Question about The Computers & Internet
My Miele T9800 dryer always spins, even when door is open. I have to unplug it to get it to stop, but it starts spinning again immediately when I plug it back in.
The panel follows the correct logic and process as before. "Check vent" light isn't on.
    Top Expert:
  • The Master
  • 78,267 Answers
There is a door switch, it must be defective.
Posted on Apr 17, 2017
Replace capacitor
always unplug unit when doing that and still be very careful as it contains a powerful electrical charge even when unplugged. u can discharged it be touching a screwdriver between both prongs but make sure screwdriver is insulated
Apr 26, 2015 | Miele T9800 Electric Dryer
How do I remove the front of my t9800 dryer
remove screws inside of door an two behind control panel
Mar 03, 2015 | Miele T9800 Electric Dryer
DRYER STOPS/STARTS DOESN'T GET HOT ENOUGH
dryer duct blockage caused thermal limiters to trip. four t 20 screws remove the heater bank cover on the back of the dryer. unplug the dryer. unplug the dryer. did i forget to mention, unplug the dryer? remove the heater bank cover, and press the three red buttons in the center of each thermal limiter. at least one of them should click when you press it. replace the cover, plug the dryer in. it will now heat, but if you dont fix the blockage it will trip again.
Jun 14, 2012 | Miele T9800 Electric Dryer
Dryer wont stop
timer may be bad or switch may be dad
Jun 04, 2012 | Miele T9800 Electric Dryer
Miele T9800 stopped, made a humming noise and now it makes a horrible noise
felt seal on the front of the drum is bad. call miele for service. this is not a repair that a normal company can perform. you have to get the part from miele, and it is very complicated to repair.
May 21, 2012 | Miele T9800 Electric Dryer
I have a Miele T9800 dryer and it stopped working and the vent/filter check light came on. I checked the filter and vent and both are clear and removed the rear cover and made sure the heating element...
Hi - it makes me wonder as why we always tend to do things first prior to seeking the right/correct advice.
A T9800 Miele is not your everyday cheap dryer as you will know - the questions is have you still got your user Manual and if you do - have you read it carefully - it will tell where the problem lies and how to clean it.
I cannot grasp the fact that you would remove the rear access panel for a heater bank to check the resetable over temperature unit.
The machine clearly indicated a vent/filter error not a heat error - I know at this moment you have and are swearing & calling me names...
I will let you cool down a little ....................and I will tell you what you should have done instead of removing that panel Ok?
Jul 16, 2011 | Miele T9800 Electric Dryer
The dryer appears to work normally, except the drum does not spin, and after about a minute, the 'buzzer' comes on.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 01, 2011 | Miele T9800 Electric Dryer
Miele T9800 dryer starts then stops and goes dead. Vent is clean.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 19, 2010 | Miele T9800 Electric Dryer
Help - Miele Dryer Model T9800 problem!
The belt is most likely broken. The front drum bearing seal may have worn out and caused this to happen. Call Miele. You'll be better off.
Feb 18, 2010 | Miele T9800 Electric Dryer
Problem with Miele Touchtronic T 9800 Dryer end indicator
You've most likely got a bad control board. You'll have to install a new one which can be a bit expensive but cheaper than a new machine by far. I recommend getting a service tech to replace it for you however if your handy you could replace it yourself. Just get the new control board from an appliance parts store, they should be able to look up which board you need as long as you bring them the model number.
Dec 15, 2009 | Miele T9800 Electric Dryer
Computers & Internet Logo
37 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
