Question about Panasonic Office Equipment & Supplies
My Panasonic TC-55AS68OU is set on the lower of the two positions using the pedestal. How do I raise pedestal to the higher position?
I've lost the quick start Guide, but do remember instructions showing how to change between both positions.
  • 18 Answers
SOURCE: Zoom lever sticks
Hi, the only reason the zoom lever sticks is dirt. Either dust or some sort of liquid may have spilled on the camera. If you wipe it off, it does not help as the liquid gets into the zoom lever mechanism.It will have to strippd and cleaned.
Posted on Jul 21, 2008
mohammed387
  • 1952 Answers
SOURCE: Janome MC 10001 auto. needle threader stuck in up position.
You are threading the top of the machine incorrectly.
Make sure the needle is in correctly with the flat side to the rear of the machine, make sure to thread the upper and lower portions of the machine correctly. If this does not solve your problem, please respond.
Posted on Feb 12, 2009
jj505
  • 195 Answers
SOURCE: mower deck is stuck in down (mowing) position
Hve you tried a "rust remover spray such as wd40,spray and lighty tap until operational. Please rate jj505
Posted on Apr 06, 2009
honeymokey
  • 3113 Answers
SOURCE: Power windows not working properly 2000 Buick Century
Replace the window regulators.
Posted on Jul 17, 2009
SOURCE: PANASONIC TC-20L3T
daigram tc-20l3t
Posted on Jan 19, 2010
New Holland tractor
Sensor, wiring or computer failure.
Jun 26, 2016 | Cars & Trucks
Janome 3050 feed dogs wont come back up
Dropping the Feed Dog
The feed dog can be lowered with the drop-feed lever for sewing on buttons etc.
  • Shift the drop-feed lever to the right to lower the feed dog.
  • Shift the lever to the left to raise the feed dog, it will return to the up position when the machine is started.
NOTE:The feed dog should be in the up position for regular sewing. Turn the handwheel toward you to check if the feed dog comes up after setting the lever in the up position
JANOME DC 3050 User Manual Page 9
May 24, 2015 | Janome Sewing Machines
What is the adjustment knob on the throttle control arm of an evinrude 8hp for?
I think it's a idle stop. If you throttle it up a little you can turn it to the right and it will stop at a higher idle position. It won't raise and lower by simply turning it. It just limits or increases how far the throttle grip goes back to idle position. So you can set a trolling speed ect.
Aug 27, 2014 | Boating
How to replace crankpully on 3300 olbs
The harmonic balancer on these engines is now press fit onto the crankshaft and requires the use of Tool J-38197 for removal. The torque specification to be used during installation has also been revised. The procedure to be used when replacing the crank sensor is as follows:
REMOVAL
  1. Disconnect serpentine belt from crankshaft pulley.
  2. Raise vehicle on hoist.
  3. Remove right front tire and wheel assembly.
  4. Remove right inner fender access cover.
  5. Using 28 mm socket, remove crankshaft harmonic balancer retaining bolt.
  6. Remove crankshaft harmonic balancer using Tool (J-38197).
  7. Remove foreign object deflector (DO NOT use pry bar).
  8. Disconnect sensor electrical connector.
  9. Remove sensor and pedestal from block face.
  10. Remove sensor from pedestal
INSTALLATION
  1. Loosely install crankshaft sensor on pedestal.
  2. Position sensor with pedestal attached on Tool J-37089.
  3. Position tool on crankshaft.
  4. Install bolts to hold pedestal to block face, torque to (18-26 lb. ft.).
  5. Torque pedestal pinch bolt to (26-44 lbs. in.).
  6. Remove Tool J-37089.
  7. Install foreign object deflector.
  8. Place Tool J-37089 on harmonic balancer and turn. If any vane of the harmonic balancer touches the tool, replace the balancer assembly.
  9. Install balancer on crankshaft.
  10. Apply thread sealer GM #(NNN) NNN-NNNNor equivalent to threads of crankshaft balancer bolt. Torque bolt to + 56 degrees (104 lb. ft. + 56 degrees).
  11. Install inner fender shield.
  12. Install tire and wheel assembly. Torque lug nuts to (104 lb. ft.).
  13. Lower vehicle.
  14. Install serpentine belt.
see this vedio
Jul 11, 2014 | 1993 Oldsmobile Cutlass Ciera
How do I change a crank sensor on a 1998 Buick Lasabre?
1998 Buick Lesabre 3.8L SFI OHV 6cyl
The dual Crankshaft Position (CKP) sensor is mounted to the front of the engine, attached to an aluminum bracket mounted to the left side of the engine at the timing chain cover. A 4-wire connector plugs into the sensor, connecting it to the ignition control module.
Fig. 1: The Crankshaft Position (CKP) sensor is mounted to the front left side of the timing chain cover
REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. Remove the serpentine drive belt from the crankshaft pulley.
  3. Raise and safely support the vehicle.
  4. Remove the right front wheel and tire assembly and the right inner fender access cover/splash shield.
  5. Using a 28mm socket, remove the crankshaft harmonic balancer retaining bolt.
  6. Remove the crankshaft balancer, using a puller if necessary.
  7. For 1992-99 vehicles, remove the CKP sensor shield.
Fig. : If so equipped, remove the crankshaft position sensor shield
  1. Unplug the sensor electrical connector.
  2. For 1987-91 vehicles, perform the following:
    1. Remove the sensor and pedestal from the block face.
    2. Remove the sensor from the pedestal.
  3. For 1992-99 vehicles, remove the sensor from the block face.
To install:
  1. For 1987-91 vehicles, perform the following:
  2. Loosely install the crankshaft sensor on the pedestal.
  3. Position the sensor, with the pedestal attached, on crankshaft sensor installation tool J 37089 or equivalent.
  4. Install the bolt to hold the pedestal to the block face, then tighten to 14-28 ft. lbs. (20-40 Nm).
  5. Tighten the pedestal pinch bolt to 30-35 inch lbs. (3-4 Nm).
  6. Remove the special tool.
  7. Place the crankshaft sensor tool on the crankshaft balancer and turn. If any vane on the harmonic balancer touches the tool, replace the balancer.
  1. For 1992-99 vehicles, install the CKP sensor on the block.
    1. Install the retaining bolts and tighten to 14-28 ft. lbs. (20-40 Nm).
    2. Install the crankshaft position sensor shield.
    3. Attach the sensor electrical connector.
  2. Install the balancer on the crankshaft.
  3. Tighten the crankshaft bolt to 200-239 ft. lbs. (270-325 Nm) for 1987-91 vehicles. For 1992-99 vehicles, tighten to 110 ft. lbs. (150 Nm), plus an additional 7 degrees rotation.
  4. Install the inner fender shield and the right tire and wheel assembly.
  5. Carefully lower the vehicle.
  6. Install the serpentine belt.
  7. Connect the negative battery cable.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jan 23, 2012 | Cars & Trucks
I need to replace crank shaft timing sensor
  2. Disconnect the electrical connector at the sensor.
  3. Using a 28mm socket and pull handle, rotate the harmonic balancer until any window in the interrupter is aligned with the crank sensor.
  4. Loosen the pinch bolt on the sensor pedestal until the sensor is free to slide.
  5. Remove the pedestal to the engine mounting bolts.
  6. While manipulating the sensor within the pedestal, carefully remove the sensor and pedestal as a unit. To install:
  7. Loosen the pinch bolt on the new sensor pedestal until the sensor is free to slide.
  8. Verify that the window in the interrupter is still in the correct place.
  9. Install the sensor and pedestal as a unit while making sure that the interrupter ring is aligned within the proper slot.
  10. Install the pedestal and tighten the engine mounting bolts to 22 ft. lbs. (30 Nm).
3X Sensor
  2. Remove the sensor harness connection to the sensor. Fig. 1: Unsecure the harness, then unfasten the bolt to remove the CKP sensor 86815102.gif
  3. Unsecure the sensor block bolt.
  4. Remove the Crankshaft Position (CKP) sensor from the vehicle. Inspect the O-ring for cracks and replace if needed. To install:
  5. Install the new O-ring if needed and lubricate with engine oil.
  6. Install the sensor into the hole in the block.
  7. Install the mounting screw and tighten to 71-88 inch lbs. (8-10 Nm).
  8. Attach the sensor harness connector, then connect the negative battery cable.
Dual Crank Sensor Sections 3 and 4 of this manual also cover testing, removal and installation, and adjustment of many computer controlled components.
  2. Remove the belt(s) from the crankshaft pulley.
  3. Raise and support the vehicle safely.
  4. Remove the right front wheel and inner fender access cover.
  5. Remove the crankshaft harmonic balancer retaining bolt, then remove the harmonic balancer.
  6. Disconnect the sensor electrical connector.
  7. Remove the sensor and pedestal from the engine block, then separate the sensor from the pedestal. To install:
  8. Loosely install the crankshaft sensor to the pedestal.
  9. Using tool J-37089 or equivalent, position the sensor with the pedestal attached, on the crankshaft.
  10. Install the pedestal-to-block retaining bolts. Tighten to 14-28 ft. lbs. (20-40 Nm).
  11. Tighten the pedestal pinch bolt 30-35 inch lbs. (3-4 Nm).
  12. Remove tool J-37089 or equivalent.
  13. Place tool J-37089 or equivalent, on the harmonic balancer and turn. If any vane of the harmonic balancer touches the tool, replace the balancer assembly. NOTE: A clearance of 0.025 in. (0.635mm) is required on either side of the interrupter ring. Be certain to obtain the correct clearance. Failure to do so will damage the sensor. A misadjusted sensor of bent interrupter ring could cause rubbing of the sensor, resulting in potential driveability problems, such as rough idle, poor performance, or a no-start condition.
  14. Install the balancer on the crankshaft. Install the balancer retaining bolt. Tighten the retaining bolt to 200-239 ft. lbs. (270-325 Nm).
  15. Install the inner fender shield.
  16. Install the right front wheel assembly. Tighten the wheel nuts to 100 ft. lbs. (136 Nm).
  17. Lower the vehicle.
  18. Install the belt(s).
  19. Reconnect the negative battery cable.
24X Crank Sensor
  2. Remove the serpentine belt from the crankshaft pulley.
  4. Remove the crankshaft harmonic balancer retaining bolt, then remove the harmonic balancer.
  5. Disconnect the sensor electrical connector.
  6. Unfasten the sensor bolts, then remove the sensor. Fig. 2: The 24X crankshaft sensor is secured by two bolts 86815103.gif
    To install:
  7. Install the crankshaft sensor to the engine with the two mounting bolts. Tighten the bolts to 8 ft. lbs. (10 Nm).
  8. Attach the electrical harness to the sensor.
  9. Using tool J-29113 or equivalent, install the harmonic balancer to the vehicle.
  10. Apply a thread sealer such as GM 1052080 or an equivalent to the threads if the crankshaft balancer bolt, then tighten the bolt to 110 ft. lbs. (150 Nm).
  11. Lower the vehicle.
  12. Install the serpentine belt.
  13. Reconnect the negative battery cable.
Dec 16, 2010 | 2003 Buick Rendezvous
How do you raise the metro to make it sit higher off the floor? Is it adjustable
This mnaual wheelchair has dual position rear axles and caster forks to allow seat to floor height changes with no additional components. What this means is that the wheelchair is adjustable in height based upon the position of the front caster wheel axles and rear wheel axles. Raising the axles lowers the chair. Lowering the axle postion raises the chair. If the rear axles of the rear wheels are in the top position you can lower the wheels and raise the chair. Likewise, if the caster axles of the front wheels are in the top hole of the fork then put the wheels and axles in the lower hole to raise the chair. It is easy to accomplish this with basic tools.
If the front and rear wheels are already in the lower holes (the chair is in its highest position) you have another option. This option is a more expensive way to raise the chair by buying 4 new wheels. Lets say for example you have 24" diameter rear wheels. If you purchase new 26" diameter wheels you will raise the chair 1". If you have 6" casters and put on 8" casters this raises the chair 1" in the front. Hope this helps.
Nov 23, 2010 | Everest & Jennings 18" Metro Ic3...
Need to replace the crankshaft position sensor
  7. For 1992-99 vehicles, remove the CKP sensor shield. Fig. 1: If so equipped, remove the crankshaft position sensor shield 89634g95.gif
  8. Unplug the sensor electrical connector.
  9. For 1987-91 vehicles, perform the following:
  10. For 1992-99 vehicles, remove the sensor from the block face. To install:
    4. Install the bolt to hold the pedestal to the block face, then tighten to 14-28 ft. lbs. (20-40 Nm). Fig. 2: Position the crankshaft sensor tool on the crankshaft 89634g76.gif
      Fig. 3: Insert the crankshaft sensor tool into the harmonic balancer 89634g75.gif
  11. For 1992-99 vehicles, install the CKP sensor on the block.
  12. Install the balancer on the crankshaft.
  13. Tighten the crankshaft bolt to 200-239 ft. lbs. (270-325 Nm) for 1987-91 vehicles. For 1992-99 vehicles, tighten to 110 ft. lbs. (150 Nm), plus an additional 76┬░rotation.
  14. Install the inner fender shield and the right tire and wheel assembly.
  15. Carefully lower the vehicle.
  16. Install the serpentine belt.
  17. Connect the negative battery cable.
Oct 29, 2010 | 1999 Oldsmobile 88
How do I replace mycrank sensor on a 1991 Buick Centry 3.3
Crankshaft Sensor REMOVAL & INSTALLATION 3.8L Engine On vehicles with a manual transaxles, the crankshaft position sensor is easily accessed from beneath the engine. On vehicles with automatic transaxles, the rack and pinion heat shield and the converter intermediate exhaust assembly must be removed first.
3X Sensor
24X Crank Sensor
    To install:
Sep 24, 2010 | 1992 Buick Century
Crankshaft Position Sensor and Camshaft Position Sensor
REMOVE OR DISCONNECT
  1. Serpentine belt from the crankshaft pulley.
  2. Raise the vehicle on a hoist.
  3. Right front tire and wheel assembly.
  4. Right inner fender access cover.
  5. Using a 28 mm socket, remove the crankshaft harmonic balancer retaining bolt.
  6. Crankshaft harmonic balancer using tool J 38192 or equivalent.
  7. Sensor electrical connector.
  8. Foreign object deflector.
  9. Sensor and pedestal from block face.
  10. Sensor from pedestal.
INSTALL OR CONNECT:
  1. Loosely install the crankshaft sensor on the pedestal.
  2. Position the sensor with pedestal attached on special Tool J 37089.
  3. Position the special tool on the crankshaft.
  4. Bolts to hold the pedestal to the block face, torque to 20-40 Nm (14-28 lb.ft).
  5. Torque the pedestal pinch bolt to 3-4 Nm (38-40 lb.in).
  6. Remove special tool J 37089.
  7. Place the special tool 37089 on the harmonic balancer and turn. If any vane of the harmonic balancer touches the tool, replace the balancer assembly.
  8. Balancer on the crankshaft.
    • Apply thread sealer (GM 1052080) or equivalent to the threads of the balancer bolt.
  1. Torque the crankshaft bolt to 140 Nm + 56°(104 lb.ft + 56°).
  2. Foreign object deflector.
  3. Electrical connector.
  4. Inner fender shield.
  5. Tire and wheel assembly, torque to 140 Nm (104 lb.ft).
  6. Lower the vehicle.
  7. Serpentine belt.
Jun 02, 2009 | 1994 Buick Regal Gran Sport
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
