When pushing the Chanel button up until the TV turns off..Do I push the Chanel button on the TV or do I push it on the remote
  • 14 Answers
SOURCE: remote
pawnbrokers carry tv's just like yours for under 50 bucks, i'd go that method.........
Posted on Dec 28, 2007
SOURCE: tuning TV onto AV chanel
How do I get the TV screen back to an AV chanel?
I cant get a slide show to view on the TV screen.
Posted on May 19, 2008
SOURCE: ilo-32hd tv only 1 chanel
dude it just happened to mine it sucks!
Posted on Sep 29, 2008
rulds2008
  • 3866 Answers
SOURCE: tv shuts itself down
This is due to bad caps read here what a cap is www.badcaps.net see you tv is getting hot as normal but the caps cannot stand it any more thus shutting the tv down. The bad caps would be more or less in the power supply unit of this TV. So you can buy a new psu or get it repaired by a expert.
Posted on May 25, 2009
ArcAiN6
  • 152 Answers
SOURCE: My TV shuts itself down by itself
Agreed, one of the problems is power supply problems, also, overheat protection may also be the cause, make sure the internals are dust free, compressed air works wonders, remove the back cover, blow as much of the dust as you can off of the componants, replace the cover, and see what happens...
NOTE: If you are using a home / shop air compressor, make sure to have a vapor filter to remove any moisture from the air lines. water + electronics = BAD
Posted on May 29, 2009
How can I program my RCA universal remote to my element tv , what button to press for the light to blink and the code to put so it can work on my tv
RCA does not have for a code Element TV. With that being said there is a work around:
Turn on your TV.Then push the code search button until the LED still ,when the LED keeps on let go the button now push and release the TV button then push and release the power button until the TV goes off, when the TV turn off stop to push the off button now push the set button the code are already set on the remote control( you might have to push the off button almost 100 times or more until you get the right code for your TV. Best of Luck
Aug 26, 2015 | RCA Televison & Video
Why won't my samsung smart tv emote wont change chanel
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
  1. TV off
Within 3 feet of TV
PAIRING and RESET buttons:
Please rate if Helpful.
Good Luck !!
May 25, 2014 | Samsung TV Remote Control
I have urc-22b remote control but i dont have the code for my tv which is techinka
Try this:
Manually turn on your TV.
Then push and hold the code search button until the light stays lighted. Release the button.
Push and release the device button you want to set (i.e. TV)
Now push and release the ON/OFF button until your device turns off. When your device turns off, stop and push and release the enter button to store the code.
Warning: You may push and release the ON/ OFF button for almost 200 times.
Good luck.
Aug 11, 2010 | One For All URC-3021 Remote Control
I have a remote that i have had for a while and it stopped working. I changed the batteries but it still doesn't work. I have the codes for it but i missed placed the instructions on how to set the code....
turn on manually your set (tv), push the code button on your remote control until led light, release the button, the led still ligth. push the tv button one pulse, push the power button several times until tv turn off. when this happen push enter button... try turn on the tv with remote control.
Mar 20, 2010 | RCA Universal Remote Control
Need program instructions
I need the model receiver you have to do this.
Jul 25, 2009 | DISH Network IR Remote Control
I have a Durabrand 1304D 13" TV and my daughter lost the remote. I bought a BIG SENTRY UNIVERSAL remote and Durabrand is not listed. I know others have similar problem. I've tried to use other codes but to...
get a G.E universal remote with code search. do a code search for tv push chanel up untill the tv changes and push mute. the remote cost about $8.00
Apr 13, 2009 | Durabrand BH1304D 13" TV
Codes to program the RCA Universal remote control for a Magivox T.V.
My dear friend if your remote control got the code search button try with this.
Push and hold code search button until the led stand lit,now release him push and release the tv button the you need to push and release the power button until the tv set turns off push and release the button set and the code get in the memory of the remote.
You need to turn the tv manually.
Good luck
Sep 13, 2008 | Televison & Video
RCA universal 3 digit remote code for diamond vision TV
turn on your tv.Then push the code search button until the led still ,when the led keeps on let go the button now push and release the tv button then push and release the power button until the tv goes off,when the tv turn off stop to push the off button now push the set button the code are already set on the remote control( you might got to push the off button almost 100 times or more until you get the right code for your tv.Good luck
Aug 09, 2008 | Televison & Video
Lost codes
Try this turn on your tv manually,Then on the control remote push and hold the code search button until the indicator light stays lit,release the code search button now push and release the device button TV and next you gotta push and release the power button until the TV turns off ( you might do this per about 150 times be patience) when the tv turns off you push and release the Enter button and the code be saved.
Good luck.
May 10, 2008 | RCA Universal Remote Control
RCA systemlink 3 remote
My friend you gotta turn on manually your tv first.Then push and hold until the indicator light lights,then release the code search button now push and release the Tv button after that you gotta push and release the power button until the Tv turns off then you push the enter button to save the code.Good luck.
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
