Question about Grilling
My grill keep turning off when i am cooking ribs
  • 463 Answers
Pressure regulator on hose is bad
Posted on Apr 17, 2017
How long would I need to cook a 151/2 lb crown roast fo pork on a Weber grill. It has 18 ribs
Cooking times are dependent on much more than weight. The shape of the roast, the thickness, the uniformity, the outside temperature, the quirks of your grill... the only way to cook a roast properly is with a probe-type thermometer. You decide what temperature you want the center of your roast and cook it until it reaches that temperature. Be sure to cook over the cool side of a two-zone fire and rotate every once in awhile to even out which side faces the fire side.
Dec 23, 2017 | Weber Grilling
What temp and how long yo cook a 5 1/2 pound prime rib roast
Cook the roast for 15 minutes, then reduce the oven temperature to 325 degrees F. Continue to cook the roast until your meat thermometer reads 110 degrees F. Estimate about 15 minutes of cooking time per pound of prime rib.22 Dec 2014
The world's easiest prime rib roast: Master a holiday classic - What temp and how long yo cook 5 1 2 pound prime rib roast Google Search
Nov 27, 2016 | Grilling
At what temperature do you cook bone in and boneless prime rib and how long per pound
13 - 15 minutes per pound @ 300 - 325 degrees F, pull when meat is 125 F - 130 F (internal temp.) for rare to medium-rare. Err on the low side. Allow to rest; the meat will continue to cook while resting. For example, if you cook it to be medium-rare (130ish F), then pull it out of the oven, and let it rest, it will end up being medium to medium-well (140 - 145 F) once cut. So be aware.
Bone-in, bone-out it doesn't really matter, because the bone is not in the center of the meat. It's best to let the prime warm at room temp for a period of time, before cooking. An hour or so from the refrigerator (not frozen).
Some people like to place the prime into a hot (425 F) oven or grill/smoker for 10 -15 minutes, then turn down to roasting temp. This is done to sear the outside, which will give it a crispy/seared outside. This doesn't "lock in" flavor, juices or anything else, it is more of a visual and texture thing. If you do this, the cooking time will be reduced, because the oven/grill will have to come down in temp over a period of time while the meat is cooking. I don't recommend doing this with prime rib. It ends up being overcooked and tough, due to the fast then slow roasting of the meat.
What you want to keep in mind is: roast the meat low and slow. Check the internal temp, with a meat thermometer, early to avoid overcooking. Don't forget the internal temp of the meat will rise after taking it out of the oven. Let it rest for 10 - 15 minutes before slicing the meat.
Mar 26, 2016 | Grilling
My ribs came out done but not fall off the bone tender. What cAn I do to achieve fall off the bone tender?
For pork ribs, start by cooking them for 2 hours, at 225, internal temp 160 degrees, then remove from the cooker and foil them.
Be sure to put some of your mop juice, or apple juice inside the foil packets to help them steam and get tender.
Smoke them in in the foil for about 1:45 to 2 more hours. Remove the ribs carefully and vent them. They will be fall apart tender now, and fragile. Let them sit.
After about 10 minutes they will have firmed up again enough to move them back onto the grill for glazing. Use some sauce or a finishing rub to taste.
Feb 16, 2015 | Grilling
Cooking Time
Google "Smokering" and you will find a lot of forums dedicated to smoking food. It is an art in itself but many of these forums are helpful in learning.
The answer to your question is basically put as many racks of ribs that fit without touching and as long as the temperature is maintained they will all cook at the same time. I typically smoke my ribs at 225 for 4-5 hours.
May 24, 2010 | Masterbuilt 20050106 Propane Smoker
How do I smoke pork ribs in the char-broil gas smoker? How long to smoke ribs and at what tempeture?
use a drip pan with some water or apple juice, they should cook approx. 2 1/2 hours at 325.
Feb 20, 2010 | Char-Broil CharBroil 4637318 Grill
Grilling Logo
105 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
