Question about LG Televison & Video
Hello guys I have LG 55" smart TV model# 55LX6500 ,screen is dark and no audio,only i have led for power,when TV is on I can't see anything even whit flash light on screen Appreciate if you can help
danasaur
  • 77 Answers
SOURCE: Toshiba power led flashing yellow
This flashing LED usually means only two things, both are quite harmless:
1. Some laptops will flash the power LED when battery is charging. If this is the case, it should stop when battery is fully charged. This can be presumed if the laptop starts normally while LED flashes. If not, suspect step 2 below:
2. Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
Look for a symbol on keyboard for "sleeping" (like a half moon with zzzz) and press that key WITH whatever color coded key matches the symbol color (usually "FN" key). If there is no suchkey, press the space bar and hold it down a few seconds.
Then wait. Can take 60 seconds to "wake up" on slower processors.
If this does not work, press AND hold the POWER button for 10 seconds. Then wait 60 seconds and press power key again, briefly, to start laptop normally.
Pressing and holding the power button 6-10 seconds forces a complete system shutdown.
If this happens often, something may be wrong with APM or ACPI settings/driver. You can go to start menu/settings/control panels/power management and adjust settings (or disable sleep/suspend and hibernation if all else fails to resolve situation)
good luck.
Posted on Jun 08, 2008
  • 16 Answers
SOURCE: green led light flashing on 700p proview flat panel and no picture
I have a similar problem.
Switching the screen off (front panel button) and on again after waiting a few seconds fixes it.
This is a recent problem, so I'm expecting it to get worse and worse until one day!!!!!!
Posted on Feb 10, 2009
Usually when the power light flashes and the screen remains blank and unlit, your power board is in fact malfunctioning. This is not always the case, as the problem can sometimes reside in the input or inverter boards. I would first recommend that you feel comfortable with opening up your screen and looking at components. It can be a little overwhelming at first. BEFORE PROCEEDING, UNPLUG POWER TO MONITOR. If inclined to check, carefully open the casing around your screen. I have not worked on your particular model, but some are easier to open than others.
Once opened, you need to gain access to the circuit boards. Sometimes they are not protected by metal, other times they are completely encompassed. The flashing power light usually indicates that a capacitor(s) is(are) malfunctioning. To see if this is the issue, locate the power board (usually the one with larger-size components) and look for any capacitors having bubbled or raised tops and/or oozing a brownish liquid. If not on the power board, look elsewhere for the same symptom.
PLEASE BE CAREFUL!!! If you have recently had your monitor plugged in, the larger capacitors can still carry a charge. If you cross the leads of a capacitor while it carries a charge, it will discharge. It won't hurt any other components, but if you cross the leads with something that is in direct contact with yourself, you can get quite a jolt! There is usually a large voltage capacitor (normally just one) on the power board of these screens. I tested one with a multimeter after immediately unplugging it, and it still held a 166V charge! So please, do this with caution.
If a bad capacitor has been found, simply remove the old one and solder a new one in its place!
Posted on Mar 26, 2009
duane_wong
  • 6826 Answers
SOURCE: Hello have a problem with tv Model is: lg
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6281
The above link goes to lg's website describing the red flashing light where the power switch is, and
another switch down below which can turn that light off.
Try switching that other switch below off so the light turns off. Then, switch it back on.
If that doesn't work, then service should be scheduled for this discontinued model.
Hope this helps on your lg tv.
Posted on Jul 14, 2010
  • 8909 Answers
SOURCE: hello. i have a problem whit my dell 1525 pp29l
If it cannot finish POST then you have a mother board problem.
You state you reset the BIOS. Can you get to the BIOS menu? If you can then the problem is not motherboard errors but hard drive boot sector problems, depending on OS used.
If the BIOS has been updated, then it is possibly an incorrect version or corrupt.
If you can reflow the soldering, remove the BIOS chip and fit a known good one. That should fix your problem.
Hope this helps.
Posted on Nov 23, 2010
I have an LG 47GA6400 TV. I have 2 large vertical lines on the screen. I need help identifying what is causing the lines. Could it be the t-con board?
PEOPLE, YOU MAY DON'T NEED TO BUY T-CON CARDS OR ANYTHING LIKE THAT, THE FIXING FOR THIS PROBLEM COULD BE VERY EASY, MOST OF THE TIMES IS A FAULTY CONTACT IN THE RIBBON CONNECTOR THAT FEEDS THE LED SCREEN AND THIS FIX APPLY FOR SO MANY BRANDS, MODELS, OR SIZES OUT THERE, GOOD LUCK!. DISCLAIMER: THIS VIDEO IS FOR REFERENCE ONLY AND I WON'T BE RESPONSIBLE FOR ANY FURTHER DAMAGES OR INJURIES YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!. THANKS FOR LOOKING.
SHOW MORE
HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55 MODEL LG 55LX6500
Jan 29, 2018 | LG Televison & Video
I have a lg 60 in flat screen smart tv. When powered on, the screen flashes the LG logo then turns black. I can still hear the audio but no video.. any idea how I can fix this.
hi in a dark room shine a flashlight on the screen see if you can still an image if you can, the led or leds has shorted in the panel thanks
shaun
Mar 08, 2017 | LG Televison & Video
Ive got a LG 55" LED tv model #55LA6200 it will turn on and show the LG screen then goes black after a few seconds. Audio works and i can see the screen with flashlight which part do i need.
This could be the power supply at 55 dollars or the LED back light strips that are about 80. Unless you know how to test them, it is a toss up. Most of the time it is the led strips though. http://www.shopjimmy.com/lg/55la6200-ua
Feb 22, 2017 | LG Televison & Video
LG 55LX6500 55 inch LED TV display gone, but sound works.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
Jan 02, 2016 | LG Televison & Video
How do I replace SMART TV SCREEN MODEL NO : LG 55LM7600 55'' 3D 1080p Full HD LED LCD Smart TV
You cannot replace a screen that big. The manufacturers wont ship it to you. IT has to be done by an authorized service center.
Nov 21, 2014 | LG Televison & Video
When I use my lg 55lx6500 led 3d tv with my lg hr598d Twin hd 250gb blu ray there`s a audio sync problem I've hooked it up to anothe tv and it works fine, I replaced the 55 and still have the audio about 1...
Just looking for a solution to audio sync myself! I have hr598D and a new 50PX9500 plasma. Works fine as stand alone tv. Bluray and dvd seem ok maybe slightly out but playing tv and recorded stuff through the set the audio is miles out. Very frustrating. Hope someone has a solution.
Cheers.
Dec 03, 2010 | LG Televison & Video
Televison & Video Logo
57 people viewed this question
Computer Repairing
Computer Repairing
