Question about Miele Dishwashers
Miele dishwasher isn't draining well and not cleaning effectively.
  • 9 Answers
SOURCE: Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Posted on Apr 20, 2008
SOURCE: dishwasher stops after 10 minutes inlet/drain light flashing
I had the same problem on a 5 year old model. It was the main pump leaking from a perished seal causing the water protection microswitch to trip. This gives the symptoms you describe exactly. Parts cost from Miele was about £60 for a new seal. Fairly easy to fit.
Posted on Jul 21, 2009
joe_lishman
  • 192 Answers
SOURCE: Inlet/drain light flashes on miele dishwasher and
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified
Posted on Jan 17, 2010
  • 177 Answers
SOURCE: Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Posted on Mar 02, 2010
  • 177 Answers
SOURCE: my miele dishwasher shows intake/drain light
hi, firstly check the filter in the waterproof system where the tap is to make sure it is not blocked. turn off the water and remove the connection with the white box attached this is the waterproof system. remove the black seal and you will see the filter. pull it out with a pair of pliers and clean it.
if this is ok check to see if you have a restrictor on the tap or inside the tap and also make sure water is flowing from the tap prior to reconnecting the waterproof system.
run the unit again and when it is time for the machine to call for water you can manually fill it and see if it works using a saucepan or bucket. if this works ok you may have a stuck waterproof system and probably need to replace this.
Hope this helps
Posted on Jun 26, 2010
How do I fix a Miele G2470 SCVi with an intake/drain fault
Look for item(s) blocking the drain, inside bottom, and remove them.
May 24, 2014 | Miele Dishwashers
My knives come out dirty
Hi useonlysomet,
Please check this following link, it contains some helpful suggestions to get your Dishwasher cleaning well again:
WHAT TO DO IF YOUR DISHWASHER ISN'T CLEANING WELL
Kind Regards :-)
* If you found this solution helpful, please rate it?
Jun 19, 2011 | Miele Dishwashers
Red intake light comes on and dishwasher will not drain, model g 843 scvi
The manual is available here: http://www.miele.ca/miele/canada/OperatingInstructions/manuals.asp?ParFolder=Dishwashers&SubFolder=Previous%20models . Scroll down through the list to the G643 G843 Incognito. The maintenance items listed below are detailed on page 44 and beyond of the manual.
The Intake light is also the Drain error light. If the light is flashing, then turn off the dishwasher and clean the triple filter, the drain pump and the non return valve and make sure that there are no kinks in the drain hose.
Make sure the water is ccoming in at a pressure above 4.5 psi. Also make sure that the water valve is open and clean the water intake filter.
The final possibility is that the Waterproof system has tripped and you need a Miele technician to service the unit.
I hope this helps.
Feb 19, 2011 | Miele 24 in. Incognito G843SCVi Built-In...
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
Water collected in bottom of dishwasher
This could be due to several reasons. The most logical is that the pump filter is getting clogged.
follow the instructions in the owner's manual to clean up the filter. Also the impeller arm will need cleaning if the dishes are not clean.
If the above does not fix it then more likely the drain outlet under the sink is getting clogged. Try and clean the drains.
Regards
Sam
Dec 15, 2009 | Miele Dishwashers
The intake/drain light is flashing. I've removed the drain cover, but dont see any blockage
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 03, 2009 | Miele Touchtronic G894 SC Built-In...
Miele Dishwasher is not cleaning dishes
check the filters. also check drain. Sounds like it's not fully draining and/or there is not enough water (ie. when filter are clogged)curculating to wash the dishes properly
Jun 08, 2009 | Miele 24 in. Incognito G843SCVi Built-In...
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
Miele dishwasher g664 12 years old maybe?
if the water drains into a bucket then the blockage will be in the drain spigot under the sink where the drain hose connects.hope this helps.
Mar 14, 2008 | Miele 24 in. G656SCi Plus SS Built-in...
Dishwashers Logo
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
