Question about Refrigerators
Recall on Model LAD504DUL serial KN11403151 - Refrigerators
Is there a recall on model LAD504DUL
Yes, the recall of Midea-manufactured dehumidifiers includes some models of the LAD504DUL. Go to https://www.recallrtr.com/dehumidifier. Use the drop-down menus to select the make and model. Then, enter the serial number of your unit to check if that particular unit is one of the recalled dehumidifiers.
I hope this helps.
Feb 10, 2017 | Baby Gear
Is there a recall on Frigidaire dehumidifier Model FAD504DUD
Some dehumidifiers with the model number, FAD504DUD, are subject to a recall. Record the serial number and then go to https://www.recallrtr.com/dehumidifier to check if your unit was manufactured in the bad batch.
Without the serial number, I can't be sure if your unit is in the 2016 recall. For details, you can look at https://www.cpsc.gov/Recalls/2017/Dehumidifiers-Made-by-Midea-Recalled .
I hope this helps.
Jan 26, 2017 | Frigidaire Dehumidifiers
Is my Remington Model 700 Serial Number RR86406B subject to recall?
Identify the serial number and provide it to Remington's recall support team, either by entering it at xmprecall.remington.com or call 1-800-243-9700 (Prompt #3 then Prompt #1) Monday through Friday, 9 a.m. to 5 p.m. EDT. You will be informed if your rifle is affected by this recall and supported with free resources to return the rifle for inspection and specialized cleaning.
Jan 05, 2016 | Optics
My Remington Model 700 has a smooth trigger face but the serial # is not on the recall list.
Remington has instituted a model wide recall of all Mod. 700 rifles. Instructions on their website will tell you how to return your rifle for repair.
Dec 28, 2014 | Optics
Leaking around heating element posts that protrude through dishwasher body
Some dishwashers like your model number are under recall for a potential fire hazard due to water leaking through the heating element posts onto the wiring.
Your serial number must begin with the 2 letters listed . Below is the list of recall serial numbers: FL, GL, HL, LL, ML, VL, ZL, AM, DM, FM, GM, HM, LM, MM, RM, SM, TM, VM, ZM, AR, DR, FR, GR
Call the phone # below or check out GE recall website. What GE does is replace the element and gaskets, unless there is burnt or arcing visible on the wires, they may replace the dishwasher.
www.geappliances.com/products/recall
GE has determined that an electrical failure in the dishwasher's heating element can pose a fire hazard. GE will provide a free repair to all consumers with units affected by the recall. We ask that you not use your dishwasher until it is repaired and to disconnect the electric supply by shutting off the fuse or circuit breaker controlling it and inform all users of the dishwasher about the risk of fire.
Consumers who instead wish to replace their dishwasher with a new model can receive a rebate towards the purchase of certain new GE and Profile brand dishwashers. Consumers can use a rebate of $75 for the purchase of certain GE front-control plastic tub dishwashers, or a GE rebate of $100 for the purchase of certain GE front-control stainless tub dishwashers or GE Profile top control dishwashers. See the rebate form for eligible models.
GE is aware of 15 reports of dishwasher heating element failures, seven of which resulted in fire and smoke damage beyond the unit. No injuries have been reported.
The model and serial numbers are important, as not all dishwashers are included in the recall. Look at the inside on the front left side of the dishwasher tub to find the model and serial number.
This recall is being conducted in cooperation with the U.S. Consumer Product Safety Commission, which will also monitor the effectiveness of the recall program.
Recall Hotline
866-918-8760
Monday through Friday, 8 a.m. - 5 p.m. ET.
Before calling, have the model and serial numbers on hand.
Customer Care
Apr 21, 2014 | General Electric Adora GHDA670N Built-in...
I have beco fridge serial number 0210011801 model number cga 96cw class sn type 1 please advise on the recall off the fault on them
From the list that I have, I would say no. But please take a look at the following to reassure yourself:
POTENTIAL BEKO REFRIGERATOR FIRE RISK AND RECALL NOTICE
I would normally give a pointer to articles I have already posted this response on, but as this is such a potentially serious matter, I have posted my entire response here for you.
According to several sources I have checked, including the London METRO magazine ( http://www.metro.co.uk/news/868330-beko-fridge-freezers-fire-risk-warning-issued-to-homeowners-amid-recall ) The MODEL numbers (not serial numbers) affected by the recall are as follows:
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
From what I can ascertain, the fridges affected were manufactured between January 2000 and October 2006 (So, after shipping and sitting around in shops, you can probably extend that margin to machines SOLD between 2000 and 2008)
If you go to the BEKO website, there is a link to check your serial number:
https://refsafety.beko.co.uk/
I have to say. Regardless of dates and matching serial numbers, if I had an affected model, I would be checking with BEKO anyway!!
Jul 06, 2011 | Refrigerators
IS THE FIESTA BLUE EMBER FG50069-U401 GRILL ON RECALL? MY GREASE PAN CAUGHT ON FIRE? TANYA
Fiesta did have a recall of their Blue Ember grills in 2008. However, you will need to not only have your Model #, you will also need the Serial number of your grill to make sure it was included in the recall.
Once you have the Serial Number, go to the follwing website to see if the Serial Number of your grill was included. There's a long list.
http://www.cpsc.gov/cpscpub/prerel/prhtml09/09020.html
If when you click on the link it doesn't work, simply copy and paste it into your web browser.
Jan 28, 2011 | Fiesta Blue Ember Gas Grill
Which drop side models are on the recall list?
The following model #'s are involved in at least one of 6 different recalls issued for Simplicity brand cribs.
  • Recall due to chipping paint: 8740KCS SC/Serial Nos. 2803 SC to 1605 SC
  • Recall due to mattress support issues: 8740KCS SC/Serial Nos. 2803 SC to 1605 SC
  • Recalls due to drop-side issues:
  • 8910, 8050/Serial Nos. 3005Y to 0806 HY
  • 4600, 4605, 4705, 5000, 8000, 8324, 8800, 8740, 8910, 8994, 8050, 8750, 8760, 8996
  • 8620, 8745, 8748, 8755, 8756, 8778, 8810, 8994
  • 8050, 8325, 8620, 8745, 8748, 8755, 8756, 8765, 8778, 8810, 8994, 8995, 8996
You can view the full recall details via the following link:
http://www.cpsc.gov/CPSCPUB/PREREL/prhtml09/09260list.html
Jan 09, 2010 | Graco Lajobi Kendal Convertible Crib
No. i want to know if my refrigerator is part of
Maytag MZ (a list of models), get your model number and serial number handy, recall for side by side models only. 866-231-1478, get ready to be on hold for a long time. Goodluck
Mar 11, 2009 | Refrigerators
Recall
just go ton google search type in your model # and it will bring you to arizona salvage which lists a;; recalls. Also lists 1-800-#
Sep 08, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
21 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
