Question about Garden
I am unable to pull the crank cord to start mower
  • 100 Answers
It's the petrol in the chamber creating hydraulic pressure..
Loosen the spark plug a few turn to remove to pressure then tighten back up and have another go.
Posted on Apr 17, 2017
The pull cord on my Husqvarna trimmer just spins
in the system there is a small lever that is pushed out to engage the crank pulley internally so that it spins the crank
this small lever breaks off and needs replacing
they are available from husqvana spares , and mower shops a sit is a generic piece common with all pull start trimmer engines engines
full the start assembly of the trimmer engine and take it in as a sample
Apr 27, 2016 | Husqvarna Garden
Suddenly cut out whilst mowing the lawn. now wont start, pull cord stiff to pull
Something just like this happened earlier this year with my pressure washer. This is what I did to fix it and now it runs great. Check the oil. If it's black or feels the least bit tacky, drain a pint or two of the oil out and re-add that amount of Marvel Mystery Oil. Now, attempt to pull the cord all the way out, but slowly at first. It should get easier to pull after about 5 pulls. If the mower restarts, let it run for 10 minutes until the Mystery Oil is hot and has cycled around inside the engine. Then drain that oil and refill it with a quality brand of oil. To top it off, either clean or replace the air filter, and put a shotglass of Lucas gas & injector cleaner into the mower's full gas tank. I also do this to my lawnmower and weedeater. It works wonders. BTW...If you're unable to turn the engine over by pulling the cord, remove the spark plug and tilt the mower up, so you can turn the blade easily by hand (use gloves). BUT FIRST MAKE SURE THAT SPARK PLUG IS REMOVED. REMEMBER... SAFETY FIRST! Let us know if this helped you any.
Jun 29, 2014 | Garden
Pull cord hard to pull since I hit tree root
see if the blade is bent the check the key under the flywheel
Aug 12, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Briggs and stratton lawn mower 4 stroke engine
did you hit something while mowing the key way between the flywheel and crank shaft might have sheared it will act like the blade is missing pull back on you while pulling the rope
May 25, 2012 | Briggs & Stratton Briggs Stratton...
Cub cadet walking mower, model 959468 can not pull cord to start
there is a the cable that goes to the handle you need to hold that releases the engine brake
Apr 04, 2012 | Cub Cadet Garden
I have a Troy-Bilt Briggs and Stratton 675 series lawn mower. The pull cord is stuck and will not move. I can lightly pull the cord repeatedly and the cord slowly allows me to pull more but if I release it...
Take the plug out and try to move the blade. If the motor won't rotate, the problem might be with the motor and the cord can't move because of it.
May 19, 2011 | Garden
I hit a stump and now it want start. It fired a couple of times and made a loud "clunk"!
Remove the plug wire and tip the mower on it's side. Pull the starter cord over and see if the blade wobbles. If so, check to see if it's the blade or if it's the crankshaft that is bent. If the blade doesn't turn while you pull the cord, it's most likely a broken crank or connecting rod which may be the cause of your "clunk".
Jun 11, 2010 | Garden
Pull start cord sticks, catches on something internally and I can't start the mower...brand new...
Make sure you hold the throttle bar firmly against the handle. If that doesn't work the cable from the throttle to the engine may need adjusting. The only other cause would be a damaged crank shaft.
Feb 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
