Question about HP Office Equipment & Supplies
My Hp designjet t1100 failed it was showing zero percent, then showed error 08:11. How can I fix that problem? Thanks for any help
SOURCE: hp 4350 error code 50.3
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell Mpundu@technet.co.zm
Posted on May 28, 2008
  • 33 Answers
SOURCE: 47.01 error
System Error: 47:YZ
Problem
Description:
Star wheels motor error..
Corrective Action: Try the following:
�� Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Reconnect the power cord and power On the Printer.
�� Check that the Starwheel Assembly cable is not damaged and is correctly
connected to Main PCA.
�� Open the Window and check for any visible obstacles restricting the
movement of the Starwheel Assembly, then clear the obstruction.
�� Perform the Scan Axis Starwheel diagnostic test to troubleshoot the
problem further → Page 4-7.
�� Replace the Starwheel Motor → Page 8-177.
�� If the System Error continues, replace the Main PCA
Posted on Nov 07, 2008
SOURCE: hp designjet 500ps having problem
system error 81:01
Posted on Jan 07, 2009
SOURCE: HP designjet 500 the system error 21:10
I recently had this problem as well and it was the service station gunked up with a bunch of ink over the years. Remove the right hand cover of the plotter. Remove the 2 screws that hold the service station in place and slide to the right to remove. When removed, take off the small motor by the gears. The rest is all plastic, I removed the 3 screws and "popped" the two black parts apart and cleaned the spitoon, which is just a sponge. I then dropped the thing into the sink and poured dishwasher soap. Let it sit for about an hour and rinse. It is really really messy. Then put the whole thing back together again. If I recall, the motor was the only electrical component.
Use care and caution so as NOT to break anything and I recall that the only electrical part was the small motor by the gears.
This wasn't so bad and I spent about 8 hours just because I was exercising much caution. If you're more mechanically inclined on the first go, then I would guess about 1 hr to clean and another 1 or two for dry time.
This SOLVED my problem and WOW there was a bunch of ink over the years. Don't worry, that is what the "spitoon" is used for to soak up the excess ink. Well, if not maintained or replaced, then the ink gunks the insides rock hard as in my case.
A new station is about $160 bucks. If you have HP install then you are looking at a few hundred more on top of that. To me, it was worth it and if it didn't work then I just get a new one and I had nothing to lose since the plotter was getting past the 21:10 error.
Be sure to download the HP Service Manual online so you know how to remove the service station. It is just 2 screws. Without the manual, I probably would have taken off many more screws as I would not have thought the service station simply slid out to the right. The designjet is well designed and was glad that I found a service manual online.
Good luck and use caution,
Posted on Feb 15, 2009
SOURCE: system error 1290 on Designjet 9000s
System error 1290 on Designjet 9000s
Posted on Jun 04, 2010
Hp designjet t1100 blank hard drive installation
Unfortunately I had a similar issue with an HP A0 printer. The Hp 'Engineer' could not fix it. The hard drive had failed and there is a complete new hard drive with software loaded available but only through Hp.
Feb 27, 2014 | HP Designjet T1100ps Printer
Error code 02.1.10
02.1:10 service station error- failure to reach home position .
you need a service tech to replace the service station within the plotter
Aug 14, 2013 | HP Designjet T1100ps Printer
How to resolve eror code 47.01 hp designjet T1100
this error code is Starwheel Motor failure.
Feb 25, 2011 | HP Designjet T1100ps Printer
Hi ! can you tel me how to resolve eror code 47.1 for hp designjet t1100
I have this error with my Designjet T1110. I followed the instructions in the service manual 2-14 for troubleshooting.
questions:
- instructions say :"Check that the Starwheel Assembly cable is not damaged and is correctly
connected to Main PCA." but I could not locate any cable from the starwheel assembly to the main PCA. I could see only cable from the starwheel motor assembly to the main PCA.
Feb 25, 2011 | HP Designjet T1100 Photo Printer
08:11 error in hp designjet t1100
I had this code recently, and solved it cleaning the contacts pins in the formatter whit 2000 sand paper (could be pencil rubber) and reseating it.
Oct 01, 2010 | HP Designjet T1100ps Printer
When I turn on my HP designjet T 1100 I get error message 08:11
turn off printer, disconect hdd from pcb, turn on then printer beeps, turn off mount hdd back, turno whait ;).
Mar 19, 2009 | HP Designjet T1100ps Printer
47.01 error
System Error: 47:YZ
Problem
Description:
Nov 07, 2008 | HP Designjet T1100ps Printer
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
