Question about Food Mixers
Mixer does not work in low speed 200a - Food Mixers
    Top Expert:
  • Food Mixers Master
  • 40,473 Answers
The speed selection switch may have failed.
Posted on Apr 17, 2017
My mixer will only work on high speed why
Speed controllers reduce the power provided to the mixer motor and have to "soak up" some of the power not used. If the mixer was used on low speed but heavy load, it could have burned out the speed controller. Some of them fail by shorting out which means that the motor always gets full power regardless of speed setting. It sounds like your speed controller has burned out.
Feb 19, 2017 | Food Mixers
Mixer does not work at low speeds
could be a loose contact on the speed selector..
Jul 29, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Funky speed
Could also be a broken wire to the control plate. It's not very often the plate itself. Just looking in there while operating the lever may reveal something. The shaft at the bottom that moves the plate closes a set of points to start the mixer, maybe the points are loose and not closing when they should. Just be careful operating it with the cover off and alive.
Dec 28, 2013 | KitchenAid K5SS Mixer Speed Control Plate...
KitchenAid mixer speed surges high and low uncontrolably
You can get the high speed back if you want to play with those three screws. there is a timing scheme for your mixer and it is set and adjusted by manipulating those 3 screws. The bottom center screw is for speeds 6 8 and 10. The best choice is to replace this switch, about $10 bucks on ebay.
Nov 13, 2012 | KitchenAid K45SS Classic Stand Mixer
Mixer works on high speed but not low. Brushes
Motor brushes are fairly cheap to buy. It sounds like the first place to start:
Jan 11, 2010 | KitchenAid K5SS Heavy Duty Commercial...
1970's 10 speed - Low speeds are barely working.
Replace the motor with a similar size and voltage. It should say on the motor what size it is.. Take the gear off and save it for new motor.
Aug 17, 2009 | Food Mixers
Kitchenaid artisan mixer does not turn the blade at low speeds
If it is the worm gear then the planetary will stop turning when there is a load on the paddle but the motor will continue to run at the speed you set it at. I'd be checking the carbon brushes, checking that the field assembly has not loosened up a bit and then I would see if the speed control plate adjustment screws are loose. I'd then reset the speed and see if it stays as it should be.
Sep 24, 2017 | KitchenAid K45SS Classic Stand Mixer
K45ss kitenaid mixer surges at low speeds
Hi. Go to and download their free Kitchenaid Service Manual. This valuable document will help you to tune up your mixer, and covers the K45SS model. They also sell kitchenaid parts.
Go to and search for a parts manual for your mixer. Enter your model# thusly k45sswh.
If this solution has assisted you, please rate it. Good luck! ricardok45.
Apr 12, 2009 | KitchenAid K45SS Classic Stand Mixer
575 watt 6qt stand mixer. start out on low speed
Hi. If your mixer is still under warranty, call Kitchenaid, they are usually very good at replacing mixers under warranty.
If you're out of warranty, you'll need to order a new speed control board. Use the following link to download the parts catalog for your mixer.
You can remove and replace this board yourself. Use the drawings to assist you with the project.
Mar 16, 2009 | KitchenAid KP26M1X Stand Mixer
Food Mixers Logo
64 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
