Question about Car Audio & Video
How do you change the brightness on the face of this stereo
The dashboard illumination is dim and won't go bright also the Foglights will not turn on and also the stereo is dim. Changed the light switch but still the same
is it adjusted by the light switch left on bright right dim all when lights are on all dash lights will dim thats normal
Apr 19, 2016 | 2008 Volvo XC90
I haVe a boss 9965i and the display on the face plate is not very bright any help?
There doesn't appear to be a setting which will change the brightness of the faceplate. Though some radios will change brightness when the headlights are on or off.
You could try resetting it by pushing the RESET button on the back of the faceplate.
Boss BV9965I manual
Check the manual for more information.
Aug 17, 2014 | BOSS AUDIO SYSTEMS Car Audio & Video
Dual CD770 (Same as XDMR7700) face stuck open (down)
Change the Flex cable that connects from main chassis to the front face plate. This is a common problem with Dual drop down face plates, since the flexible wires break and lose connection.
Mar 06, 2013 | Dual XDMR-7700 CD Player
How do i get lites on face they are dim
Check your car battery. Try to turn off your headlights and aircon then look at your stereo if its bright, if it has bright light try to turn on your aircon and headlights then if the light of your stereo turns dim the problem is now on your car battery. The battery cannot supply all the electricity needs of your car.
Jun 28, 2011 | Jensen CD-4010 K CD Player
Display dosnt work at all. it plays music fine i just dont see anything on the screen.
look and see if the yellow illumination wire behind the stereo is connected to the power wire, you may not have its lights wired up, this could cause you not to be able to see a display, to test this for sure shine a bright flash light into the face while its playing, if you see some display, this is the problem
Sep 24, 2010 | Sony CDX-F7000 CD Player
Car stereo is flashing ''protect'' on the detachable face-reason? stereo was working fine all day-got in truck tonight, turned on ignition ''protect'' scrolling across face-no sound-will not play cd-remote...
Thats the anti theft mechanism. usually theres a button, or switch you have to press or change somewhere on the stereo. Usually on the base part behind the detachable face.
Without knowing what kind of stereo it is I cant be sure, but some have security codes to prevent the use of it if you dont know the code. the combination needs to be entered with the 0-9 buttons, and is always a 4 digit combo. Usually when you set up that feature, it asks you for a custom security number and if you forget it, your pretty much screwed, as you have to remove the stereo, either find out the memory kill wires, and cross them, or open it up and either cross the memory wires or remove the eternal battery. If this is the case, you will need to have a trained professional fix it, car stereo's are very compact and will be almost impossible to re-assemble it yourself unless you have the proper tools to do it.
Chances are, theres a switch or button you need to use though. You might have acidently hit it without knowing it when taking the face off, or changing the vollume or station.
Mar 09, 2010 | Car Audio & Video
Changing the brightness Pioneer DEH-P5900IB
Try this:
turn the stereo off by holding the SRC button down, then push in on the center of the volume knob, select brightness and turn it down..
Dec 13, 2008 | Pioneer DEH-P5900IB CD Player
Car Audio & Video Logo
20 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
