My TV seems to be stuck on Widescreen. I went to menu and the system will not adjust back to normal setting
    Top Expert:
  • Televison & ... Master
  • 47,568 Answers
You will need the onscreen menu to make the adjustment in aspect ration or pixel settings
Posted on Apr 17, 2017
Vertical and horizental picture expand and please help me to adjust it
It might help if you listed the brand and model of your TV, but usually on the remote you will see some sort of mode button. You can change the picture size there. Or you can go into your system menu and change it in the display menu. The typical ones are widescreen, zoom, stretch, etc. Also try changing the picture aspect ratio. 16:9 will give you widescreen while 4:3 will give you regular. Also, another problem might be that the channel you are watching or your cable box is not in HD. If the channel is not specifically an HD channel, the widescreen setting will not work properly and you will need to adjust it to a different setting to keep from getting the black bars on the side. Hope that helps.
Mar 16, 2011 | Televison & Video
Picture Size
Keep in mind that not all programs and show are in widescreen format. When set to normal, you will get those black bars on the sides because the program is sized for the older TV's. Some TV's will have a zoom option, but that will cut off some of the top and the bottom of your picture.
Until everything goes widescreen, you are stuck in normal with those black bars or widescreen with the fat people.
I hate distortion in my TV image, so I am perfectly fine with my TV on normal.
Good luck.
Jul 14, 2010 | Philips Magnavox 42MF521D/37 Television
Bought a 19inch LCD Insignia TV yesterday at Best Buy. Everthing works fine except the picture won't fill out the whole screen. Can't find anything in the menu to adjust this.
On you remote control or panel buttons press the menu button. Using you on screen menu, use the up and down arrows to find the Settings Function, use right arrow to enter sub-menu. Use the up and down arrows to find the aspect ratio setting. Use the right arrow to enter the sub-menu.From here you can change the picture setting to : Normal wide 1: Wide 2 : Zoom: Cinema. Once you found your preferred viewing picture, set you choice with the enter button. Then use the menu or escape buttons to close the on screen menu. I hope this helps you with your problem.
May 15, 2009 | Insignia LCDTV26 26 in. Television
Picture in wrong position, too big for screen
Hi
maybe the system settings is not set in default mode
Thanks!
Mar 05, 2009 | JVC AV27F476 27" TV
I just got an xbox 360 for christmas and I play it on my Apex PF 2725 tv. I have it connected to the first Video component with the red white and yellow cords (its set to TV and not HDTV) On all of my...
orite if you have a HDTV plug in all leads apart from yellow 1, but if its normal tv just insert the white, red, yellow. : ), i aint an expert yet
Jan 15, 2009 | Apex Digital PF2725 27" TV
Ilo tv stuck in widescreen
LOOK EITHER ON YOUR REMOTE FOR ASPECT OR IN YOUR ON SCREEN MENU FOR THE PICTURE SIZE OR ASPECT RATIO FUNCTION TO ADJUST IT BACK TO THE SIZE YOU REQUIRE.
Oct 22, 2008 | Televison & Video
CT-F683 TV fault
Press setup on your foxtel remote, go to systems settings, and look for "TV Type" menu, you can change settings there, your TV is a 4.3 (square) not widescreen. Its not a telly problem your just giving it the wrong signal.
Feb 17, 2008 | Televison & Video
Aiwa TVSE 141k,
Try Unplugging For 15 Mins,Then Plug Back in ,See if that takes Care of it,If Not Go to Menu and Run a Scan to Rereckonise Everything....
Jul 19, 2007 | Aiwa S1311 13" TV
Black bars on top and bottom of screen
It sounds as if you have accidentally entered widescreen mode. Explore the on screen menu to find the widescreen option & switch it back.
Jul 15, 2007 | Mitsubishi CS-35405 TV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
