Question about Dryers
My Electric dryer keep saying gong On/Off when drying bath towels ? Model number GDE5608W ,Haier Brand
  • Rohan Likedot
    Rohan Likedot Apr 17, 2017
    Hi Terry Hays, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • 17 Answers
SOURCE: Error Code
Here's some magic help on the dryers: I have a duet sport- Whirlpool hides the complete service manual inside the cover at the bottom front of the machine- remove the bottom 2 screws, drop the cover & you have all test & service instructions--- (:
Posted on Dec 16, 2007
SOURCE: Whirlpool Electric Dryer Won't Start
Your dryer has a non-resettable "thermal safety fuse" part number 3392519 which stops the machine dead when the temperature near the heater gets too high. Typically a restricted vent system causes this so you definitely want to check that before replacing it. A failed control thermostat can also cause this so check the operating temp too.
Posted on Dec 30, 2007
  • 148 Answers
SOURCE: Kenmore Elite Heavy Duty Dryer 11063012101 Takes Forever to Dry
I think your vent has lint in the line between the wall and the outside of your house not allowing the moisture to get out
FIX
1 when the dryer is running go outside and observe the vent to see if hot air is coming out
2 Turn dryer off, disconnect electric from wall
3 pull dryer out from wall
4 take a nut driver or screw and remove the clamp that attaches the flex vent pipe to the wall
4 Also remove the flex pipe from the dryer
5 Inspect inside vent connection inside dryer for any trapped lint
6 inspect inside flex line for any lint
7 Look inside wall vent for lint you can also reach in with your hand to feel for lint
8 If you have a leaf blower or can borrow one(electric is best) from your neighbor put the snout of the blower into the vent going into the wall seal the area between the snout and the vent pipe at the wall ( i use duct tape you can use wash clothes rags etc
9 start blower and blow any lint in the line out through outside THIS WILL CLEAR THE LINT
10 Reattach the flex to the wall vent and dryer , plug in. run a load and you should be back in business
Good Luck
Posted on Jan 05, 2009
SOURCE: I HAVE A WHIRLPOOL DUET
We had the same problem. Sometimes unplugging it for a few days, it would work when plugged back in. We replaced the user interface which is part #19 on the Whirlpool parts list, the front circuit board. The part alone was $160 at the cheapest place we found. http://www.appliancepartspros.com/
Posted on Feb 11, 2009
SOURCE: Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Posted on Jan 01, 2010
Removing ink from dryer
After trying all the suggestions mentioned, I tried nail polish remover and it worked pretty well. I only had the non-acetone variety on hand. I'm guessing the acetone version would be quicker so I plan on keeping that around 'just in case'.
It took about an hour to an hour and a half to clean it all off, it was all over ever bit of the inside of the dryer so it was pretty bad. Be sure have good ventilation. Take a deep breath BEFORE sticking you head inside the dryer drum and try not to breathe once your in there.
Also, be sure you check the area close to the dryer opening, the ink seemed to 'hide' there. I went over every bit of it twice (I had brand new white sheets to dry and wasn't taking any chances!). Rinsed it thoroughly with a very wet towel, did that twice.
Then I tried the suggestion about the towels with Clorox. I put two very wet bath towels (white unless you have old ones you don't care about) and poured about a quarter cup of bleach onto the towels. Then turned on the dryer. Did that twice also. Almost every bit of ink is gone. There are some small stains on the enamel that may vanish in time but they posed no threat to the new sheets.
I dried the sheets and they came out perfectly clean with NO ink spots on them. Success!
. Expect to use some elbow grease, but it worked!
. Good Luck to you
mjo
Jan 05, 2014 | Dryers
How can I keep my bath towels soft?
I also like fluffy and soft bath towels, I recommend that you check out this article with some really great tips for keeping towel soft and fluffy.
Sep 17, 2013 | Home
I have a LG Electric Dryer DLE5932W. When I run it on any of the settings in sensor dry the dryer turns off before the clothes are dry and you have to run it multiple times to get a load dry. Then if you...
this could be operator error please hear me out...... when wash bath towels you also put in wash cloths and hand towels .... there is a sensor in dryer drum shroud in front of lint filter to metal silver strips when the clothes are tumbling they sweep across this sensor telling the dryer heat to stay on and continue to dry.... if th small wash cloth sweeps it first before the bath towel then u get the same results as your describing just like if you were waqshing colors load like cotton tshirt and blue jeans the tshirt is going to dry way faster than blue jeans so if the tshirt sweeps that sensor first the dryer going to shut off we have to sort our clothes to thickness ans same size articles just try it once i bet your clothes are dry when cycle completes
Jan 31, 2011 | LG DLE5932W Electric Dryer
My Haier Dryer Model #HLF11P will not heat at all and it will not stop tumbling.
http://www.diylife.com/2008/01/28/fixing-a-clothes-dryer-that-wont-dry/
Oct 17, 2010 | Haier GDZ5-1 Electric Dryer
If I put more than 2 bath towels in the dryer the breaker goes off?
either your motor or idler pulley bearings are dried out and lugging motor down causing increased current flow till breaker opens up
Oct 03, 2009 | Whirlpool GEW9250 Electric Dryer
Bath towels have a sour odor after we dry off with after shower.
Most of the time this is caused by your water. Try doing a load of laundry with a gallon of bleach before you do your next load. Then make sure you use some sort of softener with your clothes for washing and drying. Don't go cheap with this select a good brand. When your not using your washer try and leave your lid up, if a front loader leave it cracked. This will let it breathe and mildew will not build up from your water still at the bottom and in your lines. Let me know how this works for you.
JimmyC
Sep 26, 2009 | LG DLE2532W Electric Dryer
Dryer just stopped working in mid cycle.
Verify there is still power at the wall and check the thermal fuse.
Eric
Jul 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer sped too fast?
Put a couple of clean dry bath towels in with your knit shirts.......problem solved
May 29, 2009 | Whirlpool LEB6300 Electric Dryer
Bad smell
washers and dryers dont make smells themselves its a problem with something u might be putting in it. if u tend to add alot more detergent then usual to your towels then they never completely rinse the water out and will have a mildew smell
Feb 18, 2007 | Whirlpool GEW9250P Electric Dryer
Dryers Logo
22 people viewed this question
Top Dryers Experts
