Question about Sharp Televison & Video
I am trying to do a channel scan on my older sharp tv to set up an antenna but have no enter button on my remote. I can get to setup on the menu but dont know what to do from there?
SIGDOM
  • 17 Answers
SOURCE: unable to automatically scan for
To make it easy for you - you should have original remote.
Then through the menu look for channel set up then make sure you select cable or antenna then you do autosearch(sometimes called autoprogram).Unless the tuner is defective,you should be able to program withe the original remote.
Posted on Jul 19, 2008
SOURCE: Remote will not work. Can't perform channel setup scan.
Unplug it for a day or 2 and it will bring up the menu again like the first time.
I had the same problem with the 13 inch symphonic.
Posted on Jan 09, 2009
  • 82 Answers
SOURCE: rca hdtv channel changed by mistake
RCA channel setup and selection is not easy to understand. You may try to add channel 3 on the add/remove channel section. If that doesn't work try pressing the input button. Good Luck.
Posted on Mar 10, 2010
BElectric
  • 1140 Answers
SOURCE: I recent purchased a
There is always a possibility of getting a lemon when you buy any new electronic device, but I hope this is not the case here. From what you describe, it would appear that the channel scan is not finding anything and the TV is stuck in installation mode. There are several possible reasons why this could happen, but let's start with the 2 most common ones first:
- The devices are not connected correctly meaning there is no signal to the TV;
- The wrong scanning option has been selected;
I thank you for providing such a detailed description but I'm going to need some more information from you to solve this problem. Specifically, I need to know:
1. What is the signal source for the TV? (antenna, cable, satellite, etc)
2. How are all the devices interconnected? Basically what is connected to what else.
3. Model numbers of the TV and Shaw PVR
4. Any other detail which may be relevant - types of cable used to connect the devices, etc.
Please reply to me from within this page with the information requested and hopefully I will be able to solve this problem for you fairly easily.
In the meantime, if you are using a cable/satellite receiver or digital converter, try connecting this directly to the TV and scan again. It would be a good test to determine whether the TV is working and therefore something is wrong with the setup.
Thanks,
BElectric
Posted on Jan 31, 2011
  • 3799 Answers
SOURCE: h i have no remote for hannspree tv, tried scanning channels with buttons on the side of tv, dont know what i touched,but now its wont do anything just says scan channels. wont even turn off
Remove power for about 30 seconds and try again.
Posted on Feb 04, 2012
How to get to menu then adjust it to antena?
First make sure that an antenna is connected the coaxial input on the TV and the input is set to TV. There is an Input button on the top of the TV and on the original remote. On the remote, the Input button is below and slightly to the right of the 0 button. On the top of the TV, the Input button is the one closest to the Power button. You can toggle through the Inputs by pressing the Input button several times or use the up/down arrows and then press the Input button to select the input. (TV should be the top item in the list.)
Next press the Menu button on the remote, above and to the right of the arrow keys. (There is no Menu button on the TV.) Use the left/right arrows to navigate to Setup. Next use the up/down arrows to select CH setup. Press Enter. If you've set a PIN, you'll need to enter it. Use the up/down arrows to select the line Air/Cable, if you need to change the source of your signal. Press Enter. Use the left/right arrows to select your source. Press Enter to save the setting. Press Menu to exit. Return to this CH setup menu and use the up/down arrows to select CH Search and press Enter. If you are using an OTA antenna, use the left/right arrows to select Start and press Enter. Wait for the search to be completed. For cable sources, you'd need to select from Analog Search Start or Digital and Analog Search Start. Press Cancel and then Enter to exit the search.
Crutchfield has the manual for the LC-32D62U available from the product page under the Details tab: http://www.crutchfield.com/S-mhRC3OB2Fi4/p_284LC32D62/Sharp-LC-32D62U.html . The direct link to the manual is http://d2stobyut4u5rx.cloudfront.net/ImageBank/v20080124174400/Manuals/284/284LC32D62.PDF . The Input button use is available on page 30 of the manual. The channel search steps are shown on page 23.
I hope this helps. Please note, if you have an replacement universal remote, you may need to try multiple codes for Sharp TVs to get the Menu button to work. If your replacement remote doesn't have a Menu button or none of the codes work, then you'll need a different remote.
Nov 07, 2015 | Sharp Aquos Lc32d62u 32-inch 1080p Lcd...
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See tvfool.com for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; remotes.com also has a replacement remote available that has been programmed for the TV. (On remotes.com, search for the LC32SB24U.)
I hope this helps.
Oct 26, 2015 | Sharp LC-32SB24U 32 in. LCD TV
How do I switch the TV from cable to regular TV
Depending on your TV make, normally hitting the antenna button will switch you from cable to antenna (regular) TV.
Aug 24, 2015 | Video Game Consoles & Games
I HAVE A RCA 42" LED TV. I RECEIVE MY SIGNAL FROM AN ANTENNA. I CAN ROTATE MY ANTENNA, SCAN THE TV FOR CHANNELS, AND THIS WORKS FINE. THE PROBLEM IS IF I HAVE TO ROTATE THE ANTENNA FOR OTHER CHANNELS,...
on B:Press the MENU button on the remote.Select Setup.Select Auto Program.Choose Air or Cable.Select Auto Program to let the TV reprogram the channels.Check that the channel is programmed into memory. There are a couple of ways to do this: Use the TV menu system. Accessing this setting varies depending on the model TV that you own. Here are two options that are common on many TV's: Option A:Press the MENU button on the remote.Use the VOL and CH buttons to move through the menu and add any missing channels try this if not r
Do a full reset if this dosnt work
Dec 25, 2013 | RCA L42WD22 42 in. LCD Television
Tried to use roof antenna on RV. My Sharp hdtv by passes the digital setup. How do I receive the over the air digital signal
Used the tv remote.Push the menu button.Now u are tv menu.Goto SETUP,go down to CH SETUP push enter on the tv remote.Pick AIR not Cable and push enter on the remote again.Now tv go in auto scanning.After it is done searching all cannels,ur tv will get all the free DTV air broadcasting channels.
Apr 17, 2011 | Sharp AQUOS LC-32GP1U 32 in. LCD HDTV
I hook my antenna to the back and I'm not receiving a picture
I'm assuming your Antenna is connected to your TV with a co-axial cable? If so, please make sure you have run the Analogue/Antenna/Air channel scan correctly:
1. Switch the TV on
2. Press the "MENU" button on the Curtis remote supplied with the TV.
3. Press the RIGHT arrow button five times to highlight the "Channel" menu
4. Press the "ENTER" button or the DOWN arrow once to open the "Channel" menu
The Air/Cable option should be highlighted.
5. Use the LEFT/RIGHT arrow buttons to set the "Air/Cable" option to "Air"
6. Press the DOWN arrow to highlight "Auto Scan"
7. Press the "ENTER" button or the RIGHT arrow once to start the automatic channel scan.
When the scan has finished, the TV should automatically return to viewing mode. If not, just press the "EXIT" or "MENU" button on the remote to close the menu.
You also need to make sure the correct INPUT/SOURCE is selected on the TV:
1. Press the "SOURCE" button on the Curtis remote
2. Use the UP/DOWN arrows to highlight "TV" in the INPUT SOURCE menu
3. Press the "ENTER" button on the remote to select "TV" and close the INPUT SOURCE menu.
This should be all you need to do to watch your TV from an antenna source.
Please post back if you are still unable to get it to work and need further assistance.
Regards,
BElectric
Dec 30, 2010 | Curtis LCD2424A 24 in. LCD HDTV
I have a cable coming from the wall, and when I hooked it up to my TV Panaconic 42'' viera Just bought the TV today. . the screen is black and keeps saying No signal.... what could the problem be? Just had...
You either set the options incorrectly when running the "First Time Setup" or you skipped the first time setup entirely. Even though the cable works with your older TV, you still need to setup your new TV correctly to receive the cable feed.
The quickest way to do this is run the setup manually from the menu as follows:
1. Turn the TV on
2. Press the "MENU" button on the remote
3. Use the DOWN arrow key to highlight "SETUP" (the arrows are the big ring button around "OK")
4. Press "OK" to enter the SETUP MENU
5. Use the DOWN arrow key to highlight "PROGRAM CHANNEL"
6. Press "OK" to enter the PROGRAM CHANNEL MENU
7. Use the LEFT/RIGHT arrow key to ensure "CABLE" is highlighted
9. Use the DOWN arrow key to highlight "AUTO"
10. Press "OK" to enter the AUTO SCAN MENU
11. Highlight "ALL CHANNELS" using the UP/DOWN arrows
12. Press "OK" to start the AUTO SCAN
The scan may take several minutes to complete.
13. Highlight "APPLY" using the the LEFT/RIGHT arrow keys.
14. Press "OK" - all of the scanned channels will now be saved.
The TV should now return to viewing mode and you should be able to watch cable on your new TV. If the TV does not automatically exit the menu, simply press the "EXIT" key on the remote, next to the MENU button.
Please run through the above steps and if you are still unable to get the cable channels on your new TV, please post back for further assistance.
Regards,
BElectric
Dec 16, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
How to switch sharp tv lc26d4u from air to cable using remote ga263wjsa My mother touched the a- antenna button and now it's in air mode.can't switch back to cable .no button?
Press a button on the remote that said tv Menu.Goto SETUP,go down to CH.press the CH. highlight.Pick CABLE and press enter than tv will automatically scan ur tv for ur pay cable channels.
Nov 02, 2010 | Televison & Video
I plugged in the tv and i only have fuzz is there a way to do a channel scan
If the set is more than a couple of years old it's won't have digital tuning, so without a DTV converter box the fuzz is all you're going to get. It won't be able to pick up any TV signals on its own now that conventional analog broadcasts have ended. You'll need to get a converter (and possibly a new antenna as well), hook it to the TV and follow the setup and channel scan instructions it comes with.
If the set is new enough that it has a digital tuner already built-in, use the TV's setup menu to verify the thing is properly set for digital broadcasts and scan for channels. The on-screen displays generally make the steps clear what buttons you need to press to start the scan. This is assuming you have the remote control available or that there is a front-panel menu button on your set. If you've lost your remote, there may be no way to get into the setup without it.
You can probably find a manual for your model online at Sharp's website. If you'll post a followup comment with the complete model number, I'll see if I can provide any more information for you.
Jul 16, 2009 | Sharp Televison & Video
Televison & Video Logo
26 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
