Question about Microwave Ovens
Kitchen aid microwave khms2050SSS-0 keeps beeping and panel is blank
MicrowaveSvc
  • 9098 Answers
SOURCE: Kitchen aid microwave oven not working.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I'd say you have a contaminated or failing keypad or possibly residue on the boar dor where the keypad connects to the board.
Is it possible that some spray cleaner got into the controls?
I always recommend that users instead spray cleaner on a soft cloth then wipe the control panel.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 26, 2007
  • 338 Answers
SOURCE: KITCHEN AID KCMS145JSS 0 THE
bad control panel.. all power is routed through the control panel.. if your having a problem like that i would replace the control..
Posted on Jan 17, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: How do you replace the fuse in a microwave oven.
Be sure the oven is unplugged or the breaker is off.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Let us know if we can help further.
Posted on Jun 06, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave turns on & control panel is frozen. F2&PAN error codes
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number (KHMS155LWH1 without dashes) from the tag on the oven here.
Posted on Jun 11, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Burned out bulb on Kitchen Aid Microwave Model KBMC140
You will need to remove the oven from the wall and remove the outer cover.
If for some reason you don't have yours, you can download your owner's manual and installation instructions free from this page.
These models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
You should be able to get one from a home center or local appliance parts store.
If you order it online (from the link above) it is part # 4375348.
Posted on Aug 04, 2009
Error Code F9.Q (Touch Communication).
KitchenAid Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Kitchen-Aid-Appliance-Fault-Codes.aspx
Fault codes for a number of KitchenAid appliances, including two and four digit codesfor ... F9 - Oven Door Lock Failure - Check door lock switches and wiring.
Jul 27, 2015 | KitchenAid KHMS2050SSS Microwave Oven
Error code F2
Per the tech sheets (page 8), "F2" error code means "Keyboard failure". Recommended by the manufacturer to replace the touch panel first and, if it would not solve the problem, then the control board has to be replaced too. Not the best recommendation but we have to follow it.
- The part number for the touch panel (aka a membrane switch) is AP3130765
- The part number for the control board AP3130764
Here are the break down diagrams for the Kitchen Aid microwave Model KHMS155LSS4
Gene.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Read more: http://forum.appliancepartspros.com/microwave-repair/19054-kitchen-aid-microwave-error-code-f2.html#ixzz3bRus7JKM
May 28, 2015 | Microwave Ovens
How do you replace the fuse for model KHMS2050SSS KitchenAid microwave?
my microwave did not have a fuse. are you sure it is not a switch?
Oct 10, 2014 | KitchenAid KHMS2050SSS Microwave Oven
My microwave seems to have a mind of its own it keeps wanting me to reset date and keeps beeping for no reason at random times
Most likely it's an electronic failure of the main circuit board. Although extremely unlikely, I have seen an oven or two that have had these symptoms that were caused by an insect walking on the back of the circuit board.
Apr 29, 2014 | KitchenAid KHMS2050SSS Microwave Oven
Need to replace door handle for Kitchenaid over-the-range microwave, Model: KHMS2050SSS - 0
You usually get better search results by leaving off any dashes or spaces in a model number.
Normally you have to separate the door panels (as shown in the photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful literature and exploded view diagrams with part numbers here and you can order parts from the Pros here.
May 21, 2013 | Microwave Ovens
Kitchen aid micro wave change fuse
Unplug, remove top, look under keypad, follow wires to circuit board, look for a silver rectangular capacitor, "may be under a plastic flap" discharge capacitor with a screwdriver across the 2 points, look for a small fuse near by in clips, remove and replace with same current rating, assemble before test because lethal voltages present when powered.
Mar 11, 2012 | KitchenAid KHMS2050SSS Microwave Oven
My kitchen aid over the range microwave Model No; KHMS105EWH-0 stop heating.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 03, 2011 | KitchenAid Microwave Ovens
Microwave panel and lights work but the fans do not and nothing is heating
Basic
heatman101
Jan 29, 2011 | KitchenAid KHMS2050SSS Microwave Oven
Kitchen aid microwave KHMS155LBL2 showing up locked and then showing F2. It keeps beeping. Now it won't let you do anything.
first is it under warrenty? if so take back. if not and you want to fix it yourself: how much did u pay. less than $200. maybe trow it away and buy new one. if u paid more and r fixing it yourself, then unplug it from the wall, wait 60 seconds or more then plug in, check display only. do this and respond for more help.
Aug 20, 2009 | KitchenAid KHMS155L Microwave Oven
Microwave Ovens Logo
73 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
