Question about Refrigerators
How do you get the drawers out of the freezer?
Freezer not cold
See if you can
change the thermastat so it also freezws the bottom drawer.
Sep 16, 2013 | Zanussi ZRB834NW (865 cu. ft.) Bottom...
Samsung bottom drawer freezer is leaking and ice is forming along both sides of the drawer?
Is there a drain at the rear for when it defrosts that has become blocked? Defrost fully and clear drain hole
May 20, 2012 | GE Profile Arctica Stainless Steel Top...
The bottom freezer drawer is not closing so the freezer is getting an ice build up
It sounds like you either have a drawer that's off track, or something has fallen behind the drawer, not allowing the drawer to close. Empty the freezer, and pull the drawer all the way out. Look behind the basket of the drawer and see if some thing has fallen behind it. If nothing is behind the drawer, then the drawer must be off track. At this point, you'll need to pull the drawer out to the most extended point. Now push the drawer back in about 3-4 inches an **** it open fairly hard. Not hard enough to move the whole refrigerator. Just enough to put the drawer back on track. Hope this helps. : )
Apr 24, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Is there a way to remove the drawer in the bottom freezer?
Pull the drawer all the way out until it stops. Then lift the front of the freezer drawer (a couple of inches), and pull out further (4-6"). The front will then lower to the floor. Lift the back of the drawer upward and slid the entire drawer forward. You may want to protect your floor. I did the above with the freezer drawer full and scratched my floor a little...
Jun 27, 2010 | Sub-Zero 650 / O Bottom Freezer...
We have the bottom drawer freezer, top french doors, 3 months old, freezer will not shut all the way and now after door open beep has gone off for an hour the whole unit has gone dark
Make sure nothing has fallen behind the freezer drawer or is hitting the top of the freezer to prevent it from closing. Also check that the tilt open front is in the closed position. If nothing is blocking the drawer the gear wheels that support it may not be in the right position. See Owners Manual for instructions about removing/reinstalling the drawer. When you get the drawer to close you may have to unplug the power cord for 30+ seconds to get the unit to reset and restart.
Aug 11, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Bosch Refrigerator ice forming in vegetable drawer
Emptied drawers and cleared the drain hole. Drawers were then refilled BUT MADE SURE THAT THEY WERE NOT OVERLOADED
Jul 28, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Freezer door will not shut whilst drawers are in
Do you have an icemaker?  Be sure the ice maker drawer is in all the way.  This means pulling out the drawer and being sure the gears are lined up properly with the crank located in the back of the freezer.  If they are misaligned the drawer sticks out 1/2 inch (even though it feels firmly seated when you push on it) and the result is a freezer door that will not stay shut.  Believe me, this is experience talking.
Jun 25, 2009 | Hotpoint FFS70 Bottom Freezer Refrigerator
Removed bottom freezer drawer while moving & can't get back in
Try picking up the drawer and tilt it up as your putting it in,push it far enough and the wheels or what have you will drop in.Or try the opposite.
Len
Feb 19, 2009 | Amana ARB2557CSR / ARB2557CSL Bottom...
Removing freezer drawer
my son fixed it - thx. problem solved
Nov 23, 2008 | Pds GE Profile Bottom-Freezer Drawer...
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
