Question about Maytag Dryers
I have a Maytag MED9600SQ0. I cleaned the lint hose and screen. Can I clean the lint screen housing. My sons chapstick went thru the dryer and i can feel a residue and I also use dryer sheets.
dididsaythat
  • 291 Answers
SOURCE: Maytag Dryer not working properly after cleaning lint trap.
where does the noise sound like its coming from??
Posted on Oct 08, 2007
  • 65 Answers
SOURCE: Remove front of dryer to clean lint from interior
open door remove eight screws, four on plastic guides and same location on hinges. wiggle door and it will remove . now grab narrow ends of front panel and pull toward you. wwhen panel gets to 45 degrees pull off tabs at bottom.
Posted on Feb 16, 2008
SolutionGuy
  • 331 Answers
SOURCE: How do I remove the lint housing of Maytag Neptune dryer
Hi Kate,
Gaining access to the lint housing sounds more difficult than it is. As a matter of fact, I could get to it and have it back together in the time it takes me to type out the instructions!
Tools needed;
1.) Phillips screwdriver
2.) 5/16" nut driver or socket
UNPLUG THE DRYER FIRST!!! Or risk a funky new hair-do...
Open the door and remove the four screws at the hinges then remove the door. Opposite the hinges, you'll see 4 more screws, remove these too. Now grasp the front panel on both sides near the top and pull it toward you. Lean it out to about a 45 degree angle and lift it off the clips that are holding it (at the bottom).
Now you'll see the lint trap housing. Look around the housing, you'll probably see a yellow wire near the 5 o'clock position, remove it. Now, on either side, you'll see four 5/16" screws... Don't remove the top ones, just remove the three below the top ones. You can now pull the entire panel off of the frame for cleaning.
Rebuild in the reverse order (and don't forget to re-connect that yellow wire!)
There ya go! Please don't forget to rate this as "FixYa", OK
SG
Posted on Apr 11, 2009
57 varieties
  • 1653 Answers
SOURCE: Samsung dryer DV448AEP/XAA - lint buildup
Yes this is rellatively normal as clothes are just not made the same way any more. You could turn down the drying temperature slightly and put in an anti static drying sheet but it won't make that much difference.
Posted on Oct 13, 2009
Testimonial: "I just had a repairman out because the dryer was no longer heating. The whole inside of the dryer was full of lint. It was awful. "
  • 245 Answers
SOURCE: My Maytag washing machine leaves residue (lint? soap?) on clothes
us liqwid soap us les chang filter.to meny close can trap the dry stuf.
Posted on Jan 25, 2010
Maytag dryer isn't drying well
This is a common problem when you fail to clean the lint screen. There is also the possibility that you vent is plugged up, to confirm this is your problem just remove the hose from the back of the dryer if your drying time goes down (gets faster) then you will need to clean the tubing going from the dryer to the outside of your house. This is a common problem in apartments. If this fails to resolve you problem you may have a weak operating or high limit thermostat. Hope this helps.
Feb 22, 2015 | Maytag Dryers
The dryer shut off mid-cycle. It smelled overheated.
Hi
Your thermostat is shutting you off on mid-cycle because your overheating the dryer...
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
Make sure your lint screen is in place and has no tears or holes in it and is still firmly attached to the frame.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Please take time to rate me thumbs up.
Sep 18, 2011 | Maytag PYE2300AY Electric Dryer
When I run the dryer it smells very hot inside. I took the front off and vacuumed out everything I could.
Hi melissa h709...
Please take time to rate me.
Sep 17, 2011 | Maytag MDE9206 Dryer
After about 10 minutes the dryer becomes too hot. the top and the door become really too hot
Hi senecalginet
Aug 30, 2011 | Maytag Dryers
My neptune dryer seems to be overheating. It's very hot to touch the outside unit and is heating up my laundry room. The vents are attached and the lint screen is clean. What is the problem?
Hi twokids90s
Aug 20, 2011 | Maytag Dryers
Cleaning lint that gets past the screen???
synthetic screens are much finer to use although hard to clean.. I use a panty hose stocking on mine which works well. also they are disposable
Feb 25, 2010 | Dryers
My maytag dryer runs and there is some heat ,but clothes take hours to dry
Check dryer exhaust force at outlet. The exhaust should exert strong pressure against your hand. If not clean or replace vent system.
Dryer lint screen may be clogged with lint or finely pulverized detergent residue.
Another possibility is that the operating thermostats may be out of tolerance.
Hope this helps.
Aug 24, 2009 | Dryers
Dryer lint throughout the house
i think the dryer vent hose on the back is clogged or has come off,check that and let me know-mike
Feb 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer Lint Trap Not Catchin Lint
If you have the ability to move your dryer away from the wall and look at the hose located at the bottom of the unit.
1. Take the house off it might be clogged 2. check for ang gaping holes in the lint screen
Jan 19, 2009 | Maytag Performa PAV3200
Kenmore 110.72512101 gas dryer
Are you getting little or no lint on the lint screen? Are the clothes coming out nearly as wet as they went in, but feel warm? If so, you probably have a blockage somewhere in the vent/duct. Don't just check the back of the dryer, but also check the duct thru the wall and the point where it exits the house (exterior wall or roof). Many times birds will nest in the exterior vents or if they have a screen to keep the birds out it may become clogged with lint. If you have a window nearby try drying a load with the vent hose disconnected from the wall and hang it out the window (you COULD vent it into the house, but you may end up with lint everywhere and a lot of moisture in your house).
Jan 02, 2008 | Kenmore 75944 Gas Dryer
Dryers Logo
56 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
