Question about Delta Home
There must be a special washer or gasket - teflon tape was used and it still leeks - if it is a special washer or whatever I would purchase it pr give me the part number Thank you, Ferdinand Ruffino
Per delta 86 in shower hose - it leeks when water is turned on - my neighbor feels there is a black plastic nipple that is required - the one that is there may be defective.
5 Suggested Answers
  • 1937 Answers
SOURCE: plastic hot water hose nipple on the machine is stripped
See the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.92480200
You should be able to see how the connector fits.
Posted on Nov 27, 2009
  • 81 Answers
SOURCE: Hose leaks from back flow preventer holes when
Replace the backflo preventer.
Posted on May 29, 2010
  • 4736 Answers
SOURCE: The hose connection nipple is smaller than the
No, that would probably leak too. What you need to do, is go to your local hardware store or home center (Plumbing Dept) and purchase a female to male connector. The female end is to connect to the unit's male hose connection and the other (Male) end, needs to be the same size for garden hose connection. Make sure that you use an appropriately sized washer for the Female end.
Hope this helped you. Please let me know. Thanks.
Posted on Jun 15, 2011
claudeinmo
  • 9098 Answers
SOURCE: I am about to replace the hoses on my Kenmore dishwasher. should I use teflon tape?
There are different grades of teflon tape, make the right choice.
Posted on Jan 23, 2016
Testimonial: "Are you saying I should use teflon tape?"
Oil leek front differential housing on mitsubishi triton
if brand new never been disassembled it may not have a gasket just a special silicone used in the factory. . If the cover is leaking than you may have to make a gasket out of oil resistant gasket paper (from auto spares shops) and use locktite silicone blue on both sides if the gasket
Jan 01, 2014 | 2001 Isuzu Rodeo
Just installed a vessel sink and it leaks between the vessel and under sink.
Use silicone to seal the flange and teflon tape on the threads that the drain flange screws onto. make sure that the sink isn't cracked. make sure that you have a washer under the rubber gasket that seals the bottom of the sink and tighten the nut against the washer snuggly.
Mar 23, 2011 | Vessel Home
My complaint is about the go diego go toy trike, the screws that hold the handle bars to gather will not stay in ,, the holes are either to big or the screws are to small. do hope to hear answer on this...
1. You can buy a bigger bolt at a hardware store with a nut that fits the bolt and use a washer on both sides of the handle bar. Also, before screwing on the bolt, put teflon tape around the bolt screw where the nut is to go. This should secure the nut from unwinding through use. Make sure the nut is on more than hand tight.
2. If you cannot purchase another bolt, then start with washers and teflon tape. Be sure to tighten the nut more than hand tight using a wrench or pair of pliers.
Mar 07, 2011 | Cycling
How to change gaskets on oil sending unite on 1995 couger
IF OIL SENDING UNIT LEAKING OIL NEED REPLACING.WHEN INSTALLING NEW OIL SENDING UNIT.YOU CAN USE TEFLON PLUMBERS TAPE ON OIL SENDING UNIT THREADS BESURE WHEN INSTALLING NEW OIL SENDING UNIT.PUT TEFLON TAPE JUST A LITTLE ABOVE THE BOTTOM THREADS. SO YOUR OIL SENDING UNIT THREADS GET A GOOD GROUND FROM ENGINE BLOCK.SO IT WILL WORK CORRECTLY.
Feb 21, 2011 | 1995 Mercury Cougar
I've attached the shower head as tightly as I can but water backs up and sprays upward and outward with very little coming out as spray. Seems that a washer is needed but note came with my...
There should bea rubber gasket/washer that goes between threads on shower arm and inside of shower head. If this is a new shower head I would return it to place of purchace for exchange. If not you should be able to get the waher seperatly. If not you can get a cheap shower head and use the gasket from it. I also would recommend that you use several wraps of teflon pipe joint tape on shower arm and tighten snugly.I hop this helps you. Thank you a have a good year
Jan 02, 2011 | Water Pik Shower Head
My brand new 40 gallon water heater is leaking from the top temperature control. it is the first time it has bin filled. i have not had hot water in 3 days. please help.
Shut the water and power off. Connect a garden hose to the drain and open the valve as well as the t&pr valve to allow air flow. Remove the top element and inspect the gasket. It should be round without any wrinkels. Straighten the gasket if nessesary and reinstall the element.
If the water is leaking down from the top of the heater onto the thermostat, use a flashlight to inspect the connections on top of the tank, you may need to remove them and wrap them with teflon tape.
On rare occations, the machine that welds the tanks together will miss a small area. If there is no visable leak comming from any of the tank connections, you will have to tank the water heater back to the store and try another one. this is not what anyone wants to hear, but it does happen from time to time.
You can can the 1-800 number on the tank, but dealing with the store where you purchased the heater will be faster.
Sep 16, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Oil leek around plug on 99 dodge
A replacment pan would be the logical answer,with a new plug and gasket and tighten to the proper torque, as per factory specs.
Mar 06, 2010 | 1999 Dodge Stratus
Pool skimmer has poor suction and I've adjusted valves in various position and it is not functioning properly?
change the gasket on the pump lid. If this doesnt work seal inlet to pump with silicone as a quick fix - or replumb with teflon tape and teflon sealant. If this does not work you could have debris stuck in your impeller. Also check drain plugs to make sure that they are tight (reseal with teflon tape if necessary.
Apr 04, 2009 | Hayward Pool & Spa
Leaky handshower hansgrohe croma c100
Grab a wrench and give it at least a quarter-turn. Hand tight isn't enough with a shower, even with teflon tape.
Mar 28, 2009 | Hansgrohe 04070930 Croma C 100 3-Jet...
Home Logo
32 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
