I'M GETTING AN ERROR CODE OF 5F ON START UP. NO DESCRIPTION. CAN'T SEEM TO FIND WHAT IT MEANS.
What does error code P173B on an Audi A3 mean
OBD II trouble code description Clutch actuator position circuit low.
May 27, 2014 | Cars & Trucks
How to fix c2 error code on 5400
1) For Rheem tankless water heater, C2 11 is usually means bad circuit board.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
2) What is a 5400?
Is this a water heater?
What brand water heater. What type.
Is this gas or electric.
New installation, or older installation that started having problems.
Has required yearly maintenance been done?
Is the unit rated for correct altitude?
Has the water temperature been increased?
3) Add comment and include description of product, and best description of problem for possible assistance.
4) Call service technician.
Dec 30, 2012 | Water Heaters
I could not start my PC, a Dell Dimension E510. I got the message " Loading PBR for description 2 ...done
This is an error code that means Problem Booting Response hold down your Ctrl+Alt+Delete and see if it does not reset the boot series. it means a corrupt boot code you can try and use F2 to try to get into Bios and then f12 to get to the hard drive reboot option.
Jun 07, 2012 | Dell DimensionTM E520 PC Desktop
My 95' geo all the sudden yesterday just went to sputtering and as soon as it did the check engine light came on. I can't seem to figure it out. Its been running great and is kept serviced. Any ideas?
It means that the car has detected some problem in any of the part of your car and its details is stored in your cars computer by means of error code . You can scan your cars computer and get the error code . The code will let you know which part is faulty and needs to replaced or serviced.
Most auto zone shops does the scanning for free .
From your description i can sense that the problem is with the fuel system. Either a bad fuel filter which needs to be replaced or fuel pressure is not at the specified level.
Feb 15, 2011 | 1995 Geo Prizm
Error code OE. What does it mean? washer seems to be having a hard time draining the water
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Please check the above link for a detailed picture wise explanation for the error code.
May 17, 2010 | LG WM-1832C Front Load Washer
ERROR MESSAGE 5F
This fault concerns the relay drive circuit. If this fault code cannot be canceled, replace the oven control (also called clock or ERC).
Jul 26, 2009 | GE JKP15 Electric Single Oven
The Box Super not working in Dublin
B0 B8 4F 04 E6 5F 87 80
CE 97 58 27 7C 81 EF 28
Jan 18, 2009 | StarTech.com StarView SV211K 2-port KVM...
Codes for ntl dublin
NTL
00=B0 B8 4F 04 E6 5F 87 80
01=A3 EB EC 07 D6 49 D2 EB
Dec 16, 2008 | StarTech.com StarView SV211K 2-port KVM...
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
