Question about Ovens
We have a Delonghi DTC95 DF FSD oven/ range and the thermostat pilot light bulbs are not coming on although the oven is working correctly. Can these be replaced?
We have taken the screws out of the front plate that house the bulbs but cannot remove it
Buffalo12980
  • 625 Answers
SOURCE: SMEG SA708X Oven Heater problem
thermostat must be getting a blast of cold air from the door being opened.
Posted on Sep 06, 2007
SOURCE: Tappan Gas Range Pilot light went out.
throw the piece of **** out! nobody seems to know how to do this, and there is zero customer service or help available. there are problems like this all over the net with no answers.
Posted on Oct 30, 2008
aborcass
  • 2651 Answers
SOURCE: Replacing oven thermostat GE XL 44 (WGBS23WEA6WW)
i cannot look up the part diag. for the model you provided( no model exests), but for the most part, its a mater of unscrewing the burner heads fromthe maintop to allow yo to lift teh top further back, by lifting without uinscrewing them, you runn the chance of kinking/ loosing the gas fittings leading to them. In which case yooull wind up unscrewing htem anyway to repair the leak. As far as the capillary tube, it shoud push right through te opening in cavity where old one comes out
Posted on Nov 27, 2008
SOURCE: my tappan oven (Model 79
do you see a flame or just getting red.sounds like a bad ignitor
Posted on Dec 06, 2008
SOURCE: My Delonghi DE60PYROS needs a new thermostat, are
Ok get a Service Manual, and the Sensor, and it is not too hard.
Posted on Mar 29, 2010
Replace cooker element in delonghi dtc 90 df fsd
Kirsty
Open the oven lift the element and pull back. I have replaced many in multiple brands but make sure you get the correct one by getting you stove model info.
Sep 11, 2016 | DeLonghi Ovens
The Pilot Light on my Delonghi DEBIE 24 SS Electrical is on even though the oven is off - any idea how to correct this?
The pilot light stays on most none electric lighting for gas appliance, this is normal if you do not have an electric ingnition on your oven.
Hope this is helpful
john
May 17, 2011 | Ovens
Neff double oven u1442, main oven thermostat light does not work even though oven heats up. Is there a fix?
If the oven is heating up o/k, then I would suggest that the oven pilot bulb has failed, I have come across this on several occasions, it usually just means replacing the oven pilot light.
Mar 18, 2011 | Neff U1452 Double circotherm plus Electric...
Kenmore gas oven model no. 273 3248296 pilot free ignition wont fire up
Hi
If it won’t fire then it is possible that the oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.
The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's an internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.
If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.
The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Ovens
Frigidaire gas oven not heating
replace the bake ignitor its getting weak
Jul 01, 2009 | Frigidaire FGB24T3A Gas Single Oven
My g70m oven ignites and stays lit but it won't heat up it stays the same all the time
Hi
You have one of these faults:
Faulty FSD (Flame Safeguard Device). When you turn your oven on the FSD lets a small amount of gas through, after about 30-90 seconds the FSD is satisfied and allows more gas to come through......this then moves over to the.......
Oven Thermostat, this will sense the heat from the oven and adjust the temperature accordingly.
If the flame doesn't go high after 60 seconds it's the FSD, if it does but then it goes low and fails to increase then it's the Thermostat.
Either way you need to get a qualified gas engineer to look at it.
I hope this helps
Steve :)
Apr 05, 2009 | New World G70m Gas Double Oven
Kenmore gas range model # 362.7121191 oven
Could be the thermostat, glow bar, valve or wiring but usually the glow bar
Feb 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Bakers pride pizza oven not lighting
Hello. Usually this problem is related to the pilot being dirty, and not heating the bulb for the safety device properly/hot enough to fully open the valve. If you have a general purpose mini torch you can heat the metal bulb near the pilot with it, if this is the problem, the safety will open, and the main burner will come on. CAREFUL, you are not on/around the main burner, as it will allow gas to come on to the main burner, and if your pilot is not working properly, might not light the gas. Get the pilot cleaned and adjusted.
or... :) I know... your safety has failed, allowing gas to the pilot, but internally is not opening, this requires replacement. Last though, it could be your thermostat, its last in line, and would require replacement. The safety, and the thermostat are mechanical valves, open or closed depending on its function.
If you have a more current type, they will have a combination valve, and thermopile/thermocouple that are electromechanical, your thermostat at this point can be either mechanical, or electromechanical. This system has a few more possible causes for your symptom.
You can tell which you have by how you light the pilot, have a red button on the front of the unit, by the on/off valve? this is the first type.
Have to open a small door to access a knob, turn it to pilot, and hold in? this is the latter type.
ask if you need more help.
Hope that helps, and thank you.
Dec 17, 2008 | Bakers Pride Y-600 Gas Single Oven
Oven not working
Aug 23, 2008 | Bakers Pride Y-600 Gas Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
