Question about HP Photosmart C3180 All-In-One InkJet Printer
Label stuck inside HP Photosmart C3180
I was photocopying labels and one detached from the sheet and attached to the printer rollers on my HP Photosmart C3180. It will not print now, surprise, and is giving an error message. I would like to open the printer up but do not know where to start. Thank you!
    President:
  • HP Master
  • 1,996 Answers
Follow the instructions given here, here & here for clearing a paper jam and cleaning the unit, and access the rollers from the back of the machine.(as described.) If you have problems clearing the error message, go to your home support page here, choose solve a problem, and see the error message solutions. As a last resort, reset the printer to clear a false error message.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 24, 2009
HP C3180 keeps grabbing multiple sheets of paper when printing.
One thing you can do is make sure you fan the paper before loading it. Sometimes the paper is **** together.
Another thing is your pickup/Feed rollers might be worn out. I'm sure your can find some new ones on HP.com.
Apr 15, 2010 | HP Photosmart C3180 All-In-One InkJet...
I WANT TO PRINT LABELS ON A HP PHOTOSHOP D5360
You may want to check the ensuite software that came with the printer, and see if it offers label printing. More likely, you can access label printing templates in Microsoft Office or Works, perhaps even Openoffice.org's freeware.
Oct 22, 2009 | HP Photosmart D5360 InkJet Printer
Help! Sticky label stuck on roller
Carefully peel away the label from the roller.
Then, CAREFULLY apply an adhesive remover to the area on the roller where the glue is. I highly recommend a product called GOO GONE. It works great and smells like citrus.
Apply the Goo Gone with a Q-tip, being careful not to let the solution get on any other part in the printer.
Oct 08, 2009 | HP Photosmart 3310 Printer
Label misalignment for 14 label per sheet
Open the rear door and clean all rubber rollers with alcohol
Jun 27, 2009 | HP Officejet 4315 All-in-One Printer
QL-550 Label Stuck
Normally theres a lever you pull (the same one you use to manually pull the labels through), if you pull that, you should be able to blow the label out, or pull it through.
Apr 24, 2009 | Brother P-touch QL-550 Thermal Label...
HP 3210 getting paper jam because label stuck on roller.
I ran heavy card stock through printer several times, it caught the label and pulled it out on the paper eventually.
Feb 04, 2009 | HP Photosmart 3210 All-In-One InkJet...
Lexmark T640 won't print on label sheet a SECOND time...
try changing feed rollers. For a quick fix, remove the rubber rollers and flip them inside out. It should work
Jan 28, 2009 | Lexmark T640 Laser Printer
C3180 HP
Give it a shake.  There is a little switch that detects when there is / isn't any paper in the printer. It may be stuck.
Dec 10, 2008 | HP Photosmart C3180 All-In-One InkJet...
I am trying to print using Avery 8663 clear mailing labels using my HP Photosmart 3310 all in one. The printer keeps shooting out the paper with the message "please remove the paper and re-insert it with...
Does it still print on plain paper? Check to see if you are missing one or more labels as they may have come off and onto a roller or other part. I've found that label sheets with any labels removed prior to printing are always prone to loosing labels in the process of traveling through the printer.
Dec 07, 2008 | HP Photosmart 3310 Printer
Jammed Photocopier
I would suggest that a label came to be attached to the photorector drum. Unless you can remove this label the problem will continue
Dec 21, 2007 | Konica Minolta DiALTA Di200 Copier
HP Photosmart C3180 All-In-One InkJet Printer Logo
300 people viewed this question
Seeker5211
Seeker5211
