Question about Refrigerators
First time i used ice maker(ICE115-SS) it worked great, now it will not make any ice. is there a reset button?
  • 725 Answers
SOURCE: ice maker
1 may have frozen water line
2 reset ice maker press in ice lever 5 times
3check check ice maker plug
Posted on May 20, 2008
  • 19396 Answers
SOURCE: ice maker not making ice
Check the following suggestions from repairclinic:
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Oct 10, 2008
  • 2651 Answers
SOURCE: Ice maker only produces crushed ice
not really a reset button but htere is a solenoid that controls the type of ice coming out of dispenser. with the ice bucket in place give a look at it from underneath and find the brass rod spanning from front to back of bucket. that rod hooks into a solenoid catch that when activated lifts the rod up and down for crushed/ or cubed ice.. after locating the "hole" in which the rod enters you should also see a corresponding plastic ring that would catch the rod upn activating stich and pull/up and down.. Ill assume that the "catch ring" is tuck in the up positon , might only be frozen up in which case you can hit it with a hair dryer to melt it, its also possible that the \solenoid had melted it self in the up position in which case you need to replace it.. to check this theory you can hook the brass rod into the ring assy in which case youll only dispense cubed no crushed
Posted on Nov 03, 2008
  • 700 Answers
SOURCE: Viking Ice Maker Leak
have you cleaned the machine lately? the float may be dirty and getting stuck and not shutting down the water as it should.
Posted on Jan 06, 2009
  • 3 Answers
SOURCE: Ice Maker quit making ice cubes
Look on the bottom of the rectangular motor housing for the ice maker. This is the white box that holds the front end of the ice tray. In the past, this was normally a small patch of black 'runner' that covered the switch and helped kkep moisture out.
If you cannot locate it by feel, try using a small mirror and a flashlight to help you locate it.
Posted on Jan 14, 2009
Hoshizaki Model B-700PF is beeping three times and wont make ice.
It appears that you have supplied the ice bin model number and not the ice maker numbers. Please double check your unit and see if you can locate those numbers.
Dec 11, 2017 | Hoshizaki Freezers
Where is the reset button on the refridgerator ice makers.
4X??????? Hard to fathom you got 4 bad units in a row.
Check internal freezer temp. If not less than 10 degrees the thermostat inside the ice maker will not allow the unit to cycle and make ice. The issue could be with your refrigerator and not the ice maker.
Sep 26, 2016 | Refrigerators
GE MONOGRAM ZFS826DRC SS ice maker not working
Push the white paddle in three times slowly within 15 seconds. Then wait 2 minutes. You should see the ice maker start to cycle. If the ice maker doesn't cycle, replace the ice maker. If you need a new ice maker, you can go to the link below
Order Ice Maker
Refrigerator Parts
Mar 06, 2011 | GE Monogram ZISS480DRSS Stainless Steel
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Jan 06, 2009 | Viking Refrigerators
ngfam1 At your service!
You need service this time !
Sounds like a Thermostat problem!
How old is the ice maker?
If is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Aug 25, 2008 | Kenmore 53642 / 53644 Side by Side...
Icemaker just stopped making ice
As these ice makers cycle there is an arm that moves up while the ice is being freed from the ice maker. After the ice is dumped into the dispenser bin the arm continues a downward motion. If it encounters ice in the downward travel it shuts the ice maker off. If this arm is locked in the full up position the ice maker is manually shut off. Check this arm and make sure it is not locked in the up position.
May 15, 2008 | GE PSS26MGS Side by Side Refrigerator
Ice maker
May 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working
fill tube could be frozen, ice maker module could be bad.
Apr 09, 2008 | Whirlpool ED2FHEXN Side by Side...
Samsung RB215LABP Bottom Freezer Ice Maker..
refrigerator working great then the refrigerator portion went frmo 35deg to 61 freezer is at 4deg can not understand whats up and i cant get the damn thing to do ****
Oct 07, 2007 | Samsung RB2155 Bottom Freezer Refrigerator
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
