Question about Garden
Got gas leak on the front of a craftmen powerwasher 2800
Briggs 126t02-0521-b1 only runs with hand over intake on carb? Lots of suction .
Dirty carburetor . If it has a fuel cup on the bottom of carburetor take it off and clean it out real good Take fuel jet out and blow it out. If you don't have a compressor take a real fine wire and insert into the little hole in the jet and clean any dirt out. That is a good place to start cleaning. Quite often that is all you need.Be careful you don't loose any small parts and make sure the float is in place when you put back together. If the gasket is not seated right it will leak as well. If it has been sitting for a while dump the fuel tank and put clean fresh gas in it as well.
Dec 22, 2016 | Garden
Why is gas tank leaking?
you either have a hole in tank or a hose is bad, take some silicome and patch
Jan 04, 2016 | Garden
LEAKING SMALL AMOUNT OF WATER UNDER FRONT LEFT CORNER OF WASHER. LEAKS WHENEVER WATER GOES INTO THE DETERGENT DIPENSER.WHAT IS THE CAUSE?
Get a level and check the level of the machine. The front should be slightly higher than the back and even left to right.
Jun 02, 2015 | Maytag MVWB850YW Bravos XL HE Top Load...
Why does washer leak excessive water?
Some times the power washer are made poorly. If the leaks are at the hose connection you can replace plastic with a better one made of brass and the use of Teflon tape. Good luck
Sep 08, 2014 | FAIP Powerwasher Pw1400z 1,400 Psi 1.5 Gpm...
I just cleaned the carberator and new sparkplug it sounds like it not getting fuel when i put alittle gas in the carberator it starts and obviously stops? on my craftmen weedeater
if it is an older one, the gas lines like to rot away. you can usually tell by looking down inside the gas tank. you can also check to see if the primer is moving the fuel through the lines as you prime it
Jul 07, 2011 | Craftsman 25cc Gas Line Trimmer
Lavor Super wash Powerwasher.Lidl. Pressure leak O ring replaced at Venturi & wrote down wiring diagram for On/Off switch as follows- Blue Red Brown, Black. Had to disconnect wiring from On/Off...
hi i have a lavor 160 superwash all off the lances work except when i put the turbo lance on it gives high pressure and then goes to low pressure like starting then stopping can anyone help me or tell me what the problem may be
Feb 28, 2011 | Kitchen Ranges
I have a 12.5hp Craftmen riding mower with the
The battery or check cut off switch under seat if it disconected it won't run.
Jul 06, 2010 | Craftsman Garden
Excel powerwasher with B/S motor. Will start and
Is your air filter dirty? If so replace it. If it is still doing the same thing try this:
Turn off the fuel valve, or drain the gas tank, then place a rag under the bowl to catch the gas that will run out (the bowl is under the carburetor). Loosen the "nut" that holds the bowl on, and after the gas has stopped draining remove the nut and bowl. Blow out with compressed air, if available. Put the bowl back on and try to start it. If it still will not run off choke, the carburetor probably needs a good soaking or to be replaced.
Jan 25, 2010 | Briggs & Stratton Pressure Washer...
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
