Question about Star Computers & Internet
My account Volta's 1.5 ,3 star .My Ac spin working when also power off time..How to close the spin
Air conditioner will not turn on 1994 geo metro
ok , this is easy (dead even at first start?)
we can do this step by step if you want
  1. Does blower blow? (heater fan) no, then fix that first.
  2. Does the A/C button light glow, it must.
  3. Does the compressor spin, A.C on.?
  4. yes, then the freon loop has issues, get help there.
  5. no, bet its this, huh? and is caused by the A./C amp logic module detecting errrors, we check the pins on that model with any volt meter to find true cause. One cause is too much freon.
  6. Engine over heat sensor for A.C bad or wires there grounding out.
  7. Engine overload. ECU can tell A>C to cut out for 2 reasons.
  8. EVAP core freezes up (ice) works at start the fails later?
  9. is the AC accelerator switch closed, if stuck closed there will not be any AC compressor action. (a throttle pedal switch)
  10. Is the yellow wire at Hi/low Freon switch at 12v, if not there will be no A/C due to AC compressor relay dropping out.
  11. if the pink wire on the AC comp relay is 12v then the AMP is not happy, its logic is defeating the AC. to find cause look at the AMP.
  12. AMP pin 12 yel/blk must be 0v or overheated , or this sensor is bad or the wire fell off it. easy huh ,with a voltmeter>?
  13. AMP pin 11, blu/blk. 12volts or AMP shuts you down.
  14. AMP pin 5 has must be 12v, not 0v, and is 2 sensors. the wire color there is green-red. the transaxle cut switch or the throttle cut switch must not be closed and forcing this pin to 0v. yes, use any voltmeter on this pin. unplug each sensor 1 by one to find who is wrong (closed)
  15. Amp Pin 1, blue-red, is power 12vdc power, if not 12v the amp shuts down. (no power no joy)
this is mostly it. i have the schematic, (ask for it)
or read it all online at, like me.
Mar 31, 2014 | 1994 Geo Metro
Ac dont work
you want cold?
the first check is
, is the compression clutch closed (engages) and the actual compressor actaully spinning, (its main shaft , the pulley spins all the time)
Aug 17, 2013 | 1994 Jeep Grand Cherokee
How do i unlock my blue star AC remote
Just change the batteries! The AC remote gets unlocked for me. When I contact the service centre they asked me to pay Rs. 500 for visit and unlock the remote.
Mar 23, 2013 | Cell Phones
Split AC whole unit turnig off at each compressor start up!
Dirty coil wash outside unit with water and change indoor unit filter
Jun 08, 2017 | Heating & Cooling
The screen does not turn on only the green led below turns on then star to blink
This might be cause by lamp error. Here's possible solution. Unplug AC cord for a while.
Then follow process as below. 1, Plug AC cord 2. Press Vol (-) + TV/Video Button at the same time 3. While holding above button, Power On by pressing power button. 4. Either "K" or "K123" will appear on the screen. This indicate that you enter the service menu. 5. The Press Button Vol(-) + Channel Up button to go to menu page. 6. Find Lamp Error page. 7. Lamp error data should be "0" zero, if not change to "0" 8. After changing the data, power OFF by Power button. 9. Unplug and re-plug AC cord 10. Power On to check if power resume.
Good luck Jheremiel
May 16, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
One minute left
be sure water is draining out before spin starts if necessary remove bottom panel and clean pump out and ck hoses to pump be sure there are no excess suds ..wash only full loads small loads or loads with 1 heavy item will cause washer to sense off balance and try to balance load this will extend cycle time
Nov 09, 2008 | Whirlpool GHW9400 Front Load Washer
Spin Cycle doesn't work on our GE Energy Star frontloader, please help
You may have to remove the lower panel and clean the drain pump filter. Easy job, once the panel is removed the filter will be right in front. Get a bucket and unscrew the filter cover (3 very small screws at the bottom of the front panel) and you should find a ton of lint and stuff in there. This model has a pressure switch that detects if there is water in the tub. If so it will do this pause and slow spin. Once the pump filter is clean you should be good again. It worked for me.
Apr 08, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
Mar 24, 2008 | Washing Machines
Won't spin DVD - says OPEN (top right) on TV screen
Just got a coby dvd-207 for free due to this problem, fix takes about 5 minutes.
Tools needed:
1 small philips screwdriver
1 toothpick
1 bottle of rid-ox, deoxit, or similar contact cleaner and restorer
1) remove the two rubber feet on bottom of case that have arrows pointing at them
2) remove 6 screws that have arrows pointing at them
3) carefully open case, there are wires connecting both halves, leave them connected
4) press open button, so that the disc receptacle is open
5) look for a gear on the inside near the back of the case that is connected to the dvd door, there should be a cheap reed switch mounted near it
6) clean the cheap reed switch with a toothpick dipped in rid-ox/deoxit/etc
7) re-assemble, plug it in, and watch movies for another few months until the reed switch decides to stop working again
The next time it goes out, i am just going to cut the two wires to the switch and either cross them over or install a mini-toggle switch on the side of the case..
Nov 04, 2007 | Coby DVD-207 Portable DVD Player
Computers & Internet Logo
23 people viewed this question
Top Star Computers & Internet Experts
Abdul Mannan
Abdul Mannan
Are you a Star Computer and Internet Expert? Answer questions, earn points and help others
