Question about Delta Home
The hose was for a Delta hand held shower - where can I get the nipple. Ferdinand T. Ruffino
  • 297 Answers
SOURCE: Leak in hand held hose, Delta In2ition
you must be missing a washer or gasket that goes in the hose end, of the hose try teflon tape,this is all your plumber is going to do.
Posted on Jul 17, 2009
  • 843 Answers
SOURCE: Can the hand-held shower hose be replace without
No, you need to cut a hole. Usually an access panel is provided during the initial installation, either in the ceiling from downstairs or in the other side of the adjacent wall. But it's pretty easy to add one. After you cut a nice rectangular hole, you can cover it with a piece of painted plywood that has a trim piece attached to the plywood. The plywood is held in place with a couple of screws. When you remove the panel, the trim stays attached to the plywood. When you place the panel in the hole, the trim covers the gap between the drywall and the plywood.
Posted on Dec 01, 2010
  • 528 Answers
SOURCE: where is the filter screen in my delta hand held
I is at the end of the hose where it attaches to the hand held head.
Posted on Jan 31, 2011
  • 27 Answers
SOURCE: I just installed the valve
Assuming that your two heads are fed from the typical curved wall mounted shower pipe, what you need is a diverter valve. Removed both heads till it's down to just that curved pipe. Get a diverter valve from a plumbing supply store. Tell the sales folks that you want to install a diverter valve so that in one position, the hand held receives water and in the other, it cuts the hand held and puts it to the reg. shower head instead. They should give you a "T" sort of fitting. The female threads of this screws into that curved shower pipe. Then you will find two male thread ends. These connect to both your shower heads. Finally there will be a push/pull knob that is operated to control which head gets the water.
Posted on Feb 15, 2011
  • 12 Answers
SOURCE: Delta hand held shower head with adjustable spray
Unless you live in a very hard water area, soaking in vinegar will do nothing. Don't waste money on stronger solvents which will likely harm the finish... and void your warranty! The problem is sticking swelled rubber o-rings/seals inside the head, that can't be fixed. Instead, take advantage of Delta's lifetime warranty and return the shower head for a warranty exchange.
Posted on Oct 06, 2012
How do install delta shower
If you are looking to replace only the shower head, you'll need two plumber's wrenches, a cloth, and Teflon tape.
First and foremost, read the install instructions that come with the new shower head...
After you clearly understand what the instruction's say, shut of the water supply lines for the hot & cold water.
Take one of the wrenches and apply it to the neck of the water supply tube coming out of the shower wall (a.k.a. goose neck or supply nipple, or arm, depending upon the design). It'll have male threads (the threads are on the outside of the fitting). I would place a cloth of some sort around it before placing the wrench on it so you don't mar the finish of the water supply tube.
Place the second wrench on the shower head assembly (which has the internal, female threads). and unscrew it by turning the shower head assembly counter-clock-wise (to the left) while holding the water supply nipple with the other wrench.
You need to do this, so you don't snap or deform the water supply nipple coming out of the shower wall- and/or possibly causing leaky damage to the fittings behind the shower wall.
To replace the shower head, you reverse the removal process- the only difference is, you wrap Teflon tape around the male threads of the water supply nipple before spinning on the new shower head.
Somethings to be careful of, and I can't stress this enough, DO NOT cross thread the new shower head onto the water supply nipple. You should be able to screw it on the new shower head by hand- where it is hand tightened- then using the double-wrench method that you used to take off the shower head, turn the new shower head an additional half to three quarter turns with the wrench, clock-wise; and I mean gently.
Here's a nice short video on the subject, illustrating my instructions:
Jul 27, 2014 | Delta Faucet Home
Where is the filter screen in my delta hand held shower head
Jan 31, 2011 | Delta RP48770PB Traditional Three Function...
Instructions for item rp32539 for instalition
You can get the install manual on link below.
Good Luck and please rate 4 thumbs for the free answer
Feb 24, 2010 | Delta RP32539 Chrome Classic Multi...
No hot water
you have to take the handle off
there should be an insert that you can adjust by pulling out and turning
May 28, 2009 | Delta & Single Handle Shower Faucet
May 18, 2009 | Delta & Single Handle Shower Faucet
Water trickles out of hand help head
the problem is probably not in the actual head but in the valve body where the diverter is attached. It is easy to google something like "how to change the washers on a faucet" and you will find step-by-step instructions on how to do so.
May 16, 2009 | Delta Faucet Delta 75582 In2ition 2-in-1...
Bathroom stall shower
Most handheld showers use a hose to connect from the existing shower arm down to the hand held option.  Some units come with attachment points on the shower arm, but I believe that you are looking for a unit that has a hook that you can mount where ever is comfortable for you.
Oct 16, 2008 | Home
Home Logo
21 people viewed this question
Top Delta Home Experts
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
