Question about Kenmore Washing Machines
How do you fix a SR Error Code on Kenmore Elite Calypso Washing Machine? (Is control board replacement the only option or can the relay be "Unstuck"/reset)
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 12 Answers
You could tap the relay with a screwdriver handle or something that may unstuck it.
Can also just replace the relay(s) if you are able to remove the board and know how to de solder and solder
Posted on May 04, 2017
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite Calypso
"LF" is a "LONG FILL" error. This will occur if water fill time exceeds 10 minutes. I don't know why this would pop up at the end of a cycle. Normally this is associated with filling at the beginning of a cycle. There is also an "FL" error, which is an "OVERFILL" error. This is normally associated with a problem with either the control board or wiring harness. This normally occurs when there is an open circuit between pins 1 and 3 on P17 of the control board. That one is a little more involved and usually requires replacement of the control board, wiring harness, or both. If you, indeed, have an "LF" error I would check your water source coming in. Check your fill hoses for kinks or obstructions, first. Then, turn the water supply off and remove the hoses from the back of the machine. Place one end of each hose inside the wash tub and turn both water supply lines back on to make sure you have good water flow coming through the hoses. Replace the hoses if they show signs of bulging, cracks, leaking and/or restricted water flow. Turn water back off and check the fill valve inlet ports on the back of the washer for accumulations of sediments in the screens. It doesn't take much to restrict water flow. You can clean the screens with a cotton swab. If you check everything and still have problems with the error code popping up, I would replace the fill valve. It's an easier fix and less expensive than a control board. If you decide to replace the valve, it is located under the console on your washer, I believe. It's fairly simple with a couple of screws to remove on the console and a couple of connectors and hoses on the valve to remove. Make sure you unplug the machine and turn off the water supply before attempting. I hope you find this advice helpful. Let me know if this works for you.
Posted on Jul 14, 2007
catriver
  • 878 Answers
SOURCE: F2 error code
Chia, this is not a good one, F2 is a keypad failure or interface mismatch. You can try a couple of things. 1. unplug the washer for a minute and see if the code returns. 2. Remove the consol to access the control board, three screws on the backside and the consol lifts up. On the right side you will see the main board. On the right side of the board, center harness will be the interface ribbon cable. Reseat it a couple of times. If this doesn't work, I believe you will have to replace the touchpad. Catriver.
Posted on Jan 13, 2008
SOURCE: Kenmore Calypso Washing Machine
I have had the same problem, there is too much water in the basin. I actually have a repair man coming over in the morning to replace the pump motor. There is a way to make the pump drain without cycling the washer. I cannot remember the exact process, so I will have to wait until the am to repost the solution (sorry).
Posted on Mar 12, 2008
jimappliance
  • 42 Answers
SOURCE: Kenmore Elite Catalyst washing machine getting error F4
See if this helps.
http://www.askmehelpdesk.com/appliances/washer-kenmore-elite-catalyst-110-20092993-f3-f4-error-codes-191730.html
Posted on Aug 01, 2009
  • 636 Answers
SOURCE: Kenmore Elite Calypso washer with C1 error code
Have you tried unplugging it for a couple of minute?
Posted on Aug 11, 2009
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
    Search Results
      Why am I getting an FL error code on a Kenmore Calypso ...
      www.shopyourway.com > Manage My Life > Questions
      I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
      fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
    Jan 27, 2016 | Washing Machines
    Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
    Slow drain code. How high is the outlet pipe ABOVE the machine?
    Jan 05, 2016 | Washing Machines
    My Kenmore Elite Calypso wont stop washing
    What is the model number of your unit?
    Nov 22, 2012 | Washing Machines
    My kenmore elite washer, model #110.27092600 flashes an f1 error code when filling
    F1 code = Primary Control Failure. Replace the machine/motor control assembly.
    Call 1-800-659-7026. That machine has a recall for the control board and if your machine is in the recall they will fix it for free.
    Jul 30, 2011 | Kenmore Washing Machines
    Whirlpool Calypso washer with Sr error code. Water sound will begin and sound like it is coming in, and then shut off. It tries this a couple of times. I cleaned the strainer on the back at the hose...
    Hello, Thank You for using FixYa. I will be helping you today.
    "Sr" signifies a failure of the relay in the closed position. With this failure, power to the motor controller cannot be turned off by the machine controller.
    The machine control board may have a bad relay and may need to be replaced. Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller. This should have AC line voltage when the motor controller is powered.Chances are it needs a machine control.
    Thank You and please rate my answer if it was helpful..
    Jun 12, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
    My kenmore front load washing machine comes up with error sp ?
    SR = Stuck Relay.
    Press STOP/CANCEL to clear the display.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Aug 23, 2010 | Kenmore 44102 Front Load Washer
    Getting sr error code
    The Sr error code means that there is a stuck relay on your main board. Would request you to replace your pc board.
    Let us know if you want any further clarification.
    Thanks for contacting fixya.com
    Dec 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    Error SR
    SR = Stuck Relay.
    Jan 28, 2009 | Kenmore 24032\24036 Top Load Washer
    Kenmore elite calypso 24082 error code CE
    On the ccu, the board on the right is usually the culprit, I have recently replaced one with that same error but I would first unplug it and remove and re connect each plug on the board looking for dark connections or dialysis, corrosion. If not fully insert each plug and try again.
    Sep 06, 2008 | Kenmore Elite 45986 Front Load Washer
    Washing Machines Logo
    52 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
