that one side has 2 screws that are joined together with a metal tab. _That_ is the side that gets the hot wire, pick a screw, it doesn't matter which one as long as you don't break off that tab.
On the other side of the switch you will see that the 2 screws are _not_ joined together with a metal tab. _Those_ are the screws that connect to each individual switch leg.
Dec 11, 2010 | Leviton 5224-2 Wall Duplex Switch
Broken leg - need replacements
bake lite is very hard to repair
but i ahve made this very repair using a varied amount of things with varied success
depending on where it broke yo may want to try gorilla glue
if clost to the bottom get som jb weld from your harware store this will do it it may not be prtty but it will work
May 10, 2009 | Kitchen Appliances - Others
TT 200 Toastess Toaster
hi 1)yes - aluminum: solder, plastis: epoxy 2)yes if you got special gear for it 3) NO BUY A NEW 1 IT WILL COST HALF THE PRICE!! GOOD LUCK
Mar 22, 2006 | Toastess TT-200 Turnover Toaster
Kitchen Appliances - Others Logo
Top Toastess Kitchen Appliances - Others Experts
ray gallant
Tom Chichester
Bill Boyd
Are you a Toastess Kitchen Appliances - Other Expert? Answer questions, earn points and help others
