Question about Refrigerators
What would cause my immunochemistry reagent cooler compressor to fail yet fan is running/
5 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: lowe vv 5n countertop cooler top fan inside unit
the compressor won't turn on if the other fan is not running. make sure nothing is blocking it. replace if necessary.
Posted on Aug 26, 2009
  • 1040 Answers
SOURCE: Cooler won't cool. Fan is
hi,
not just the compressor running is fine but the compressor should have gas in it... if the compressor gas has been wiped out in the same case also the refrigeration will stop cooling....
Hope this has helped you... thanks
Posted on Aug 18, 2010
walterkunesk
  • 683 Answers
SOURCE: my refigerator does not work.
you can test it if you are still online i will tell you how.
Posted on Mar 12, 2011
  • 489 Answers
SOURCE: my true back bar cooler dosent cool it is not iceing over
That will help You. REPLACING COMPRESSOR TRUE AIR BEER COOLER R134A
Posted on Jan 26, 2015
Fan runs, control panel lights up compressor not running unit not cooling. Any ideas as to why compressor not running?
could be a start run capacitor failed
I suggest that you get a fridge technician to check ti out first as a compressor is generally more expensive than a new unit.
Aug 03, 2015 | Furniture
Fan not spinning
If the fan on the backside is not spinning it could be a bad fan-motor. When the fan runs the compressor should run as well. If the compressor is not running the fan should not be running either, so you should unplug it for about an hour, then plug it back in and see if the compressor unit starts up. If it doesn't, it is probably something wrong in the control circuit for the compressor. It could be the thermostat (check that it is set correctly). If the compressor starts up but the fan does not run, it is most likely a bad fan motor or bad wire leading to the fan motor.
Jan 20, 2014 | Cuisinart CWC1600 Wine Cooler
The wine cooler light works but it does not cool.
so the light tell us that it has power . you need to ck the fan underneath in back and make sure it is running and feel the compressor it runs when the fan does . and you may nees gas in the unit . . so ck the fans / then the compressor see if hot or can you feel it running and then the refergent . and the thermostat down in front . andy of these could cause the no cool problem. mm hope this has helped ..feed back pls ..
Nov 25, 2010 | GE ZDW24Y Wine Cooler
My wine cooler no longer cools the temperature is hot
Do you hear it running? Usually there are two things that happen with wine coolers when they get warm. The first is a faulty cold temperature control, failing to turn the unit on despite our attempt. You should have one, possibly two or more fans. If you have any, and they do not run no matter where you set control, that is likely your problem. If you dont have any fans - you will likely have a black plate with some "bubbles" around the back and side walls, Then you may have to have a service company test your compressor, to see if the compressor itself or the starter has failed.
Assuming the other motors on the cabinet are running, you've narrowed your problem down to 2 things, the compressor itself, or the start device has failed. Without the proper tools you wont be able to test the compressor first. My advice, go to repair clinic . com, see what a starter will cost you, if you can find a repairman to check your compressor for cheaper than what it costs to buy starter, well there you go. Either way, if its the compressor thats bad, you wont want to spend the money to replace, unless you have a built in worth several thousand, or physical constraints of kitchen prevent you from buying new fridge.
Visit: www.FixMyFridge.net for Chicagoland Refrigerator Repair Service or read our FAQ and Tips.
Mar 22, 2010 | Refrigerators
Wine cooler not cooling below 65 lights works but not fan any ideas
Brand and model number will help someone answer your question easier. But to guess the problem I would think the fan is the answer. Both interior and exterior fans must run while any cooler or refrigerator or it will cause the compressor to over heat and stop cooling. Running with a bad fan can also damage the compressor internal overload. f you unplug the fan wires and test for voltage you should get your local voltage unless the fans are DC. Thanks, Lit me know the model and make and I will help you further, Sea Breeze
Feb 11, 2010 | Refrigerators
Danby DWC513BLS does not cool. Fan is on, but compressor does not turn on to lower temperature even when temperature is turned down. Where does one get parts for this online
Before you worry about where to get parts,you need to know what is wrong and what parts you will need. When a compressor does not run but the fan motor does, then either the compessor is bad (in which case you need refrigeration expertise) or the starter components have failed ( in which case you can replace. The two most common failed parts are the start relay or the overload (both attached to the compressor. Goodluck, Macgivor
Jan 31, 2010 | Danby Silhouette DWC512BL Wine Cooler
Where can I get a wiring diagram for an under-counter Beverage-Air cooler. The condenser runs then stops after a few seconds. Figuring a bad relay? The power runs but the condenser kicks off immediately...
If it's the condenser fan you are talking about you will not need a wiring diagram. The fan should be wired to the compressor and the thermostat. the thermostat is the relay to start the fans and compressor. I will continue to look for a wiring diagram. When the fan wears out they will stop causing the cooler to overheat. I think replacing the fan would be what you need. I believe that Beverage Air used the Copeland compressor with the condenser fan mounted on the one end of the the same slide in compressor. Check your voltage on the 2 wires going to the fan. When compressor is on the fan should also be running. I just have the feeling that condenser fan is defective.
Sea Breeze
Aug 19, 2009 | Refrigerators
I just bought a wine cooler not sure where to start to fix it. Fans will not turn on
Hi there.........i take it this is a used / second hand wine cooler......if so you've probably discovered why its been discarded........problem could b due to a faulty compressor unit....the fans are usually wired through the compressor...and run in conjunction with it........if the compressor isnt running then the fans are out .........if the comressor is running then check that there is nothing impeeding the fans rotation.....check for broken or damaged wiring.....check for tampering by someone else....check continuity of wiring through fan coils.........check for faulty starter unit on compressor
regarddss ir Galahad
Aug 12, 2009 | Haier BC112G Wine Cooler
Cooler coil freezing up
Way too many thing's can cause such problem's. Most important with bottle coolers are clean condensor, good condensor ventilation, do not overstock and block evaporator circulation. Then you get to component failures, failed thermostat or improperly positioned sensing element, failed evaporator fan, icing of the evaporator section from fan or gas charge problems, contamination in gas curcuit causing cap tube blockage, compressor overheat shut downs from real or defective component issue's. Trouble-shooting is a plan for cause elimination, start with the simple end and move out from there?
Jun 29, 2009 | True TD-95-38-LT Beverage Cooler
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
