Question about Sony Audio Players & Recorders
Can a eq work with a sony receiver 2 channel receiver sony model str-dh130 the eq is harmon /kardon model eq8 s
What eqalizer model do you need to function with a sony 2channel receiver modelstr-dh130?
3 Suggested Answers
emissionwiz
  • 78257 Answers
SOURCE: can you use a eq tape deck ,cd with a sony receiver model str-dh130
I don't see why not.
Posted on Nov 24, 2016
How do I adjust the treble and bass on sony str-dh520?
See EQ Mode on page 59 of the owners manual to set the bass and treble for the front speakers, presumably for 2 channel mode. For multi-channel mode there are several pre-programmed audio modes listed starting on page 43 and music mode starting on page 44.
https://docs.sony.com/release/STRDH520.pdf
Mar 02, 2015 | Sony STR-DH520 A/V Receiver
I Bought a Sony STR-DH130 2-Channel Hi-Fi Receiver and a AudioSource EQ 200 Graphic Equalizer. I connected them and the equalizer does not make a difference nor does it change the sound, can someone
Well i have a equalizer, some times and just(studio gear) the output from my mixer connected to my equalizer and that output to the monitors., It might be a wrong connection orrrr have you put the equalizer on the receiver input signal, that signal has to be the right impedance and your receiver will propably make the signal linair, so that,s useless
Oct 05, 2014 | Audio Players & Recorders
My Pioneer VSX-D902S receiver will not turn on.
the receiver pioneer vsx - d902s has in the display lights are LED. ? and that screen will wear over time and stop working .. ? like the large volume potentiometer . ?I have wanted to purchase the sony receiver str.dh130 to renew the pioneer..que reviewers. ? although it is 100 watts and 125 watts pioneer
Aug 14, 2011 | Audio Players & Recorders
HOW CAN I HOOK UP CAVILIER 200A POWER AMP TO A sony str av 770x f
You can pull the Left and Right stereo program from either MD/Tape or Video 2 Audio OUTputs. Run a pair of RCA cables to the Active EQ's Line IN; then the EQ's Line OUT to the Cavalier's Line IN.
If the Tape output you're borrowing the program from is already connected to something, use RCA-cable splitters.
Remember to NEVER activate the monitor for that Tape function during playback of any digital audio source - it disables the digital input; or if the 901's are being used - it will remove the signal to the Cavalier.
Now if you wanted to use the 901's in your movie listening this will work with two limitations
Your receiver doesn't have preamp outputs for Front Left and Right out so you'd be extracting only the mixed-down 2-channel version of whatever the Sony is processing.
You'll have to manually control the Cavalier's volume because the pre-out you're using is BEFORE the Sony's volume control.
It might still be an improvement over what you have now.
Mar 21, 2010 | Sony STR-DE675 Receiver
The volume doesn't turn up on my sony
on my harmon kardon there are 2 RCA pre-amp ports. if you're not using an external amp then you need 2 really short RCA cables to connect the pre-amp ports to the RCA 'in' ports next to them. In essence the built-in amp isn't hooked up from the factory-you need to 'jump' it with 2 RCA cables. and no, my $350 harmon receiver didn't come with those little jumpers but it did come with a pair of 3 foot RCA cables that I had to ravel up with a twist tie to keep out of the way of all my other wires. hope this is similar to your issue. also make sure the speaker buttons are selected appropriately. just take some time to read EVERY label on the back of your receiver-there's a lot to read in the owner's manual and there may be something you simply overlooked or forgot about.
Mar 14, 2010 | Sony STR-DE945 Receiver
SEQ-711 connection to sony STR D350Z
You can use the VCR audio connections for a stereo analog processor
Many people want to use an EQ with their modern multi-channel Digital Sound Processing gear but at best an analog 2-channel EQ (or any other processor) will only work with analog stereo sources. On most receivers, simply selecting the Tape Monitor disables all digital inputs. However, most DSP can still be employed with analog source material and a 2-channel processor with varying degrees of aesthetic pleasantness. Beauty is indeed in the ear of the beholder.
If that works for you, go for it. I do it, but I fully understand the limitations.
Mar 15, 2009 | Sony SEQ-711 Home Equalizer
16 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
