Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
I am looking for a amana side by sid refrigrator door gasket Model # sr22gl/8705086417. They are no longer manufactured, is there any gasket I can use insted of it or do you know where I can find one?
    President:
  • Amana Master
  • 1,922 Answers
Try allpliace parts pros in ohio,they'ry on the web and you can shop online and if you can't find it you can e-chat or call theyre toll free phone.great people and prices are reasonable
Posted on Jul 24, 2009
Amana SZDE27MPE
check the gasket fist if it's ok check the closure.there's a door closure on the bottom of the door and hinge that wears out and needs to be replaced,is the fridge door when closed side by side lower than the freezer door?it's plastic,here's a picture
http://www.repairclinic.com/PartDetail/Closing-Cam/R0181181/1035
part number R0181181 but call your local parts store and give them your model and p number or manufactures number and they will sell you the correct part,on some kits they give you the cams,shims and new screws,as for the drip pan overflowing,this is most likely from the warm air getting into the fridge melting out the frost on the coil or ice,usually when this happens the air ducts freeze up and the fridge section gets warm because the dold air from the freezer can't blow over into the fridge side because the air ducts are filled with ice,shut down the machine or unplug it,remove everything from the door,remove the top screws and then tilt out the door and lift up,put the door on it's side and change out the cams,it's usually a 5/16 inch screw holding them in place and then put it back together,while you have the door out check the gasket,any rips or anything change it out.hope this helps and good luck.
Aug 27, 2012 | Amana Refrigerators
Hi, In my refrigrator there is no water and ice coming.and i dont find where is the fiter.my refrigrator type is 2255a mod # ed2choxkb07 ser,# issu4235315.thanks
Since you did not provide a model number this is the best guess. On 25 Cu Ft and above models no matter the manufacturer most of the filters are in the left portion of the grille at floor level. You turn the tab and the filter pops free. If yours is not in this are just respond here with a model number and I will help you.
Kelly
Oct 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have an Amana side by side refrigerator model SXD225SW and the other day water began leaking from underneath the refrigerator. As the couple of days have worn on, it seems as though the amount of water...
Move the refrigerator out from the wall and look for the location of the leak.
Step 2
Check the side panels and the seals around the door for beads of "sweat." This could indicate a condensation problem.
Step 3
Check the floor. A puddle there could indicate a missing or cracked drip pan, or a leak in the water line that feeds your ice maker.
Step 4
Check for water seeping from the front of the freezer or the refrigerator. This could indicate your defrost drain is plugged or your ice maker is leaking.
Fixing a condensation problem
Step 1
Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely.
Step 2
Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets (see How to Fix a Refrigerator That Cools Poorly).
Step 3
If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls
Hope this helpout......
Aug 15, 2010 | Amana SXD524VW Side by Side Refrigerator
Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
Looking for a Amans side by side refrigerator, door gasket sr22gl
HI, you can purchase both door gaskets at the link provided below.
DOOR GASKETS
Jul 24, 2009 | Refrigerators
Amana refrigerator door gasket Model #sr22gl
You may wish to contact the folks at RepairClinic.com. They have a large selection or repair and replacement parts at a fair cost. You'll need to know your brand name, model #, serial #, and the approximate age of the appliance.
Need parts for an older side by side refrigerator
repair clinic may have it for you
http://www.repairclinic.com/Amana-Refrigerator-Parts?s=b1a4c238
I have had plenty of luck finding the parts I need. please clarify the part needed becuase alot of parts are used on different manufactured refrigerators. you may have to measure the gasket al the way around to get the proper part needed
Please rank my answer
May 26, 2009 | GE GSH22KGR Side by Side Refrigerator
Amana sid by sid ice maker
Replaced the water electric valve to the ice maker.
Aug 01, 2008 | Amana ACD2232HR Side by Side Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
106 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
