Question about Dishwashers
How do you change out part #918458 door guides on AM15
Hobart am15 scrolls message drain and de-lime with a constant beeping??
It may have reached the number of cycles to trigger a delime warning. Either follow the procedure in your operator manual to delime, or go into the control board settings and either change or turn off the delime timer
Dec 04, 2013 | Hobart 29 in. AM15-1 Free-Standing...
Can i use a tankless hw heater to supply my hobart am15 dishmachine
Don't install tankless, because repairs, installation, operation, maintenance, replacement etc are expensive.
And the thing can be unreliable since you are connecting a computer chip and sensors to gas line, water line, electric line, and to a gas burner with vent to outdoors ... and each of these systems has problems on its own without a computer chip that can fail at the first electrical surge.
Otherwise call Rinni for specs.
1-800-621-9419
Ask about the 4 year warranty for residential installation.
Ask about deliming each year.
Ask about exposure to hard water, and water impurities, and water problems. Tankless cannot be exposed to more than 11 grains hardness.
Ask about recommended yearly maintenance requirement.
Ask why there are no service manuals, and how technicians know how to fix the thing without detailed service manuals.
Call around locally and see who services the thing, and ask if there are service problems.
Apr 07, 2013 | Hobart Commercial Equipment Ventless Dish...
Door of our brand new to us, AM 15 is jammed closed, staff called me How do we open ,
This not something that can be fixed by the home mechanic, you need to see the GM dealer for this repair, it is very involved and requires special tools an skills.
Mar 09, 2011 | Hobart AM15-2 Dishwasher
How do you drain Hobart am15?
With the door lifted up, there is a lever on the rear-right on the inside of the dishwasher. Lift this lever and the machine should drain. If it doesn't drain with the lever up, remove the screens inside the dishwasher and verify that the lever is, in fact, lifting the overflow tube so that water can drain out the bottom.
Nov 30, 2010 | Hobart AM15-5 Dishwasher
My dishwasher is not filling up water to start the washing cycle when the door is closed
Asuming you have an AM15, Check you have power to the fill valve during fill cycle. Make sure your drain is closed to retain the fill water. You should have 20 psi flow rate.
Jul 19, 2009 | Hobart 29 in. AM15-1 Free-Standing...
No rinse cycle
If it is new, would you not call Hobart for a warranty call? 1-800-444-4764 to reach the nearest branch in Canada.
Seeing it's new it is most probably not programmed correctly. On the control board is factory jumper J5, short thse two pins and press ON on keyboard. when the display shows ty remove short. pressing select on the CB will change the options, pressing up arrow will incriment the change options. first setting is machine type= AS,second is id, hot/cold or plain AM15 only, select H,C,or P.
3rd is tc,auto temp control. The rest will not affect your condition. Press OFF on keyboard to save and exit.
Jul 03, 2009 | Hobart 29 in. AM15-1 Free-Standing...
HOBART AM15 DISH WASHER ERROR(E1)
After checking the service manual, I find no code for E1. There is a P1, or other E codes. Please list ML number.
Jun 14, 2009 | Hobart 29 in. AM15-1 Free-Standing...
What is p3 code on hobart am15 dishwasher
It means that the final rinse thermistor is bad.Your not getting 180 degrees---right?Its located on the booster and costs about $65.I work for hobart.Any ?
Jan 08, 2009 | Hobart 29 in. AM15-1 Free-Standing...
Am model Hobart dishwasher
Yes. Most of the AM models have a magnet on the RH door, and a corrospnding reed switch on the jam. Sometimes the magnet fractures in the casing and weakens its strength. Otherwise it is likely the reed switch.
On the more recent AMs, it you open the control box and there is a green board on the inside of the door. There will be an LED to show when the door is closed. Look towards the bottom right of the board.
Mike
Apr 23, 2008 | Hobart 29 in. AM15-1 Free-Standing...
Dishwashers Logo
32 people viewed this question
Top Dishwashers Experts
