Question about Craftsman Garden
I have craftsman pressure washer model # 250 752050 It is missing the hose that goes to the cleaner tank to the machine .Can I get this replaced. Can I find a book on this .
SOURCE: Craftsman Pressure Washer
I believe sears will give you one free;
http://www.managemyhome.com/mmh/lis_pdf/OWNM/98070390.pdf
you have to download it, but it isn't too much trouble, page 16 lists a whole laundry list of possible problems. Word of advice, change your oil in the pump regularly, if it is burnt appearing you might want to consider replacing rings etc and complete teardown, we didn't and trashed the pump.
Posted on Mar 01, 2009
  • 27 Answers
SOURCE: Bosch SRS4302GB Replacement Inlet hose - which type?
it should have and is delivered with the narrow bore high pressure hose
if your water flow rate is high more than 20 ltrs p min you could get away with a standard low preessure hose
you can download the instruction manual from the bosch web site or from the bsh home appliances web site
good luck
Posted on Mar 12, 2009
  • 174 Answers
SOURCE: How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Posted on Aug 26, 2009
blueextc3221
  • 15935 Answers
SOURCE: Craftsman 2000 psi, 1.9 gpm pressure washer Manual
The model number is required to get the correct manual.
The Model Number is on the motor tag.
It is in the format XXX . XXXXXX
Where X = a number.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 31, 2009
  • 691 Answers
SOURCE: Craftsman Pressure washer will not spray
your not missing anything, check the pump, they tend to go bad over time and may need replacing. The pump provides the pressure as well as the suction for the whole process, pulling water from the hose or tank and pushing it forcefully through the pressure washer line. If the motor is running and you have the water going through the line and to the pump, and no water is coming out, my guess would be the pump.
Posted on Sep 24, 2009
Why is gas tank leaking?
you either have a hole in tank or a hose is bad, take some silicome and patch
Jan 04, 2016 | Garden
How do i remove gas tank cover?
Hey Chuck
Not sure of the model washer you have but most Briggs tank covers only have 2 bolts on top holding the cover to the tank. If the isnt it can you be more specific with a model number?
Feb 20, 2015 | Craftsman 2700 PSI Briggs Stratton...
Need help, finding a replacement or substitute for craftsman or devilbiss air compressor part # cac-1245
if it is a plastic tube then go to your nearest hose specialist with the tube and he will have tubing and the necessary ferrules, olives and nuts to do the job
Jan 19, 2014 | Cars & Trucks
I had to replace the fuel lines on my Craftsman model 358798940 leaf blower and i'm not sure how they hook up on the carburetor, 1 line runs from the fuel tank fliter to the carburetor and the other...
The fuel hose from the tank with the filter on the end goes to the main fuel inlet on the carb, this is the conection closest to the alloy pump cover held with a single screw, the other conection on the carb has a hose to the short conection on the back of the primer ( the suction side ) the longer conection on the primer ( pressure side ) has a hose back to the tank, this pipe just pushes into the top of the tank, just remember the primer pulls fuel from the carb, into the bulb, and back to the tank, not the other way round.
May 31, 2011 | Garden
My washer does not spray the cleaner solution as high as it did originally. The high pressure spray is fine.
If your pressure washer works like ours, it has a T connection.
A plastic hose comes off the T and goes into the bucket of cleaner
Pressure from the hose creates suction across the T and this draws cleaner into pressure hose
The plastic hose from cleaner connects to a small brass ball valve on the T
The ball valve clogs up or changes over time and cleaner will not draw up into the pressure hose.
We would replace the valve stem
I don't know if they sell the little replacement parts like they used to
Finally we had so much trouble.
We started applying our chemical with a pump-up sprayer.
For us, it was cheaper, and the work went faster.
We put one guy on the pump up sprayer
And then another guy came behind him on the washer.
Oct 25, 2010 | McCulloch FHH18A Electric Pressure Washer
I had a replacement engine installed. is it missing a fuel pump?
check inline fuel filter or hose to long between bottom of tank and carb
Feb 13, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman pressure washer constantly fluctuates and then stops
sounds like fuel problem. Either water\trash at bottom of tank, or most likely, carb needs to be disassembled and bowl and jets sprayed out w\carb cleaner.my money is on the latter.
Jan 29, 2010 | Briggs & Stratton Pressure Washer...
Sep 24, 2009 | Briggs & Stratton Pressure Washer...
Hi,karcher hds hot pressure washer now pressure when you pull trigger and pulses.
what you need to do is, take the screw fitting which goes to the water tank off, then the one that goes from the water tank to the pump head .
then put the one that was in the first place going to the water tank on to the pump and force feed with water.
see if you can see water leaking from any where seals hose.
try running the machine to check the pressure.
if water leaking from pump head you need seals.
Mar 21, 2009 | Karcher Garden
Garden Logo
21 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
