Question about Sony Audio Players & Recorders
Can a eq be used with a sony receiver str-dh130 show drawing how to hook up the rca jacks
2 Suggested Answers
emissionwiz
  • 77544 Answers
SOURCE: can you use a eq tape deck ,cd with a sony receiver model str-dh130
I don't see why not.
Posted on Nov 24, 2016
How do I connect Pioneer equalizer SG9500 to a Sony STR-K740P and Sony CD DVP NC600?
Equalizers can be hooked up two stereos a few different ways. If your receiver or amplifier has what's called a processor loop that is where you would connect the output of the processor to the input of the DEQ and then the output of the processor loop to the input of the Eq. This would be visible on the back as for RCA jacks either with a selector switch above to determine whether you want to use the loop or not or jumpers that go from one of the RCA's into the other input to output for when you're not using that loop. The other way would be to connect it to the input and output for a cassette deck you would hook it up the same way however that would depend on whether your receiver has a separate tape monitor button. If your receiver let's say is In FM mode and you press tape and it still shows FM on but an indicator for tape Mon comes on as well then it will work OK. But, if you must switch off of FM to put on the tape Mon. You prob won't be able to use an eq with that receiver. Then your only other option would be to put the eq between a source such as CD....etc and the input for that source barring phono.
Aug 16, 2015 | Sony Audio Players & Recorders
I Bought a Sony STR-DH130 2-Channel Hi-Fi Receiver and a AudioSource EQ 200 Graphic Equalizer. I connected them and the equalizer does not make a difference nor does it change the sound, can someone
Well i have a equalizer, some times and just(studio gear) the output from my mixer connected to my equalizer and that output to the monitors., It might be a wrong connection orrrr have you put the equalizer on the receiver input signal, that signal has to be the right impedance and your receiver will propably make the signal linair, so that,s useless
Oct 05, 2014 | Audio Players & Recorders
How to hook up external equalizer to Sony STR-DA 2000 ES. Equalizer is a Denon
you need a empty in/out tape slot (jacks in back of Sony, if tape deck is connected you can use "Y" connectors) connect jacks to EQ tape in & out.... (press EQ button Bypass)
Nov 13, 2010 | Sony STR-DA2000ES Receiver
HOW CAN I HOOK UP CAVILIER 200A POWER AMP TO A sony str av 770x f
You can pull the Left and Right stereo program from either MD/Tape or Video 2 Audio OUTputs. Run a pair of RCA cables to the Active EQ's Line IN; then the EQ's Line OUT to the Cavalier's Line IN.
If the Tape output you're borrowing the program from is already connected to something, use RCA-cable splitters.
Remember to NEVER activate the monitor for that Tape function during playback of any digital audio source - it disables the digital input; or if the 901's are being used - it will remove the signal to the Cavalier.
Now if you wanted to use the 901's in your movie listening this will work with two limitations
Your receiver doesn't have preamp outputs for Front Left and Right out so you'd be extracting only the mixed-down 2-channel version of whatever the Sony is processing.
You'll have to manually control the Cavalier's volume because the pre-out you're using is BEFORE the Sony's volume control.
It might still be an improvement over what you have now.
Mar 21, 2010 | Sony STR-DE675 Receiver
Ca I hook up mt MP3 to mt STR DE825 receiver? If
yes either buy the sony dock for mp3's or go to Radio shack and buy the adapter that goes from a headphone jack to a red/white RCA plug get the gold tipped version and just use an open interface on the back phono, tape, whatever you have open.
Nov 25, 2009 | Sony Audio Players & Recorders
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
EQ hookup????
Yes I do! I hade the same problem so went to radio shack and got tow Y -RCA splitters with one male and tow female works great!!
Dec 23, 2008 | Sony STR-DE545 Receiver
Equalizer connections
Usually you hook your equalizer between the pre out and main in RCA jacks and then open the connection between the pre and main with a switch. If your unit doesn't have pre out/ main in jacks then I have seen it done by putting your equalizer between the tape in and tape out jacks and then select that tape function on your front panel. The tape out goes to eq. in and the eq. out goes to tape in. Good luck.
Jul 25, 2008 | Sony STR-DE485 Receiver
55 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
