Question about Xerox Office Equipment & Supplies
I have replaced the accumulator belt on the Xerox phaser 7500 but the error does not go away. How do I clear the code?
pdouglasss
  • 125 Answers
SOURCE: xerox phaser 7700 having problems printing transparencies and accumulator belt problems
Hi xander4265:
I
Streaks in direction of paper travel
There are dark lines running along
the page in the direction of paper
travel from the leading edge to the
trailing edge (B-size print shown).
The printer displays no error code.
Note A-size prints are processed
through the printer with the short
edge of the print parallel to the
direction of the paper path --
making horizontal print artifacts
parallel to the shot edge of the
print.
B-size prints are processed
through the printer with the long
paper path -- making horizontal
artifacts parallel to the long axis
of the print.
1. Check the end of life for each of
the consumables by printing the
supplies usage page. From the front panel’s Printable Pages Menu, select
Print Supplies Page.
2. Run the solid fill test pages; From the front panel’s Printable Pages Menu,
select Service Pages, then select Print Solid Fill Pages. If the missing bands
only occur in a single primary color, replace the print cartridge of the affected
color.
3. Swap print cartridges and run another test print.
Note Under some circumstances, streaking may occur in the margin of
SRA3-size paper. This is due to the edges of the paper extending
beyond the end of the imaging components. print-quality in the
margins of SRA3 paper is not guaranteed.
4. Inspect the Accumulator Belt cleaner; replace the cleaner, if necessary.
5. Run the Remove Print Smears routine. From the front panel’s Support Menu,
select Improve Print-Quality?, then select Remove Print Smears.
6. Replace the Developer Housing Assembly (RRP 27, on page 7-171).
7. Remove the print cartridge and (with a flashlight) check for debris along the
edge of the developer housing.
3041-42
Leading Edge
hope that this will help you.
Posted on Jan 10, 2009
SOURCE: PHASER 7700 ERROR 30
Error 30 :Belt Home Too long
Posted on Apr 19, 2009
  • 17 Answers
SOURCE: Xerox Phaser 8500DN printer error : 09,037.45:67244
Please clear the ISC Fault (Ink Stick Count) from the Service diagnostic menu under function.
Posted on Aug 21, 2009
  • 21 Answers
SOURCE: We have an error that came up on our Xerox Phaser
clear tech faults
pulsa back + info + on (power on) hasta ver version firmware
navega hacia abajo en el menu hasta nvmram
Posted on Dec 02, 2009
  • 1833 Answers
SOURCE: xerox 7500 I replace the accumulator
When you get this error for 3 consecutive times then it keeps coming even the error has been rectified. It will keep coming even if you turn the machine off and on. The solution is that you have to download the Error30_snippet and send it to the printer. HEre are the links for Windows and MAC
When you download you will get a read me file. This has the instruction about how to perform the steps.
Posted on Feb 22, 2011
042-326 error code on Fuji Xerox ApeosPort II 7500
Not good news.
The ibt belt needs replacement. This is a large smoth blackbelt also known as a accumulator belt. It has a silver reflective marker on its edge and due to wear or damage the sensors cannot see it as it rotates. It will require replacement by a technition.
Jan 27, 2015 | Xerox Office Equipment & Supplies
Accumulator belt for Xerox Phaser 7760: can I refurbish this unit myself? If so where can I buy the parts to refurb the belt?
064K91451 iteminconline they sell the belt only and also the home position sensor encase you have an error.
May 12, 2014 | Xerox Phaser 7760/YDX Laser Printer
Hello, I have a xerox 7700 dx machine. Since moving the machine to new premises, when turning it on, I receive the error message, "Error 30 accumulator belt home position took too long" and it doesn't...
The error is caused by the home sensor for the accumulator belt not finding the home position of the belt. Since the error occured after a move, toner probably contaminated the sensor. Use canned air and blow out the sensor. Manual @: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
to locate the sensor. The other possibility is that the accumulator belt bit the dust. Parts a vailable at: http://www.lpscomputer.com/p-2993-1-016-1889-00-accumulator-belt-assembly.aspx
Apr 07, 2010 | Xerox Phaser 7700 Laser Printer
Phaser 8560 Error Code 09,005.40.5185
Hi mark711:
Here is you problem.
9,005.49: Ink loader fault. The cyan ink melt heater is on, but the ink does not
appear to be dripping.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Are the ink sticks all Xerox ink? Go to
Step 2.
Advise
customer. Run
clearISCfault
test to clear the
error.
2 1. Manually verify that the ink stick is able to
advance in the ink loader chute.
Go to
Step 3.
Remove any
blockage and/
or replace the
ink stick.Run
clearISCfault
test to clear the
error.
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace
the
printhead.
Replace the ink
loader
assembly. Run
clearISCfault
test to clear the error.
Hope this helps
Apr 23, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 7700DN color printer
I would be willing to be it's one of two things.
Most common is a jammed gear on the imaging units. Remove all imaging units CMKY. The turn on machine. If the noise is gone, start replacing imaging unit one at a time tile noise reappears. Replace defective imaging unit.
If that doesn't work remove the accumulator belt from the right side of the machine and then turn machine on, see if noise is gone. If so replace accumulator belt.
May 16, 2008 | Xerox Phaser 7700DN Laser Printer
try this
The following functions will generate a Tech Rep Fault:
  • Error: 30: Belt Home Too long
  • Errors: 12, 13, 14, 15: ATC-YMCK Sensor Fail
  • Errors: 40, 44: Fuser Main/Sub Lamp Temp Too High
  • Enter Service Diagnostics
  • Highlight NVRAM Access and press OK
  • Highlight Clear Tech Rep Faults and press OK
  • Highlight the Tech Rep fault to be cleared and press OK
If you have had the error 3 consecutive times , you do need to send the snippet to the printer to clear the error. The instructions how to do it are in the download.
Other things. You may need to replace the accumulator belt.
You may have toner backed up in the waste auger, you can clean that out and replace the waste bottle.
Cause:
The plastic tab attached to the cleaning blade assembly was broken, this tab opens the cleaning blade waste assembly when the belt is lowered .
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. The waste toner from accumulator belt cleaner could not reach the waste bin and jammed the augur. This caused the grinding noise by stalling the accumulator belt motor. This causes an error 30 code to be displayed.
The belt cleaner does come as a separate part 016-1889-00 and is very easy to fit and much cheaper than a new belt assembly.
Error 30 is a Tech Rep fault. After three Error 30's, the NVRAM Clear Tech Rep Faults will need to be reset to be able clear the Error 30 message.
Mar 04, 2008 | Xerox Phaser 7700 Laser Printer
Phaser 7700 Accumulator Belt Replaced, upon startup there is an error
POSSIBILITIES
Problem:
1st BTR Contact Failure or 1st BTR Retract Failure Message is displayed after replacing the Accumulator Belt Cause:
A Phaser 7700 Accumulator Belt was installed in a Phaser 7750. The Phaser 7700 Accumulator Belt does not have retractable 1st Bias Transfer Rollers; so these errors will be reported if one is installed in a Phaser 7750 printer. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Remove the Phaser 7700 Accumulator Belt and install a Phaser 7750 Accumulator Belt. TRY FIRST (Solutions without parts):
1. Check that all shipping restraits have been removed.
TROUBLESHOOTING TIPS AND HINTS:
1. Test the 1st BTR motor in diagnostics to verify proper operation. 2. Test the 1st BTR sensor in diagnostics, then run the 1st BTR motor test and recheck the 1st BTR sensor. Sensor state should alternate between L and H. The sensor is part of the accumulator belt.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
116177400 1 *KIT IBT - UNIT
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers, exit rollers and guides; replace if
necessary.
2. Clean feed rollers and exit rollers only when dust or
debris is visible.
3. Remove and clean all paper trays.
4. Clean the Laser Scanner Unit window.
5. Inspect the image density sensors; clean if necessary.
6. Inspect the accumulator belt home sensor; clean if
necessary.
7. Inspect the fuser assembly; clean if necessary.
8. Print the Error Log, diagnose and repair any problems as
indicated.
9. Print the Usage Profile, diagnose and repair any
problems as indicated.
10. Check version of all installed firmware; as
appropriate, install the latest version of firmware.
11. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
Problem:
Jan 25, 2008 | Tektronix Phaser 860DP Thermal Printer
61 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
