Question about Samsung Televison & Video
Error code 39
On Samsung model rfg298hdrs/xaa
  • 556 Answers
SOURCE: Samsung Model Hlt6176SX/XAA has Check Fan No. @
The lamp fan needs to be replaced.
Posted on Jan 12, 2010
SOURCE: My Samsung Dryer (DV218AEB/XAA) Error code HE
invalid heating temp when running. call for service.
Posted on Sep 18, 2010
  • 6277 Answers
SOURCE: samsung model #WF448AAW/XAA will not
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please score accordingly.
Thanks and good luck!
John C
Posted on Apr 13, 2011
  • 75025 Answers
SOURCE: I bought a used samsung
Three digit universal remote codes to check with Samsung tV are:
004/ 005/ 009/ 015/ 104/ 105/ 106/ 109/ 133/ 172
Four digit codes are:
0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Posted on Jul 26, 2011
  • 43501 Answers
SOURCE: My Samsung DV219AGW/XAA dryer has no error codes.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Posted on Aug 21, 2011
No water when water filter is replaced for RFG298HDRS/XAA
You are not screwing the new filter in right/ it is not seating. I experienced the same problem; you need to "break the seal" on the new filter.
Apr 03, 2014 | Samsung RFG298HDRS 29 cu. ft. French Door...
Samsung eo error
The code means that the controller or main board is having an issue with the EPROM. Take the top off and you should see a tech sheet for service persons. IT will tell you the troubleshooting steps. BE SURE TO UNPLUG THE UNIT
Jul 20, 2013 | Dryers
No ice
Almost certainly you need a new icemaker. What is the model number of your fridge? The model number is normally inside on the left side of the fridge and also has a BOM number that ends in /XAA or /AA the BOM number would be more helpful than the model number.
Mar 13, 2013 | Samsung Refrigerators
I'm getting error code tE on samsung silvercare WF316LAS/XAA
tE is mostly related to
temperature sensor wire and connection problem. Look for a broken or loose wire.
Dec 07, 2012 | Washing Machines
E-33 The initial value of HEX is under "14" for 30 seconds while
a weight sensor in operation.
Nov 27, 2012 | Samsung RFG298HDRS 29 cu. ft. French Door...
Jun 07, 2010 | Samsung DV218AEW Electric Dryer
Televison & Video Logo
23 people viewed this question
Jerry Greenberg
Jerry Greenberg
