Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Model # kv-32hs510 stuck in standby blinks 7 times
I have a sony trinitron television model KV-32HS510 I believe its about 4 0r 5 yrs old according to the manufactuer date. the tv has been off for 7 months since I was out of town came home and the standby light blinks 7 times then goes off, how can this be fixed
  • 1 more comment
  • mike moreland Jul 25, 2009
    sorry light is blinking 4 times. and the tv was unplugged for the 7 months I was out of town
    just took the back of the tv off to find locations of what I was looking for plugged it in and its back to blinking 7 times, what could that be does the ic8002 and ic 6501 make sense
    my sony model kv32hs510 is back to blinking seven times. any suggestions. does replacing the ic 8002 and ic 6501 sound like a good place to start?
  • 4,472 Answers
Yes I would try the IC 8002 first. Depending on your area alot of times you can get these tv's fairly cheap on craigslist. Also the D-board i believe is around 175$. If you have other questions or need further assistance please let me know and please don't reject my solution until I get a chance to do so.
Thank you,
Lee
Posted on Jul 25, 2009
  • 10,515 Answers
As per Sony, the 4 blinks refer to :-
No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505.
You will notice that 4 blinks has something to do with loss of the vertical deflection amplifiers. So, that would be a place to start. You must have a qualified tech do the actual diagnosis unless you are a tv expert yourself.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Why does my sony weta model KV-32HS510 stand by indicator blinks 6 times?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jul 31, 2014 | Sony FD Trinitron WEGA KV-32HS510 32" TV
What is the life span for the Sony Wega KV-32HS510?
10,000 continous woking hours is calculated to most of the CRT based TVs.
It is only calculation, but the life span might be much more that that. I've repaired a Sony TV recently, which was released by Sony Corporation Japan. The model is KV1820, an 18" Trinitron TV, still works perfectly. Just see, it is an '80 model one.
Turn on my Sony FD Trinitron WEGA KV-32HS510 32" TV, you hear a click, and then it blinks 3 times pauses and repeats.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. This is the fault with 3 blinks. If you wish to get more, check the site linked here.http://electronicshelponline.blogspot.com/ Pull up previous posts, either by brand search, or view it in Mosaic / Timeslide / Flipcard option.
Aug 18, 2013 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Problem with Sony FD Trinitron WEGA KV-32HS510 32" TV
Blinking of standby LEDs to Sony TVs are fault indications. Form the number of blinks occur at one time, the repairman can get an idea of the faulty stage inside it. According to you, it blinks 4,6 & 7. Just visit this site, It has details about blinking codes to Sony TVs, both CRT based, Flat panels and Plasmas. I can't provide more advice to you, because the number of blinks are not constant. Check the site, and get it.
Jan 22, 2013 | Sony FD Trinitron WEGA KV-32HS510 32" TV
My tv want turn on and the standby light just blinks 7 times
Do a google search for SONY LED BLINKS and select the second choice in the list. This is a known problem with these tv's it will require the two 18 pin IC's replaced on the D power board.
Good luck
Rich
Jun 06, 2010 | Sony FD Trinitron WEGA KV-32HS510 32" TV
I have the same Problem with my sony KV-32HS510
Your set needs two regulator ICs replaced and a capacitor . I recommend taking it to a sony authorized servicer.
Oct 06, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony wega kv-32hs510
place blow dryer on heat setting to rear of tv and try to turn on set after 5 mins...humidity sensor in board
Sep 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Kv-32hs510 6 blinks
This just happened to me. I was all set to send it out but there's a snowstorm right now. Thank goodness I checked another thread on Sony.com. Hold the setup button on the original remote while pushing the ON/OFF button on the TV at the same time. This worked for me. Here's the link I got this from: Good luck! http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=http--esupportsonycom-perl-tutorial-displaypltutid297templateid1regionid1KSMFlag7370&sliceId=&docTypeID=DT_TUTORIALS_1_1&dialogID=53101564&stateId=0%200%2053105132
Nov 04, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
The 7 blinks indicate an over voltage condition. The high voltage section has exceeded 33,000V. This is generally caused by a bad regulator. I don't have a listing for your model, but there should be a multi-pinned IC attachd to a heatsink marked STRxxx located close to where the AC cord comes into the set. Post the actual marking here and I'll get you the part number and cost. That is the regulator that may be the problem.
Dan
Jul 15, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
167 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
