Question about Vacuums
The bottom of the bin on my dc07 opens as soon as I remove the bin from the vacuum causing any debris to immediately fall. Do I need a new seal or a new bin bottom
    Habit-Forming:
    New Friend:
  • 108 Answers
Actally u need a new release mechanism. Theres a rod runs down inside of bin assy.and a clip at bottom to lock.a new top part is an alternative if u can find a broken one from a local tip or recyling centre.theyre quite commonly skipped so a new part shouldnt be hard to find
Posted on Apr 18, 2017
Dyson dc07 clear dust bin will not close after emptying. Any time the bin is removed, the dirt falls out.
There is a lever that has a hook on the end that holds the door in the bottom of the dirt cup closed. If the little plastic hook gets broken the trap door will not stay closed by itself. The easiest way to fix this is to purchase a new dust bin. I have a bunch of them in my vacuum graveyard. You may call my store at 260 244-4696.
Apr 05, 2016 | Dyson Vacuums
Dyson DC07 bin falls open
you can replace the lid
Oct 28, 2012 | Vacuums
How ldo I open the Dyson DC07 bin to clean the mess out
Empty the bin in the usual way. Leaving the bottom door open, raise the small catch on the front of the bin, towards the top. Pull the front of the bin down when this catch is held open and the clear bin will disengage from the top lug at the back. The whole clear outer bin them can be removed dowards to enable the cyclonic air wholes to be totally cleaned.
This is for the DC07 all floors but I asume all DC07s to be the same.
John
Aug 02, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
MY DYSON 07 EMPTYS DIRT AND DEBRIS AS SOON AS I TAKE THE CYLINDER OFF. SEEMS THE LEVER IS BROKEN THAT RELEASES DIRT. CAN I PURCHASE THIS LEVER?
Hi its Darran at Dyson.
The trigger mechanism which stops the bin base coming open is part of the cyclone top. this part can be purchased via our website at www.dyson.com.
Kind regards
Darran
Dyson Customer Service
Mar 28, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do i empty my dyson dc07
Remove the bin and cyclone assembyl by pressing the release button above the word Dyson on the carrying handle towards the machine.
Then hold the bin and cyclone assembly over a dustbin and pull the trigger located underneath the carrying handle which will release the bin base to empty the dust and debris from the bin.
I hope this information is useful to you and should you need any further help or advice, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Feb 25, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
On the DC07, the entire cyclone assembly must be removed to empty the dust, debris, etc. collected when vacuuming. On the top of the cyclone is a "trigger" that you lift with your finger to release the...
Beofre you go to the extent of buying a replacement canister, you can remove the top and using a straightened coat hanger type thing open that bottom lid. Then maybe you can clean the rim and possibly add some silicone spry to loosen things up. Here's how to get inside In this order: 1) Remove the canister 2) remove the three star screws at the top of the canister. It'll take a bit of pressure to pull the top up, there's a rubber seal. When you pull it up there will be a rod running down into the canister, leave it be, just pull up the top high enough to clear out any debris. 3) Use a straightened coat hanger and with a flashlight to guide you, reach down with it and push it into that hole down at the bottom center of the canister. That will pop the lid open. Clean the canister & lid rims, maybe add some silicone. At this point you might as well clean the canister too. OPTIONAL-> ***leave the bottom lid open*** and follow the rest of these steps 4) Put the top back on aligning the screws, when you lower it make sure the bottom of the rod engages with the hole at the bottom center of the canister, this is why you left the bottom lid open. Put the three star screws back in. 4) Turn the canister upside down, lid open, and keeping in mind this is thin plastic, gently tug upwards on the four fins that surround the bottom rubber seal. This part is held in by friction, so work your way around the four fins gently pulling until you work the ring they're connected to free. This will give you access to the inside of the canister. 5) remove the round perforated section by tugging upwards on it, set it aside with the fin part. 6) Take the canister to a laundry tub or large sink and holding it bottom up fill it with hot/warm water. Grasping the center section shake it vigorously and turn it upside down while shaking and a bunch of sh*t will come out. Repeat several times. 7) Dry thoroughly, you might use a hairdryer held to the center tube, but only if you can switch off the heat and use air only. Make sure its 200% dry, water will kill your machine 8) clean and replace the round perforated section 9) replace the fin section, I'd suggest pulling the round rubber part off of the fin part and setting it in place on the canister first, then follow with the plastic fin part. If you don't do it this way the rubber won't seat properly and the bottom lid won't close. 10) Close the lid, replace the canister, and staaaaaart suckin like it's brand new.
Jan 10, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Replacing the hepa filter
The cover for the HEPA filter is located immediately beneath the clear bin, and is exposed when you remove the bin. Removing the filter cover without breaking something can be a bit of a challenge, but if you look carefully you will see how it fits on, and then, with care, you can lever it off. Then the filter just lifts out. Don't worry if you do break the cover - the cost of a new one is nothing compared with the filter itself. You will need to buy a new adhesive seal too, as the old one will be stuck to the old filter.
Dec 31, 2009 | Dyson DC07i Bagless Upright Vacuum
Dyson DC07 Clear Bin Flap will not release
I just received my replacement root cyclone in the mail today after waiting in the back-ordered status for three months. I positioned a butter knife in between the rubber gasket on the bottom flap lid and the bottom rim of the clear bin at the farthest point from the hinge and slowly and gently wiggled the knife between until the bottom flap just fell open. I examined the rubber gasket and it survived without injury and the bottom flap seals without any gaps...good luck
Jun 07, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bottom of dirt container doesn't stay closed
The catch/latch that is on the bottom of the bin button release has likely broken.
If you take out the canister (as when you are dumping the bin), and flip it upside down and then squeeze the bin release button, you will see that it moves a rod inside the cyclone assembly.  At the end of this rod is a plastic (plastic.. redundant, as the entire Dyson is practically plastic) latch that catches onto the bin's lid and locks it in place.  A broken latch means it doesn't lock the lid in.
What you need is a replacement latch.  Note that the "Bin Release Button + Rod assembly" that are sometimes sold on ebay do *not* contain the latch at the end of the rod.  Also the bottom bin assembly does not contain the required parts.
The cyclone assembly should have the full bin release rod + latch, so if you can't find the latch, then a new cyclone assembly would work also (but will cost more, obviously).
Oct 09, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
