Question about Bosch Washing Machines
HAVE A BOSCH CLASSIXX CONDENSER DRYER KEEPS SWITCHING OFF AFTER A FEW MINUTES
    Welcome Back:
    Visited the website for 2 consecutive days.
Have you tried cleaning out the metal concertina-like element inside the bottom trap door? This clogged up caused mine to stop & also to drip some water on floor
Posted on May 04, 2017
SOURCE: bosch classixx condenser dryer how
Pay me, I tell you. I am an Engineer, why work for nothing when we can rip you off, and take OAP life savings for a simple fix ; )))
Posted on Mar 06, 2009
SOURCE: Bosch Condenser Dryer Classixx
I found this on justanswer.com, I am going to try it this weekend and I will post an update.
"Ok if you remove the left hand side panel then located at the back is the drain pump
remove the hose on it which goes up to the bottle and blow up it to make sure its clear.
If thats fine then remove the pump and clear any fluff thats in there and make sure the impeller is ok and turning fine.
Then refit and try again hopefully this should sort it out.
let me know if you need anymore info."
Posted on Jan 02, 2010
sonicboomele
  • 1557 Answers
SOURCE: bosch classixx condenser dryer won't turn on
try replacing the thermistate fuse link
Posted on Jul 04, 2010
  • 414 Answers
SOURCE: manual for WTE84105GB
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
Posted on Jul 08, 2010
Macmarkus
  • 2605 Answers
SOURCE: Hi Bosch classixx condenser dryer
Welcome to FixYa,
Based on your post it may just be the hi-limit has tripped. Here's what I'd do/check.
**Unplug the unit from the wall or switch off the breaker...safety first**
Once the dryer has been disconnected from any power, remove the rear panel...
i.e.
Once the panel has successfully been removed, you'll see the heater with the Hi-Limit and NTC attached. The Hi-limit is the thermostat with the red button in the center...
i.e.
push it in to reset it. As you can see by the images I've provided, if you have a multi-meter or ohm meter you can verify the proper values of the listed components.
If the hi-limit is tripped, obviously something triggered it, you can check the possible culprits such as the NTC's or heater with the info I provided above as I alluded to.
( Even so, I'd suggest running it through a cycle or two with clothes and monitor it's performance, it may have tripped simply due to poor air flow from a large load etc. and therefore nothing is actually wrong...human error )
You may run the dryer momentarily without the rear panel in place ( provided nothing electrical has been disconnected, don't attempt an entire cycle. ) just to witness the heater functioning, but it isn't recommended for much longer than a minute or two.
Thank you for choosing FixYa and please let me know what you find out or if you indeed require further assistance.
Good luck.
Regards,
Macmarkus :)
Posted on Dec 01, 2010
Why my bosch classixx keeps stopping every 5 minutes
The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 13, 2014 | Bosch Classixx WVF 2402 Front Load...
I have a Bosch Classixx Condenser Dryer which wont turn on - have cleaned out the filter - checked the fuse on the plug - still wont turn on. The model is WTE84107GB
Check the door interlock, this could be sticky or broken.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | Bosch Axxis WTL 6003 Electric Dryer
Hi I have got problems with my Bosch Classixx electric dryer It runs for a few minutes and then it stops I have cleaned the filter system etc and looks as clean as a whistle It seems to stop as it...
Clean the front under the lint filter has a sensor on the left near the lint pin. purchase a special long thin cleaner for vac from: All rand Vacuums 561-967-3575 GREAT
Sep 08, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Our Bosch Classixx Condenser Tumble Dryer works but there is no heat. I have cleaned the Condenser Unit and the filter and emptied the water, but still no heat. Please advise. Thanks Craig
my wte84105gb condenser dryer (bosch) as a symbol on it looks like a glass with wavey lines inside it will not dry please advise what to do .
Feb 26, 2010 | Bosch Axxis WTA4400 Dryers
Bosch classixx condenser dryer won't turn on
Dec 04, 2009 | Bosch Axxis WTA4400 Dryers
Bosch classixx tumble dryer container full light keeps coming on which is stopping the cycle but container is empty
This is happening me too. Have you had any suggestions how to solve this problem???
Nov 16, 2009 | Bosch Dryers
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Bosch classixx condenser dryer how do get to reservoir as its not pumping water up to condensing drawer
Jul 29, 2008 | Bosch Dryers
Washing Machines Logo
101 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
