Question about Retail Supplies
Hi. I have a casio ce-3415 and it only displays 0 on the screen and i cant do anything. I have tried the reset in program mode turning the power while holding the receipt feed button but didn't work.
3 Suggested Answers
flexion1
  • 737 Answers
SOURCE: Casio CE-3700 lockup
It sounds like you have a flat, or faulty backup battery. The machine has probably lost all programming. This is common if the machine has been stored.
Try this:
Turn key to program.
Turn power off at wall.
Hold JOURNAL FEED.
Turn power on at wall.
When you see '000000000' or 'LLLLLLLLLL' type 21151 (for Europe), or type 12300 (for USA) then press SUBTOTAL
If you still have trouble, just let me know.
Mark
Posted on Aug 18, 2008
flexion1
  • 737 Answers
SOURCE: CE-3700 lockup
See my other answer.
Mark
Posted on Aug 20, 2008
Casio ce 7000 error code 004
Turn key to PROGRAM mode.Turn power off at wall.Hold RECEIPT FEED down - keep your finger on it.Turn power on at wall.Wait 5 seconds, then let go of RECEIPT FEED.You should see "FFFFFFFFFF" on display.Press SUBTOTAL.Wait for printout.Turn key back to REG mode and try it. You might need to sign on again (clerk button) if you see error 8.
Nov 24, 2011 | Casio Parts Cash Register PC Desktop
I have a Casio CE-6100 cash register. Whenever I try to finalise a transaction with the "Cash" button i get a long beep and nothing happens. If i use the cheque or credit card buttons instead...
You may have changed the key feature settings for CASH accidentally. Try this:
Turn key to program mode 0 CASH SUBTOTAL 3 SUBTOTAL 0 CASH SUBTOTAL
Turn key back to REG mode and try it - you may have to sign a clerk on
If anyone needs more information, the Casio CE-6100 manual is here:
CE-6100 programming manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-6000_TK-6500_TK-7000_TK-7500_TK-T500_CE-6000_etc_dealer_manual.html
CE-6100 user manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-6100_users_manual.html
Aug 18, 2011 | Casio Parts Cash Register PC Desktop
I have casio ce-3700 cash register and i have problem E04 and noies come beep any one help me plz.
This is caused by incomplete initialisation. it means the program may be corrupt from being unplugged for too long, or you may have a bad battery inside the machine (change it every five years).
Firstly, try a flag clear to jump it back to REG mode:
Turn power off at wall Turn key to program position Hold down RECEIPT FEED button. Keep your finger on it. Turn power on at wall Wait 5 seconds, then let go of RECEIPT FEED Press SUBTOTAL
Turn key back to REG mode and try it. If the programming is corrupt, you will often see the decimal point in the wrong place.
If you want to re-program it, there is a manual for the CE-3700 here:
http://the-checkout-tech.com/manuals/TOC/cashregisters/Casio/CE-3700%20operators%20and%20programming.TOC.pdf
Aug 26, 2010 | Casio Parts Cash Register PC Desktop
CASH REGISTER CASIO CE 3115 DISPLAY E 03 AND ALARM
This ino might help: Cleaning ERRORS: ______________________________
1.- Turn the Mode lock to OFF
2.- Press down the RECEIPT FEED button
3.- Turn the key to PROGRAM
4.- Lift up RECEIPT FEED button (FFFFFFFFFF)
appears on the display panel
5.- Press SUBTOTAL (wait for receipt to issue)
6.- Turn Mode Switch back to REG and use as Normal.
Also another bit goes like this:
RESET: _______________________________________
1.- Insert the OW key and turn to OFF
2.- Hold down the JOURNAL FEED button and turn the key to PROGRAM mode
3.- Release the JOURNAL FEED button. The display should shows "00000000".
4.- Turn the key to OFF
5.- Turn to REG1. The display shows "INIT" and "0.00"
6.- Press the number 10801 and then press SUBTOTAL. Initialisation is completed when the printer stops operation. The display shows: "_ 0.00"
Hope this helps in restting to factory settings................................sodeep
May 12, 2009 | Casio Parts Cash Register PC Desktop
A error in cash register casio ce-4250
Hi.
Try this:
Hold RECEIPT FEED down.
When you see 'FFFFFFFFFF' on display, let go of RECEIPT FEED.
Press SUBTOTAL
Let me know if you still have trouble.
Mark
Jan 19, 2009 | Casio Parts Cash Register PC Desktop
Te-2200 does'nt work
Hi.
You may have lost all of the programming.
I need to see the MAC code.
Press SUBTOTAL
Now look at the print out and tell me what the big number is right at the bottom.
Mark
Nov 27, 2008 | Casio Parts Cash Register PC Desktop
Casio ce-3700 e01
Hi. You have turned the key before you finished what you were doing in another mode. A flag clear will jump you back to reg mode. Try this:
Turn key to program mode.
Hold RECEIPT FEED button down.
Turn power on at wall and let go of RECEIPT FEED after 5 seconds.
You should see 'FFFFFFF' on display
Press SUBTOTAL
Turn key back to reg mode and try it.
Mark
Sep 11, 2008 | Casio Parts Cash Register PC Desktop
Try this:
Hold JOURNAL FEED.
Mark
Aug 18, 2008 | Casio Parts Cash Register PC Desktop
Casio CE 2350
Hi.
It depends what is causing the lockup.
If you don't have anything on the display, then it is probably a printer jam. If you have anything at all on the display, then you can try a flag clear:
Turn the power off at the wall.
Turn the key to Program mode.
Hold down RECEIPT FEED button while turning on at the wall.
Wait 5 seconds
Let go of RECEIPT FEED
You should see 'FFFFFFFFF' on the display.
Press SUBTOTAL
Turn the key back to Reg mode, and try it. You might have to log on to the machine if you normally use logon codes.
Mark
Jul 10, 2008 | Casio Parts Cash Register PC Desktop
Retail Supplies Logo
46 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
