Question about Watches
I booked wrong date for a hotel just now
Itinery number is 283191909 I'd like to change date by one day for hotel stay
3 Suggested Answers
  • 61 Answers
SOURCE: setting day and date
To sync the correct 12 hour with your day you need to set the date to the day before (if today is Wed 21, then make sure the day window reads Tues 20). Then spin the analog hands until the the date window turns to Wed 21. At this point your watch is reading 12 AM (midnight). Then keep turning to set the correct time. If it is 9 am then stop the hands the first time you hit the 9 marker. If it is 9pm, then keep turning until the SECOND TIME your hour hand meets the 9 marker. This is now set for 9 pm. The day (Mon thru Sun) sometimes needs to be set seperately from the day; it may take a couple of tries but use the directions above and patience and you will achieve your goal.
That's how you do it. If you need more clarification let me know.
Posted on Oct 21, 2009
  • 4 Answers
SOURCE: Day/Date change
The date on mechanical and automatic watches change normally between 2-4am because this is normally when people sleep. It is not broken or in need of overhaul. It has to change sometime and that is what they have tradionally used as a time for the date to change. Also remember it is normal for an automatic or mechanical watch to loose or gain time friction is the culprit here since the gears do mesh with each other.
Fine watches like Rolex and Omega are beautiful watches but expensive to have cleaned. It should be cleaned about every 10 years or if it starts to loose a lot of time.
Incidently most agree that the Omega speedmaster manual wind (The watch that went to the Moon) is the most accurate of the bunch and is very sought after by collectors!
Posted on May 02, 2010
Testimonial: "Thankyou! This has appeased me!"
Problem with day/date changes! My casio edifice
follow these instructions off the manual below if you set the watch in wrong sequens it wont change at 12 oclock
http://support.casio.com/en/manual/009/qw5125.pdfhttp://support.casio.com/en/manual/009/qw5125.pdf
Sep 27, 2013 | Watches
Date is wrong on neff watch
Keep pressing mode until you get to where you get to edit the time and press the "light" button until there's a big number and that's the month and keep pressing the light button and you can edit the date and what day it is
Dec 16, 2012 | Neff Flava Watch Watches
Cannot advance date manually when crown is in 1st position on eco citizen ladies watch
Return for warranty repair. They have a 5 year warranty. Your instruction book has details and address to send it in. Send a copy of your receipt also.
Oct 08, 2012 | Watches
I have an eco drive and recently in trying to set the clock back to regular time, I must have done something wrong. The time is correct but the date, and day are one day forward. How do I correct this?
the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
example: you want to change it to sat 12th 11am
set the day and date to fri 11th
then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
Dec 13, 2010 | Citizen Eco-Drive watch
Hi, I just purchased an Invicta 4718 watch, and although I have the date set correctly, the DAY is wrong. Does anyone know how to change the day?
Pull crown out 1/2 way to fist click. Rotate one direction for date and the other direction for day. Should be clockwise (right) for day and counterclockwise (left) for date.
Oct 20, 2010 | Invicta 8937 Wrist Watch
GB743 CHANGE DATE
mcdevito75 here, Your Bulova watch should have a 2 position crown (winder), carefully lift the crown to it"s first position, this should allow you to change the DAY, once done pull crown out to set the time, keep turning the hans till you get the right DATE (number) now set the correct time and your done.
Jul 01, 2010 | Bulova Watch
How do I change the date on 30-day months without changing the day?
In most cases the winder has 2 positions, mcdevito 75 here, pull the stem out very carefully to it's first position, this should allow you to change the DATE (number) by turning the stem eithe toward you or away, once you get the Date, pull the stem out to it"s 2 nd position and turn the hands until you get the correct day. mcdevito 75
May 20, 2010 | Swiss Army Wenger Sportedge Bracelet Watch
I just bought a new watch and am having with the calendar
Check that you have set the time at the correct AM or PM setting. If this setting is wrong it may appear that the date is changing in 12 hours because it sees 12 midday as 12 midnight.
If this resolves the issue please do take a moment to rate my answer. If not please use 'Add comment' or 'Continue with this Expert' to post up the details. I will be happy to respond.
Thanks for using FixYa.
Jan 05, 2010 | Citizen Watches
My rolex submariner keeps having the wrong date on it. when it turns midnight it stays on the old date and i switch it to the correct one. but when noon rolls around it switches to the day ahead and i once...
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Aug 06, 2009 | Rolex Watches
Change day on dial
Pull out the crown to the first click- the watch is in day-date setting mode. Turn the crown one way- the date will change. Turn the crown another way- the day will change.
Rate me, please.
Mar 21, 2009 | Guess Collection Textured Dial Watch
Watches Logo
20 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
