Question about Mitsubishi Heating & Cooling
My Mitsubishi Mr. Slim continues to trip and stop...when it starts both lights are on...when it trips only one light is on and it is flashing...please advise...Thank you
  • 1,873 Answers
Try vacuuming the drain line.
Posted on Apr 17, 2017
Why is my mr slim a/c tripping the main C.B. on start-up, but not every time.
try washing the outside coil with a water hose to see if its kicking out on high pressure and tripping the breaker. Clean the coil well with a spray nozzle.
Aug 01, 2014 | Mitsubishi Electric Mr Slim E12C26426...
Indicator light
May be showing a fault code, you need to count how many times it flashes. Could also be a delay or de ice mode which will go away after a few minutes
Aug 05, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
Had a thunderstorm here this morning, I'm sure it was a lightning strike as our TV's do not work either. On our Mr. Slim unit the green light flashes continuously on the inside unit but the...
It could have takenout the compressor but I would start with the breakers or fuses , then move to the capisitor. But first just shut it down for a bit at the breaker and then reset the breaker.. Hope this helps let me know jon
Aug 05, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a Mitsubishi Mr. Slim Model MSZ-A09NA. We just purchased the house and have only been using it for a week. I had it serviced on Friday and was told it worked fine. Sat. we had a power outage. ...
Hi, it sounds like you may have lost the blower motor due to the power surge. Normally, it would kick the breaker off.The code is just telling you something is not right as you know. You can try turning off the breaker to the indoor unit for 10 minutes or so, and reset it to see if the blower will start. If you have the manual, that might tell you what the code or light is. Its more then likely a 220 volt indoor unit. Sometimes on a double pole breaker, only one half of it will trip in a power surge. Check to see if this is the case, as you may only be getting 120 volts to run the vanes. If its half way tripped, turn it off hard, and back on hard. that may be your problem. If not, call the service tech, and just tell him it stopped working. He will come out at know charge to you. I bet its your breaker though. Please let me know.
Sincerely,
Shastalaker7
A/C Contractor
Jun 06, 2011 | Mitsubishi MS09TW Air Conditioner
MMy Mitsubishi Mr. Slim Air conditioner is
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
May 26, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr. Slim MXZ30TN Air Conditioner: Indoor unit blinks on and off what is the problem?...
continuous flash is frost prevention ...clean the filter & switch fan to high
flashes once every 2 sec could be room air sensor contact loose/short...call dealer
flashes 2x every 2 sec is indoor coil sensor contact loose/short...call dealer
flashes 3x / 2sec sensor contact problem, or compressor overload protection trip or gas leak...call dealer
May 17, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
CIRCUIT BREKER KEEPS TRIPPING
Your house wiring in not capable of powering the unit. Try a different location to plug in. Check the unit to make sure it is not faulty and will trip breakers because it is damaged.
Sep 29, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim breaker continuously trips
Sounds like you're on the right track. Might as well replace the , inexpensive, gfi while doing so. With power off make sure all connections are tight. Electrical tape is a wonderful thing. Good luck!!
Apr 01, 2017 | Mitsubishi Heating & Cooling
Display E4 code then only normal air blow in the room
check your cap also you may have a bad condensor fan
Feb 21, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
62 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
