Question about Garden
Drive chain and sprocket operating but impeller does not engage, just turns freely. Eaton Viking 21" single stage snowblower. Possibly Model 6703 or 6723, Very old machine but had worked fine.
2 Suggested Answers
SOURCE: Auger on snowblower doesn't engage
how do I find good anime movie on Netflix help me fam
Posted on Feb 11, 2015
Troy-bilt snowblower smokes when I try to engage auger. It’s the belt burning, but do I simply just replace the belt or is it something else that’s causing the belt to burn?
How old is it? Model? Can you move the auger single stage or augers 2 stage by hand when in neutral. Could be a ice jamb. or bad bearing. Do this with the unit NOT running. If it's a 2 stage take a 2X4 and insert in the chute
and try to wiggle or move the impeller. Bent impeller/auger? Maybe. check them visually.
Hope this helps.
Dec 26, 2017 | Troy-Bilt Garden
How do i unlock brake on a Poulan wildthing 2375 chainsaw
First, stop your engine. Check to make sure that the chain brake isn't engaged. The chain brake can activate automatically by a sudden movement or impact. You can disengage the chain brake by pulling the chain brake hand guard back against the front handle and releasing slowly. If the chain brake is disengaged and the chain does not turn; turn off the saw, then check the drive links on the chain, the bar groove and the sprocket nose on the bar. A burr on the drive links will bind the chain in the bar. If the bar has been pinched, the chain will not pass freely through the groove. If a sliver of wood has gotten into the sprocket nose, it will not turn at all. Also, look at the drive sprocket on the saw itself to see if it has a groove worn into it. A drive sprocket with a groove worn into it will damage the chain.
Sep 12, 2016 | Poulan 2375 Wildthing Chainsaw Gas / Fuel...
I have an MTD single-stage snow blower that I replace the other the cable and the belt and under a load it's still not throwing snow
There should be 2 holes on the handle that engages the auger belt, use the top hole as it will increase the belt tension.
Check the condition of the rubber auger's rubber paddles as they are subject to wear and should be replaced if any signs of excessive
wear is present.
Jan 31, 2016 | Craftsman 21" 179cc* Single Stage...
Does 4-stroke and 4-cycle mean the same thing?
yes ... intake, compression, power, exhaust .... vs 2 cycle which mixes them down to two.
Mar 30, 2015 | MTD PRODUCTS INC Craftsman 21" 179cc*...
Feb 11, 2015 | Mtd Garden
Replaced shear bolts now engine will not turn over
Well look in the Housing to see if ther is something stopping it from turning over or the chain is stuck in drive and not movin
Feb 06, 2014 | Craftsman 21" 179cc* Single-Stage...
Not getting any gas
Most people leave gas in the tank year round. This is a problem for engines that are only used a few months out of the year. Old gas will cause the carb to gum up and not allow gas to pass thru into the combustion chamber.
You will need to pull the carburetor part and clean it.
check out this YouTube video. It shows how to clean a single stage snowblower carb
Dec 15, 2013 | Poulan PRO® PR 621 Single Stage 21 in. Gas...
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
